查看: 4833|回复: 5
[ThreadX全家桶] ThreadX GUIX的screen stack是什么东东
发表于 2020-9-15 12:36:49 | 显示全部楼层 |阅读模式
GUIX Studio里面有这个:
查阅了下,这是仅有的资料:
大概看了下,貌似意思是说各种控件状态的上下文切换。
发表于 2020-9-15 14:20:45 | 显示全部楼层
Animation: Start an animation with specified information. Attach: Attach the target screen to the parent screen, if the parent screen is not specified, the target screen will be attached to the root window. Detach: Detach the target screen from its parent. Hide: Hide the target screen. Screen Stack Pop: Pop a screen from the internal screen stack. Screen Stack Push: Push a screen pointer to the internal screen stack. Screen Stack Reset: Remove all screen pointers from the internal screen stack. Show: Show the target screen. Toggle: Attach the target screen to the current screen's parent, and detach the current screen from its parent. Window Execute: Modally executes the target screen. Window Execute Stop: Exit modally execution of the current screen.
发表于 2020-9-15 14:22:08 | 显示全部楼层
https://docs.microsoft.com/zh-cn/azure/rtos/guix/guix-studio-7
这里有对这几个选项的解释。
发表于 2020-9-15 14:22:46 | 显示全部楼层
 楼主| 发表于 2020-9-15 14:24:44 | 显示全部楼层
sunpeng123 发表于 2020-9-15 14:22
https://docs.microsoft.com/zh-cn/azure/rtos/guix/guix-studio-7   这个里面有对这个的解释
谢谢。
 楼主| 发表于 2020-9-15 14:43:21 | 显示全部楼层
GMT+8, 2026-11-23 19:34 , Processed in 1.043701 second(s), 27 queries .
