查看: 6611|回复: 5
[RTOS] microsoft 的threadx 套件例程更新的,使用官方班子的可以嫖一波了
发表于 2020-9-6 20:58:44 | 显示全部楼层 |阅读模式
地址如下:
https://github.com/azure-rtos/samples
内容如下:
Azure RTOS - Additional samplesThis repository is used to distribute IDE and board-specific ZIP filesthat you can use in addition to the content in the getting-startedrepository.
The following ZIP files can be downloaded from the release associated with this repository or the direct links:
NOTE: These zip files are completely self-contained and include appropriatecode from the other Azure RTOS repositories. Please refer to the LICENSE.txt filein each ZIP file for licensing requirements.
The MXChip AZ3166 IoT DevKit is currently supported by the [getting-started] guide. And you can also download the whole CMake project as ZIP file from:
Azure RTOS with Azure Sphere sampleThe Azuure RTOS and Azure Sphere better together sample can be found at:
https://github.com/Azure-Samples/Azure-RTOS-on-Azure-Sphere-Mediatek-MT3620
This sample demonstrates how Azure Sphere and Azure RTOS are able to run together on the MediaTek MT3620 Development Kit.
发表于 2020-9-6 22:52:52 | 显示全部楼层
官方这么不待见MDK,
发表于 2020-9-7 03:24:38 | 显示全部楼层
感觉官方的Demo例子做的略粗糙。
 楼主| 发表于 2020-9-7 09:44:15 | 显示全部楼层
morning_enr6U 发表于 2020-9-6 22:52
官方这么不待见MDK,
估计没钱买mdk
 楼主| 发表于 2020-9-7 09:45:16 | 显示全部楼层
eric2013 发表于 2020-9-7 03:24
感觉官方的Demo例子做的略粗糙。
是粗糙了一点。
发表于 2020-9-7 22:32:42 | 显示全部楼层
官方还是定期维护更新的,就是没有H7的demo
GMT+8, 2026-10-26 10:44 , Processed in 0.847393 second(s), 24 queries .
