查看: 2218|回复: 0
[emWin] emWin首版发布于99年6月10号
发表于 2020-7-28 10:15:51 | 显示全部楼层 |阅读模式
都已经更新20年了。
  1. Version control for emWin/GSC
  2. 000804 V1.32    a) various changes implemented
  3. 000403 V1.30f   a) LCD.h V1.30 used
  4. 000327 V1.30e   a) LCD.h V1.06a used
  5. 000323 V1.30d   a) GUIArcFloat.c included
  6. 000323 V1.30c   a) LCD.h V1.06 used
  7. 000229 V1.30b   a) Improved Unicode support in GUIChar.c
  8. 000217 V1.30a   a) LCD_Color update to V1.16 (grayscale support in 8666 mode)
  9. 000211 V1.30    a) 2 new info functions for fonts implemented
  10.                 b) Unicode string support added
  11. 991210 V1.28d   a) GUIChar.C: GUI_DispStringHCenter added
  12.                 b) Compile Warnings eliminated
  13. 991210 V1.28c   a) GUI2DGL.C splitted
  14. 991204 V1.28b   a) GUI_Context.AWin init modified
  15. 991203 V1.28a   a) GUI2DGL init now initializes GUI_Context.AWin
  16. 991203 V1.28    a) LCDColor updated (support for 3bpp)
  17. 991129 V1.26d   a) GUIChar.C update (1.20c)
  18. 991129 V1.26c   a) GUI2DGL.C update (reg. LCD_Init)
  19. 991110 V1.26b   a) GUIChar.h update
  20. 991110 V1.26a   a) GUI.H: System defines (Keys etc) added
  21. 991109 V1.26    a) GUI2DCL.C eliminated
  22. 991018 V1.24    a) All value display routines rewritten in order to
  23.                    support writing into a string (which is helpful
  24.                    for other modules, like Progbar etc.)
  25.                 b) Type cast added in GUI_GetCharDistX in order to
  26.                    make sure characters above 128 are properly handled
  27. 991018 V1.22b   a) LCDChar.c 1.20.02 used
  28. 991018 V1.22a   a) LCDColor V1.12a used
  29. 991018 V1.22    a) Support for 8666 mode (LCDColor V1.12 used)
  30. 991015 V1.21.10 a) LCDColor.c update V1.10f
  31. 991014 V1.21.09 a) GUI2DGL.C update 1.02.05
  32. 991014 V1.21.08 a) GUI.h: Define for GUI_LIGHTBLUE changed
  33. 991012 V1.21.07 a) LCDColor.c: Color translation in 8bpp mode with fixed table as default added
  34. 991011 V1.21.06 a) LCDCOLOR.C V1.10.04 used
  35. 991009 V1.21.05 a) new GUI2DGL.C used
  36. 990927 V1.21.04 a) LCDColor.C: LCD_Color2Color15: Blue and red in return value swapped
  37. 990926 V1.21.03 a) Clipping on entire region for cursor
  38. 990921 V1.21.02 a) Add. locking support for thread safety
  39. 990918 V1.21.00 a) New file GUITASK.C added for thread safety
  40. 990909 V1.20.05 GUI2DCL.c: clean up
  41. 990901 V1.20.04 Config sample changed
  42. 990831 V1.20.02 GUIChar V1.10.01 in order to avoid compiler warnings
  43. 990821 V1.20.01 GUI: Small changes to avoid compiler warnings
  44. 990821 V1.20.00 Files reorganized, GUIX, GUIFONT, GUIFONTX directories
  45.                 created
  46. 990821 V1.14.01 WMID.H eliminated
  47. 990820 V1.14.00 LCDMEM4.C added
  48.                 LCDChar.C: GUI_DispStringCenterAt added
  49. 990810 V1.12.03 GUI.H cleanup, Sample\GUIConf.h cleaned up
  50. 990809 V1.12.02 GUIColor changed in order to ensure proper function
  51.                 with 16-bit CPUs
  52. 990804 v1.12.01 Some compiler warnings generated by the IAR compiler
  53.                 eliminated, code cleaned up
  54. 990802 V1.12.00 Font files now in seperate directory
  55.                 LCDWIN.C --> LCDWIN.CPP, now exports a routine
  56.                 to display the BITMAP under Windows
  57. 990725 v1.10.00 Dynamic fonts are supported (Fontkonverter compatible)
  58. 990720 v1.04.01 New version LCD135X.C
  59. 990713 v1.04.00 LCD135X.C:  V1.10
  60.                 LCDColor.C: V1.10
  61. 990712 V1.03.05 LCD15XX.C: V1.31.01
  62. 990709 V1.03.04 LCD15XX.C: V1.30.03
  63. 990709 V1.03.03 LCD15XX.C: V1.30.01
  64. 990708 V1.03.02 LCD15XX.C: V1.21.02
  65. 990615 V1.03.01 GL_DrawArc now works with degrees
  66. 990615 V1.03 Drawarc implemented
  67. 990615 V1.02 New Version LCD15XX.C: 1.21
  68. 990614 V1.01 New version of LCD15XX.C with support for Segment
  69.              COM lookup tables
  70. 990610 V1.00 ** Initial version for version control purpose
GMT+8, 2026-11-23 18:58 , Processed in 0.857019 second(s), 24 queries .
