查看: 4363|回复: 0
STM32G4库搞的一个快速内部Flash编程函数FLASH_Program_Fast
发表于 2020-7-26 11:14:30 | 显示全部楼层 |阅读模式
代码如下,在文件stm32g4xx_hal_flash.c里面。
  1. /**
  2.   * @brief  Fast program a row double-word (64-bit) at a specified address.
  3.   * @param  Address specifies the address to be programmed.
  4.   * @param  DataAddress specifies the address where the data are stored.
  5.   * @retval None
  6.   */
  7. static void FLASH_Program_Fast(uint32_t Address, uint32_t DataAddress)
  8. {
  9.   uint8_t row_index = (2 * FLASH_NB_DOUBLE_WORDS_IN_ROW);
  10.   uint32_t *dest_addr = (uint32_t *)Address;
  11.   uint32_t *src_addr = (uint32_t *)DataAddress;
  12.   uint32_t primask_bit;
  13.   /* Check the parameters */
  14.   assert_param(IS_FLASH_MAIN_MEM_ADDRESS(Address));
  15.   /* Set FSTPG bit */
  16.   SET_BIT(FLASH->CR, FLASH_CR_FSTPG);
  17.   /* Enter critical section: Disable interrupts to avoid any interruption during the loop */
  18.   primask_bit = __get_PRIMASK();
  19.   __disable_irq();
  20.   /* Program the double words of the row */
  21.   do
  22.   {
  23.     *dest_addr = *src_addr;
  24.     dest_addr++;
  25.     src_addr++;
  26.     row_index--;
  27.   }
  28.   while (row_index != 0U);
  29.   /* Exit critical section: restore previous priority mask */
  30.   __set_PRIMASK(primask_bit);
  31. }
GMT+8, 2026-11-25 17:02 , Processed in 0.260170 second(s), 24 queries .
