查看: 5472|回复: 4
[客户分享] ThreadX GUIX移植到RA8875上的底层优化
发表于 2020-6-28 00:14:34 | 显示全部楼层 |阅读模式
底层接口函数的关键就是下面这个_gx_display_driver_565rgb_setup的第3个参数my_buffer_toggle
UINT my_custom_565_display_driver(GX_DISPLAY *display)
   _gx_display_driver_565rgb_setup(display, GX_NULL,  my_buffer_toggle);
为了方便幕布里面的内容复制到RA8875上展示,直接在RA8875上开个窗口,这样就不需要每次换行时,重新指定坐标地址了。
  1.        x = canvas->gx_canvas_display_offset_x + Copy.gx_rectangle_left;
  2.                 y = canvas->gx_canvas_display_offset_y + Copy.gx_rectangle_top;
  3.                 x1 = Copy.gx_rectangle_right + canvas->gx_canvas_display_offset_x;
  4.                 y1 = canvas->gx_canvas_display_offset_y + Copy.gx_rectangle_bottom;
  5.
  6.                 RA8875_REG = 0x30; RA8875_RAM = x;
  7.                 RA8875_REG = 0x31; RA8875_RAM = x>>8;
  8.
  9.                 RA8875_REG = 0x32; RA8875_RAM = y;
  10.                 RA8875_REG = 0x33; RA8875_RAM = y>>8;
  11.                 RA8875_REG = 0x34; RA8875_RAM = x1;
  12.                 RA8875_REG = 0x35; RA8875_RAM = x1>>8;
  13.                 RA8875_REG = 0x36; RA8875_RAM = y1;
  14.                 RA8875_REG = 0x37; RA8875_RAM = y1>>8;
  15.                 RA8875_REG = 0x46; RA8875_RAM = x;
  16.                 RA8875_REG = 0x47; RA8875_RAM = x>> 8;
  17.                 RA8875_REG = 0x48; RA8875_RAM = y;
  18.                 RA8875_REG = 0x49; RA8875_RAM = y >> 8;
  19.
  20.                 RA8875_REG = 0x02;
  21.
  22.                 for(row = 0; row < copy_height; row++)
  23.               {
  24.                      xxxxxxxxxxxxx
  25.               }
  26.
  27.                 RA8875_REG = 0x30; RA8875_RAM = 0;
  28.                 RA8875_REG = 0x31; RA8875_RAM = 0;
  29.
  30.                 RA8875_REG = 0x32; RA8875_RAM = 0;
  31.                 RA8875_REG = 0x33; RA8875_RAM = 0;
  32.                 RA8875_REG = 0x34; RA8875_RAM = g_LcdWidth;
  33.                 RA8875_REG = 0x35; RA8875_RAM = g_LcdWidth>>8;
  34.                 RA8875_REG = 0x36; RA8875_RAM = g_LcdHeight;
  35.                 RA8875_REG = 0x37; RA8875_RAM = g_LcdHeight>>8;
发表于 2020-6-28 08:43:37 | 显示全部楼层
发表于 2020-10-23 15:29:38 | 显示全部楼层
看不懂这个xyx1y1.有没有这段代码的讲解?
 楼主| 发表于 2020-10-24 08:37:10 | 显示全部楼层
GUIX会把要重绘的区域裁剪出来,这里就是在RA8875上绘制裁剪出来的区域。
发表于 2020-10-24 10:16:26 | 显示全部楼层
嗯,我已经移植到RA8876,有一点区别,需要把gx_utility_rectangle_define的gx_canvas_x_resolution-1和gx_canvas_y_resolution-1的-1去掉,不然会乱。
GMT+8, 2026-11-28 17:00 , Processed in 0.206489 second(s), 24 queries .
