查看: 3998|回复: 2
[JPEG] STM32H7的硬件JPEG也可以为ThreadX GUIX的JPEG提供硬件加速
发表于 2020-6-27 10:26:10 | 显示全部楼层 |阅读模式
ThreadX GUIX提供的JPEG和PNG的加速接口,用户都可以重定向:
  1.     display -> gx_display_driver_palette_set                   = GX_NULL;
  2.     display -> gx_display_driver_buffer_toggle                 = toggle_function;
  3.     display -> gx_display_driver_canvas_blend                  = _gx_display_driver_24xrgb_canvas_blend;
  4.     display -> gx_display_driver_pixel_blend                   = _gx_display_driver_32argb_pixel_blend;
  5.     display -> gx_display_driver_pixelmap_blend                = _gx_display_driver_32argb_pixelmap_blend;
  6.     display -> gx_display_driver_8bit_glyph_draw               = _gx_display_driver_generic_glyph_8bit_draw;
  7.     display -> gx_display_driver_4bit_glyph_draw               = _gx_display_driver_generic_glyph_4bit_draw;
  8.     display -> gx_display_driver_1bit_glyph_draw               = _gx_display_driver_32bpp_glyph_1bit_draw;
  9.     display -> gx_display_driver_8bit_compressed_glyph_draw    = GX_NULL;
  10.     display -> gx_display_driver_4bit_compressed_glyph_draw    = GX_NULL;
  11.     display -> gx_display_driver_1bit_compressed_glyph_draw    = GX_NULL;
  12. #if defined(GX_SOFTWARE_DECODER_SUPPORT)
  13.     display -> gx_display_driver_jpeg_draw                     = _gx_display_driver_24xrgb_jpeg_draw;
  14.     display -> gx_display_driver_png_draw                      = _gx_display_driver_24xrgb_png_draw;
  15. #endif
发表于 2020-6-27 16:51:26 | 显示全部楼层
这个支持上就完美了,perfect !
代码不规范,亲人两行泪!
 楼主| 发表于 2020-6-28 00:39:07 | 显示全部楼层
missfox 发表于 2020-6-27 16:51
这个支持上就完美了,perfect !
可以参考emWin的为其做上支持。
基于V7开发板的裸机和各种RTOS版本的emWin程序模板,支持硬件JPEG,已发布(2019-05-26)
https://forum.anfulai.cn/forum.p ... 3843&fromuid=58
GMT+8, 2026-10-26 11:28 , Processed in 0.428172 second(s), 24 queries .
