查看: 7028|回复: 3
[有问必答] ST Link下载程序时提示Invalid Rom Table,怎么办?
发表于 2020-6-22 14:38:04 | 显示全部楼层 |阅读模式
我这里两块STM32F407IG 的板子(版本为D030-8)都出现了下载程序时Invalid ROM Table的问题,Keil版本是5.23, Pack为DFP.2.11.0,下载器为ST-Link。
其中有一个是刚刚可以下载程序,测试了几次之后就下载不了了,请问这个问题该怎么解决?
后来我尝试通过串口ISP模式下载程序,点击next按钮后一直提示no response from target那个信息。
发表于 2020-6-22 14:59:38 | 显示全部楼层
下载器接触不良会这样,换个下载器整。
 楼主| 发表于 2020-6-22 15:42:17 | 显示全部楼层
我在网上找到了解决方法,这个方法可以解决我的问题。
http://www.keil.com/support/docs/3566.htm
PROBLEM
When trying to download to my STM32 device, using ULINK2, ULINK-ME or ULINKPro, I get the following message:
Invalid ROM Table
The ULINK-ME/ULINK2 and ULINKPro adapters have worked with this board in the past. How can get downloading to work again?
SOLUTION
For ULINK2, ULINK-ME and ULINKPro debug adapters, make sure the Connect and Reset Options in Options For Target — Debug — Settings are set as follows:
The Connect: option must be set to under Reset
The Reset: option must be set to HW RESET
After saving these options, cycle power on the target device, then try the download again. Your application should download as before.
发表于 2020-6-22 16:46:16 | 显示全部楼层
对,这个也是一个后期的解决思路。
STM32的Flash读写保护,SWD引脚锁的各种解决办法汇总(2020-03-10)
https://forum.anfulai.cn/forum.p ... 6798&fromuid=58
GMT+8, 2026-11-28 16:36 , Processed in 0.368051 second(s), 24 queries .
