查看: 4782|回复: 1
使用STM32F4的定时器6触发DAC时,可以同时开启TIM6更新中断干别的
发表于 2020-5-18 10:17:12 | 显示全部楼层 |阅读模式
简易测试代码:
  1. /*
  3. *        函 数 名: dac_InitHard
  4. *        功能说明: 配置PA4 为DAC_OUT1, 启用DMA2
  5. *        形    参: _BufAddr : DMA数据缓冲区地址
  6. *                          _Count : 缓冲区样本个数
  7. *                         _DacFreq : DAC样本更新频率
  8. *        返 回 值: 无
  9. *********************************************************************************************************
  10. */
  11. void TIM6_DAC_IRQHandler( void )
  12. {
  13.         if(TIM_GetITStatus(TIM6, TIM_IT_Update) != RESET)
  14.         {
  15.                 bsp_LedToggle(1);
  16.                 TIM_ClearITPendingBit(TIM6, TIM_IT_Update);
  17.         }
  18. }
  19. void dac_InitHard(uint32_t _BufAddr, uint32_t _Count, uint32_t _DacFreq)
  20. {
  21.         DMA_Cmd(DMA1_Stream5, DISABLE);
  22.         DAC_DMACmd(DAC_Channel_1, DISABLE);
  23.         TIM_Cmd(TIM6, DISABLE);
  24.
  25.            /* 开启DMA, GPIO, DAC, TIM6 时钟 */
  26.           {
  27.                 RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC, ENABLE);
  28.                 RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
  29.                 RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM6, ENABLE);
  30.         }
  31.
  32.         /* 配置GPIO.  */
  33.         {
  34.                 GPIO_InitTypeDef GPIO_InitStructure;
  35.                 RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
  36.                 /* 配置PA4为DAC_OUT1 */
  37.                 GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_4;
  38.                 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
  39.                 GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
  40.                 GPIO_Init(GPIOA, &GPIO_InitStructure);
  41.         }
  42.         /* TIM6 配置 */
  43.         {
  44.                 NVIC_InitTypeDef NVIC_InitStructure;
  45.                 TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure = {0};
  46.
  47.                 RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM6, ENABLE);
  48.                 /* 方便测试,直接配置个10Hz */
  49.                 TIM_TimeBaseStructure.TIM_Period = 1680 - 1;
  50.                 TIM_TimeBaseStructure.TIM_Prescaler = 1000 - 1;
  51.                 TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  52.                 TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  53.                 TIM_TimeBaseStructure.TIM_RepetitionCounter = 0x0000;
  54.                 TIM_TimeBaseInit(TIM6, &TIM_TimeBaseStructure);
  55.                 TIM_ARRPreloadConfig(TIM6, ENABLE);
  56.                 TIM_ITConfig(TIM6, TIM_IT_Update, ENABLE);
  57.                 TIM_SelectOutputTrigger(TIM6, TIM_TRGOSource_Update);
  58.
  59.                 TIM_ITConfig(TIM6, TIM_IT_Update, ENABLE);
  60.
  61.                 NVIC_InitStructure.NVIC_IRQChannel = TIM6_DAC_IRQn;
  62.                 NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  63.                 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  64.                 NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  65.                 NVIC_Init(&NVIC_InitStructure);
  66.         }
  67.         {
  68.                 DAC_InitTypeDef DAC_InitStructure;
  69.
  70.                 RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC, ENABLE);
  71.                 DAC_InitStructure.DAC_Trigger = DAC_Trigger_T6_TRGO;
  72.                 DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_None;
  73.                 DAC_InitStructure.DAC_LFSRUnmask_TriangleAmplitude = DAC_LFSRUnmask_Bit0;
  74.                 DAC_InitStructure.DAC_OutputBuffer = DAC_OutputBuffer_Disable;//DAC_OutputBuffer_Enable;
  75.                 DAC_Init(DAC_Channel_1, &DAC_InitStructure);
  76.         }
  77.         DAC_Cmd(DAC_Channel_1, ENABLE);
  78.
  79.         {
  80.                 DMA_InitTypeDef DMA_InitStructure;
  81.                 RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA1, ENABLE);
  82.                 DMA_DeInit(DMA1_Stream5);
  83.                 DMA_InitStructure.DMA_Channel = DMA_Channel_7;
  84.                 DMA_InitStructure.DMA_PeripheralBaseAddr = DAC_DHR12R1_Address;
  85.                 DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&g_Wave;
  86.                 DMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToPeripheral;
  87.                 DMA_InitStructure.DMA_BufferSize = _Count;
  88.                 DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  89.                 DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  90.                 DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  91.                 DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  92.                 DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  93.                 DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  94.                 DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
  95.                 DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
  96.                 DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
  97.                 DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
  98.                 DMA_Init(DMA1_Stream5, &DMA_InitStructure);
  99.                 DMA_Cmd(DMA1_Stream5, ENABLE);
  100.         }
  101.         DAC_DMACmd(DAC_Channel_1, ENABLE);
  102.         TIM_Cmd(TIM6, ENABLE);
  103. }
 楼主| 发表于 2020-5-18 10:18:46 | 显示全部楼层
GMT+8, 2026-11-25 17:11 , Processed in 0.273992 second(s), 27 queries .
