查看: 6011|回复: 13
[embOS] 原创,终于打通 embOS+LwIP 网络接口sys_arch.c/.h 的底层驱动
发表于 2020-4-28 09:17:43 | 显示全部楼层 |阅读模式
sys_arch.h (2.41 KB, 下载次数: 9)
sys_arch.c (13.67 KB, 下载次数: 11)
目前已知 bug 说明一下
1. 在 开发板 客户端(服务器) 端没有与 远程 的 服务器(客户端) 连接时, 貌似过一会就会出现 硬件中断错误,目前初步估计应该是 消息邮箱 溢出造成的,
   后续有待解决,
2. 如有谁有比较好的解决之法,欢迎更正
3. 开发板与远程设备一旦连接上,就不会出现上述的问题了,而且工作也基本稳定
4. embOS V5.02a
    Lwip    v2.1.2
发表于 2020-4-28 09:47:52 | 显示全部楼层
你搞得那个封装层版呢,这个封装层版的好用。
  1. /*
  2. * Copyright (c) 2001-2003 Swedish Institute of Computer Science.
  3. * All rights reserved.
  4. *
  5. * Redistribution and use in source and binary forms, with or without modification,
  6. * are permitted provided that the following conditions are met:
  7. *
  8. * 1. Redistributions of source code must retain the above copyright notice,
  9. *    this list of conditions and the following disclaimer.
  10. * 2. Redistributions in binary form must reproduce the above copyright notice,
  11. *    this list of conditions and the following disclaimer in the documentation
  12. *    and/or other materials provided with the distribution.
  13. * 3. The name of the author may not be used to endorse or promote products
  14. *    derived from this software without specific prior written permission.
  15. *
  16. * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED
  17. * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
  18. * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT
  19. * SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
  20. * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
  21. * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
  22. * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
  23. * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
  24. * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
  25. * OF SUCH DAMAGE.
  26. *
  27. * This file is part of the lwIP TCP/IP stack.
  28. *
  29. * Author: Adam Dunkels <adam@sics.se>
  30. *
  31. */
  32. #include <string.h>
  33. #include "cmsis_os2.h"
  34. #include "lwip/opt.h"
  35. #include "lwip/sys.h"
  36. #if !NO_SYS
  37. static uint32_t tick_freq;
  38. /* Time to kernel ticks */
  39. static uint32_t ms2tick (uint32_t ms) {
  40.   if (ms == 0U) {
  41.     return (osWaitForever);
  42.   }
  43.   if (tick_freq != 0U) {
  44.     ms = (ms * tick_freq) / 1000U;
  45.   }
  46.   return (ms);
  47. }
  48. /* Kernel ticks to time */
  49. static uint32_t tick2ms (uint32_t tick) {
  50.   if (tick_freq != 0U) {
  51.     tick = (tick * 1000U) / tick_freq;
  52.   }
  53.   return (tick);
  54. }
  55. /* Mutexes */
  56. err_t sys_mutex_new(sys_mutex_t *mutex)
  57. {
  58.   static const osMutexAttr_t attr = {
  59.     NULL, osMutexPrioInherit | osMutexRecursive | osMutexRobust, NULL, NULL
  60.   };
  61.   osMutexId_t id;
  62.   id = osMutexNew(&attr);
  63.   if (id == NULL) {
  64.     return ERR_MEM;
  65.   }
  66.   *mutex = id;
  67.   return ERR_OK;
  68. }
  69. void sys_mutex_free(sys_mutex_t *mutex)
  70. {
  71.   osMutexDelete(*mutex);
  72. }
  73. void sys_mutex_lock(sys_mutex_t *mutex)
  74. {
  75.   osMutexAcquire(*mutex, osWaitForever);
  76. }
  77. void sys_mutex_unlock(sys_mutex_t *mutex)
  78. {
  79.   osMutexRelease(*mutex);
  80. }
  81. /* Semaphores */
  82. err_t sys_sem_new(sys_sem_t *sem, u8_t count)
  83. {
  84.   osSemaphoreId_t id;
  85.   id = osSemaphoreNew(1U, count, NULL);
  86.   if (id == NULL) {
  87.     return ERR_MEM;
  88.   }
  89.   *sem = id;
  90.   return ERR_OK;
  91. }
  92. void sys_sem_free(sys_sem_t *sem)
  93. {
  94.   osSemaphoreDelete(*sem);
  95. }
  96. u32_t sys_arch_sem_wait(sys_sem_t *sem, u32_t timeout)
  97. {
  98.   osStatus_t status;
  99.   status = osSemaphoreAcquire(*sem, ms2tick(timeout));
  100.   if (status != osOK) {
  101.     return SYS_ARCH_TIMEOUT;
  102.   }
  103.   return 0U;
  104. }
  105. void sys_sem_signal(sys_sem_t *sem)
  106. {
  107.   osSemaphoreRelease(*sem);
  108. }
  109. /* Mailboxes */
  110. err_t sys_mbox_new(sys_mbox_t *mbox, int size)
  111. {
  112.   osMessageQueueId_t id;
  113.   id = osMessageQueueNew((uint32_t)size, sizeof(void *), NULL);
  114.   if (id == NULL) {
  115.     return ERR_MEM;
  116.   }
  117.   *mbox = id;
  118.   return ERR_OK;
  119. }
  120. void sys_mbox_free(sys_mbox_t *mbox)
  121. {
  122.   osMessageQueueDelete(*mbox);
  123. }
  124. void sys_mbox_post(sys_mbox_t *mbox, void *msg)
  125. {
  126.   osMessageQueuePut(*mbox, &msg, 0, osWaitForever);
  127. }
  128. err_t sys_mbox_trypost(sys_mbox_t *mbox, void *msg)
  129. {
  130.   osStatus_t status;
  131.   status = osMessageQueuePut(*mbox, &msg, 0U, 0U);
  132.   if (status != osOK) {
  133.     return ERR_MEM;
  134.   }
  135.   return ERR_OK;
  136. }
  137. u32_t sys_arch_mbox_fetch(sys_mbox_t *mbox, void **msg, u32_t timeout)
  138. {
  139.   osStatus_t status;
  140.   status = osMessageQueueGet (*mbox, msg, NULL, ms2tick(timeout));
  141.   if (status != osOK) {
  142.     return SYS_ARCH_TIMEOUT;
  143.   }
  144.   return 0U;
  145. }
  146. u32_t sys_arch_mbox_tryfetch(sys_mbox_t *mbox, void **msg)
  147. {
  148.   osStatus_t status;
  149.   status = osMessageQueueGet (*mbox, msg, NULL, 0U);
  150.   if (status != osOK) {
  151.     return SYS_MBOX_EMPTY;
  152.   }
  153.   return 0U;
  154. }
  155. /* Threads */
  156. sys_thread_t sys_thread_new(const char *name, lwip_thread_fn function, void *arg, int stacksize, int prio)
  157. {
  158.   osThreadAttr_t attr;
  159.   osThreadId_t   id;
  160.   memset (&attr, 0, sizeof(attr));
  161.   attr.name       = name;
  162.   attr.stack_size = (uint32_t)stacksize;
  163.   attr.priority   = (osPriority_t)prio;
  164.   id = osThreadNew(function, arg, &attr);
  165.   return id;
  166. }
  167. /* Time */
  168. u32_t sys_now()
  169. {
  170.   return (tick2ms(osKernelGetTickCount()));
  171. }
  172. u32_t sys_jiffies()
  173. {
  174.   return (osKernelGetTickCount());
  175. }
  176. /* Critical sections */
  177. #if SYS_LIGHTWEIGHT_PROT
  178. sys_prot_t sys_arch_protect(void)
  179. {
  180.   sys_prot_t pval;
  181.   pval = osKernelLock();
  182.   return pval;
  183. }
  184. void sys_arch_unprotect(sys_prot_t pval)
  185. {
  186.   osKernelRestoreLock (pval);
  187. }
  188. #endif /* SYS_LIGHTWEIGHT_PROT */
  189. void sys_init(void)
  190. {
  191.   tick_freq = osKernelGetTickFreq ();
  192.   if (tick_freq > 990U && tick_freq < 1010U) {
  193.     // No scaling for 1ms ticks
  194.     tick_freq = 0U;
  195.   }
  196. }
  197. #endif /* !NO_SYS */
 楼主| 发表于 2020-4-28 09:52:32 | 显示全部楼层
你提供的这个封装层,在 embOS + Lwip 上使用不行,我已经测试过了的,所以后来只能使用 embOS 的原型函数 就可以
embOS 提供的 v2 封装层,我目前使用 除了 那个 创建任务函数可以正常使用外,其他的 v2 封装层都不行啊,目前也不知道到底是咋回事
你目前提供的这个封装层 貌似在 rtx 上使用效果是非常好的哟
发表于 2020-4-28 09:53:59 | 显示全部楼层
hpdell 发表于 2020-4-28 09:52
你提供的这个封装层,在 embOS + Lwip 上使用不行,我已经测试过了的,所以后来只能使用 embOS 的原型函 ...
得给SEGGER反馈,做个更好的封装层。
这个封装层在RTX5和FreeRTOS下都好用。
 楼主| 发表于 2020-4-28 09:58:09 | 显示全部楼层
1. segger 洋文太多,要不托付你 去 segger 反馈一下啊 ?
2. 你提供的封装层 在 rtx5 , FreeRTOS 系统下确实是好用的
 楼主| 发表于 2020-4-28 10:03:42 | 显示全部楼层
貌似发现这个 embOS 的提供的 消息邮箱,os 系统内部 貌似不会 自动 循环使用,这样就容易造成 内存泄漏的问题了,还有 这个 系统,说起来是占用 系统资源小,但是实际使用 貌似需要的 任务 堆栈也不小啊,貌似比 ucos, freertos 还大啊
 楼主| 发表于 2020-4-28 21:04:01 | 显示全部楼层
现在貌似在没有连接上网络运行一会就会出现如下错误
System Handler Control and State Register = 0x10000 , Addr = 0xE000ED24
Memory Fault Status Register = 0x0 , Addr = 0xE000ED28
Bus Fault Status Register = 0x1 , Addr = 0xE000ED29
Bus Fault Manage Address Register = 0x0 , Addr = 0xE000ED38
Usage Fault Status Register = 0x0 , Addr = 0xE000ED2A
Hard Fault Status Register = 0x40000000 , Addr = 0xE000ED2C
Debug Fault Status Register = 0x0 , Addr = 0xE000ED30
Auxiliary Fault Status Register = 0x0 , Addr = 0xE000ED3C
这些个地址 的介绍在哪里可以查看啊 ???
 楼主| 发表于 2020-4-28 23:06:46 | 显示全部楼层
貌似使用 embOS + Lwip 的人民很少哇
发表于 2020-4-29 10:21:19 | 显示全部楼层
2. 你提供的封装层 在 rtx5 , FreeRTOS 系 ...
SEGGER这块好像国内专门有人搜集这方面的问题,给他们反馈。
发表于 2020-4-29 10:26:27 | 显示全部楼层
System Handler Control and State Register = 0x ...
 楼主| 发表于 2020-4-29 21:06:04 | 显示全部楼层
这个中断地址,有没有具体的相关介绍啊 ?
发表于 2020-4-30 07:47:27 | 显示全部楼层
在私有外设,这个要翻翻编程手册,或者权威指南。
 楼主| 发表于 2020-5-5 20:10:52 | 显示全部楼层
终于 搞定了, 目前基本可以正常使用了,
不过还有个小 小的 bug, 不影响正常使用
上传 来备份或者供后续需要者 提供参考,
已目前的水准 也只能这样了, 后续看看哪位高人 改 好 改 完美哟
sys_arch.h (2.25 KB, 下载次数: 5)
sys_arch.c (17.28 KB, 下载次数: 10)
目前已知 bug ,
说明: 已知问题
      a. 开发板设置为 客户端, 如果 远程 服务器端没有连接 开发板 客户端, 会出现
         lwip v2.1.2
         1. Assertion "p != NULL" failed at line 732 in ..\Middlewares\Third_Party\LwIP\src\core\pbuf.c
            出现这个貌似也不会影响正常使用
         2. 可以在底层 把这句 删除掉即可, 不删除也不会影响正常使用, 出现这句提示的原因,主要是
            sys_mbox_valid 这个函数还没有完全正常搞好造成的吧?
      b. 开发板设置为 服务器, 工作正常, 也没有任何异常提示
c. 图片, 图片中消息显示, mobx 的 新建, 释放, 还有信号量的 新建, 释放 都是 正常的
发表于 2023-7-18 18:04:01 | 显示全部楼层
牛逼大佬
GMT+8, 2026-11-24 00:28 , Processed in 1.193530 second(s), 27 queries .
