查看: 3499|回复: 2
[Linux] linux下OTA功能基于licurl使用http下载文件
发表于 2020-4-21 09:10:47 | 显示全部楼层 |阅读模式
版权声明:本版面文章皆为原创、或参考其他技术网站、博客后自己动手做实验所得,转载请注明出处。
商务合作:lz_kwok@163.com
易开嵌入式工作室
嵌入式系统,OTA功能是十分重要的。linux环境下,使用libcurl,通过http可以很方便实现文件下载功能,并显示文件下载进度。实现方案如下:
首先定义下载地址和下载路径
  1. #define downLoad_url         "http://xxxx/downloadExample/update.tar.gz"
  2. #define downLoad_file         "/home/xxx/update.tar.gz"
初始化libcurl并配置
  1. CURLcode curl_base::Download(std::string strUrl,std::string filepath)
  2. {
  3.     CURLcode res;
  4.     char *progress_data = "* ";
  5.     FILE* fp = fopen(filepath.c_str(),"wb+");
  6.     curl_handle = curl_easy_init();
  7.     /* send all data to this function */
  8.     curl_easy_setopt(curl_handle, CURLOPT_WRITEFUNCTION, OnDownLoadFile);
  9.     /* we pass our 'chunk' struct to the callback function */
  10.     curl_easy_setopt(curl_handle, CURLOPT_WRITEDATA, (void *)fp);
  11.     curl_easy_setopt(curl_handle, CURLOPT_NOPROGRESS, 0L);
  12.     curl_easy_setopt(curl_handle, CURLOPT_PROGRESSFUNCTION, my_progress_func);
  13.     curl_easy_setopt(curl_handle, CURLOPT_PROGRESSDATA, progress_data);
  14.     curl_easy_setopt(curl_handle, CURLOPT_FOLLOWLOCATION, 1);
  15.     curl_easy_setopt(curl_handle, CURLOPT_SSL_VERIFYPEER, 0L);
  16.     curl_easy_setopt(curl_handle, CURLOPT_SSL_VERIFYHOST, 0L);
  17.     curl_easy_setopt(curl_handle,CURLOPT_RESUME_FROM,0);  //从0字节开始下载
  18.     /* 设置连接超时,单位:毫秒 */
  19.     curl_easy_setopt(curl_handle, CURLOPT_CONNECTTIMEOUT_MS, 10000L);
  20.     curl_easy_setopt(curl_handle, CURLOPT_TIMEOUT_MS, 10000L);
  21.     curl_easy_setopt(curl_handle, CURLOPT_NOSIGNAL, 3);
  22.     curl_easy_setopt(curl_handle, CURLOPT_URL, const_cast<char*>(strUrl.c_str()));
  23.     /* get it! */
  24.     res = curl_easy_perform(curl_handle);
  25.     /* check for errors */
  26.     if (res != CURLE_OK) {
  27.         fprintf(stderr, "curl_easy_perform() failed: %s\n", curl_easy_strerror(res));
  28.     }
  29.     fclose(fp);
  30.     return res;
  31. }
其中,注意要关闭CURLOPT_NOPROGRESS。看下官网解释:
If onoff is to 1, it tells the library to shut off the progress meter completely for requests done with this handle. It will also prevent the CURLOPT_XFERINFOFUNCTION or CURLOPT_PROGRESSFUNCTION from getting called.
回调函数如下:
  1. static size_t OnDownLoadFile(void* buffer,size_t size, size_t nmemb,void* fp)
  2. {
  3.    fwrite(buffer, size, nmemb, (FILE*)fp);
  4.    fflush((FILE*)fp);
  5.    return (size*nmemb);
  6. }
  7. static int my_progress_func(char *progress_data,
  8.                      double t, /* dltotal */
  9.                      double d, /* dlnow */
  10.                      double ultotal,
  11.                      double ulnow)
  12. {
  13.   printf("%s %g / %g (%g %%)\n", progress_data, d, t, d*100.0/t);
  14.   return 0;
  15. }
下载完成后,进行clean操作:
  1. void curl_base::DownloadFinish()
  2. {
  3.     curl_easy_cleanup(curl_handle);
  4. }
主函数:
  1. void *myDownload_run(void *para){
  2.         mycurl::my_curl::curl_base curl;
  3.         curl.Download(downLoad_url,downLoad_file);
  4.         curl.DownloadFinish();
  5.         while(1){
  6.                 sleep(2);
  7.         }
  8. }
编译后,查看运行效果:
*  271917 / 364519 (74.5961 %)
*  273365 / 364519 (74.9933 %)
*  276261 / 364519 (75.7878 %)
*  277709 / 364519 (76.1851 %)
*  279157 / 364519 (76.5823 %)
*  280605 / 364519 (76.9795 %)
*  282053 / 364519 (77.3768 %)
*  283501 / 364519 (77.774 %)
*  284949 / 364519 (78.1712 %)
*  296533 / 364519 (81.3491 %)
*  297981 / 364519 (81.7464 %)
*  302325 / 364519 (82.9381 %)
*  305221 / 364519 (83.7325 %)
*  306669 / 364519 (84.1298 %)
*  308117 / 364519 (84.527 %)
*  309565 / 364519 (84.9242 %)
*  312461 / 364519 (85.7187 %)
*  313909 / 364519 (86.116 %)
*  315357 / 364519 (86.5132 %)
*  316805 / 364519 (86.9104 %)
*  319701 / 364519 (87.7049 %)
*  321149 / 364519 (88.1021 %)
*  322597 / 364519 (88.4994 %)
*  334181 / 364519 (91.6773 %)
*  335629 / 364519 (92.0745 %)
*  337077 / 364519 (92.4717 %)
*  338525 / 364519 (92.869 %)
*  342869 / 364519 (94.0607 %)
*  344317 / 364519 (94.4579 %)
*  348661 / 364519 (95.6496 %)
*  350109 / 364519 (96.0468 %)
*  351557 / 364519 (96.4441 %)
*  353005 / 364519 (96.8413 %)
*  355901 / 364519 (97.6358 %)
*  358797 / 364519 (98.4303 %)
*  361693 / 364519 (99.2247 %)
*  363141 / 364519 (99.622 %)
*  364519 / 364519 (100 %)
OK,完成!!!
发表于 2020-4-21 09:16:26 | 显示全部楼层
就是单纯下载网址上的文件吗,这个单片机实现也很简单,给下面这个地址发送http post/get消息就行。
我之前获取百度地图就是这么干的
 楼主| 发表于 2020-4-21 09:54:04 | 显示全部楼层
我 ...
网络协议栈支持bsd也都很容易。
GMT+8, 2026-11-23 12:50 , Processed in 0.153308 second(s), 24 queries .
