查看: 4713|回复: 5
[CMSIS-RTOS] 关于在RTX5中使用SVC中断
发表于 2020-4-14 10:15:19 | 显示全部楼层 |阅读模式
在RTX5工程中使用的SVC中断一直不能正常运行,大家有没有模板,想参考一下,谢谢了!
下面是官方的说明:
  • Add the SVC User Table file svc_user.c to your project folder and include it into your project. This file is available as a user code template.
  • Write a function implementation. Example:uint32_t svc_atomic_inc32 (uint32_t *mem) {
      // A protected function to increment a counter.
      uint32_t val;
      __disable_irq();
      val  = *mem;
      (*mem) = val + 1U;
      __enable_irq();
      return (val);
  • Add the function to the SVC function table in the svc_user.c module:void * const osRtxUserSVC[1+USER_SVC_COUNT] = {
      (void *)USER_SVC_COUNT,
      (void *)svc_atomic_inc32,
  • Increment the number of user SVC functions:#define USER_SVC_COUNT  1       // Number of user SVC functions
  • Declare a function wrapper to be called by the user to execute the SVC call.
    Code Example (Arm Compiler 6)
    __STATIC_FORCEINLINE uint32_t atomic_inc32 (uint32_t *mem) {
      register uint32_t val;
      __ASM volatile (
        "svc 1" : "=l" (val) : "l" (mem) : "cc", "memory"
      return (val);
    Code Example (Arm Compiler 5 using __svc(x) attribute)
    uint32_t atomic_inc32 (uint32_t *mem) __svc(1);
发表于 2020-4-14 11:23:41 | 显示全部楼层
楼主位的确定是可以的,直接复制粘贴即可,昨天你不是看了么,你没有实际测试下?
RTX5中自定义使用SVC中断方法
https://forum.anfulai.cn/forum.php?m ... id=95810&fromuid=58
 楼主| 发表于 2020-4-15 13:06:03 | 显示全部楼层
RTX5中自定义使用SVC ...
这是我测试用svc_user.c中的程序,一直进不到中断里边去
#include "cmsis_os2.h"
#include "Measure.h"
#include "led.h"
extern osEventFlagsId_t Measureflag_id;
extern osStatus_t status1,statys2;
extern void LED_thread(void *argument);
void svc_TIM3_Int_Init(u16 arr,u16 psc)
    TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
        NVIC_InitTypeDef NVIC_InitStructure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE); //时钟使能
        //定时器TIM3初始化
        TIM_TimeBaseStructure.TIM_Period = arr; //设置在下一个更新事件装入活动的自动重装载寄存器周期的值
        TIM_TimeBaseStructure.TIM_Prescaler =psc; //设置用来作为TIMx时钟频率除数的预分频值
        TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; //设置时钟分割:TDTS = Tck_tim
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //TIM向上计数模式
        TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure); //根据指定的参数初始化TIMx的时间基数单位
        TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE ); //使能指定的TIM3中断,允许更新中断
        //中断优先级NVIC设置
        NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;  //TIM3中断
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;  //先占优先级0级
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;  //从优先级3级
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道被使能
        NVIC_Init(&NVIC_InitStructure);  //初始化NVIC寄存器
        TIM_Cmd(TIM3, ENABLE);  //使能TIMx
extern void * const osRtxUserSVC[1+USER_SVC_COUNT];
        (void *)svc_TIM3_Int_Init,
//(void *)user_function1,
void TIM3_Int_Init(u16 arr,u16 psc) __svc(1);
void TIM3_IRQHandler(void)
        if (TIM_GetITStatus(TIM3, TIM_IT_Update) != RESET)  //检查TIM3更新中断发生与否
                TIM_ClearITPendingBit(TIM3, TIM_IT_Update  );  //清除TIMx更新中断标志
                status1 = osEventFlagsSet (Measureflag_id,0x01);
        osThreadNew(LED_thread,NULL,NULL);
发表于 2020-4-15 18:17:48 | 显示全部楼层
#include "Measure.h" ...
你楼主位代码缺东西,没有关联起来。
atomic_inc32和svc_atomic_inc32
 楼主| 发表于 2020-4-15 22:03:06 | 显示全部楼层
eric2013 发表于 2020-4-15 18:17
你楼主位代码缺东西,没有关联起来。
硬汉哥,我都是根据官方教程来写的,不太清楚怎么关联起来,麻烦解释一下,感谢
发表于 2020-4-16 00:47:17 | 显示全部楼层
分享RTX5的自定义SVC软中断两种实现方法
https://forum.anfulai.cn/forum.php?mod=viewthread&tid=97322
GMT+8, 2026-11-25 21:48 , Processed in 0.200260 second(s), 24 queries .
