查看: 3511|回复: 4
[μCOS-II] 分析源码 uc/os 2.93.00 OSIntEnter()函数遇到些问题
发表于 2020-3-29 10:53:04 | 显示全部楼层 |阅读模式
发现有两个函数
1.
void  OSIntEnter (void)
    if (OSRunning == OS_TRUE) {
        if (OSIntNesting < 255u) {
            OSIntNesting++;                      /* Increment ISR nesting level                        */
        OS_TRACE_ISR_ENTER();
2.
void  OSIntExit (void)
#if OS_CRITICAL_METHOD == 3u                               /* Allocate storage for CPU status register */
    OS_CPU_SR  cpu_sr = 0u;
#endif
        OS_ENTER_CRITICAL();
        if (OSIntNesting > 0u) {                           /* Prevent OSIntNesting from wrapping       */
            OSIntNesting--;
        if (OSIntNesting == 0u) {                          /* Reschedule only if all ISRs complete ... */
            if (OSLockNesting == 0u) {                     /* ... and not locked.                      */
                OS_SchedNew();
                OSTCBHighRdy = OSTCBPrioTbl[OSPrioHighRdy];
                if (OSPrioHighRdy != OSPrioCur) {          /* No Ctx Sw if current task is highest rdy */
#if OS_TASK_PROFILE_EN > 0u
                    OSTCBHighRdy->OSTCBCtxSwCtr++;         /* Inc. # of context switches to this task  */
#endif
                    OSCtxSwCtr++;                          /* Keep track of the number of ctx switches */
#if OS_TASK_CREATE_EXT_EN > 0u
#if defined(OS_TLS_TBL_SIZE) && (OS_TLS_TBL_SIZE > 0u)
                    OS_TLS_TaskSw();
#endif
#endif
                    OS_TRACE_ISR_EXIT_TO_SCHEDULER();
                    OSIntCtxSw();                          /* Perform interrupt level ctx switch       */
                } else {
                    OS_TRACE_ISR_EXIT();
            } else {
        } else {
        OS_EXIT_CRITICAL();
OSIntExit()使用临界段保护了OSIntNesting以确保修改时的正确性, 为什么OSIntEnter()中不用使用临界段保护OSIntNesting 这个全局的系统变量呢,求教各位
发表于 2020-3-29 10:59:57 | 显示全部楼层
这个是需要用户手动加的,标准的中断写法
  1. void  My_Handler (void)
  2. {
  3. #if OS_CRITICAL_METHOD == 3u                                    /* Allocate storage for CPU status register             */
  4.     OS_CPU_SR  cpu_sr;
  5. #endif
  6.     OS_ENTER_CRITICAL();
  7.     OSIntEnter();                                               /* Tell uC/OS-II that we are starting an ISR            */
  8.     OS_EXIT_CRITICAL();
  9.     xxxxxxxxxxxxxxxxxxxx
  10.     OSIntExit();                                                /* Tell uC/OS-II that we are leaving the ISR            */
  11. }
 楼主| 发表于 2020-3-29 11:06:07 | 显示全部楼层
eric2013 发表于 2020-3-29 10:59
这个是需要用户手动加的,标准的中断写法
    OS_CPU_SR  cpu_sr;
#endif
OS_EXIT_CRITICAL();
把函数改成这样可以吗,会对源码编写有什么不好的影响吗
发表于 2020-3-29 11:07:29 | 显示全部楼层
#if OS_CRITICAL_METHOD == 3u                                    /* All ...
随便改,遇到问题了再解决。
 楼主| 发表于 2020-3-29 11:09:38 | 显示全部楼层
eric2013 发表于 2020-3-29 11:07
随便改,遇到问题了再解决。
好的,谢谢eric2013
GMT+8, 2026-11-23 17:48 , Processed in 1.022417 second(s), 24 queries .
