查看: 3683|回复: 6
V6 LUA-RL-Flash+SD和C互调
发表于 2019-9-4 13:58:27 | 显示全部楼层 |阅读模式
说明:lua文件放在外部储存器(例如SD卡)才有项目意义,方便有户修改LUA代码,本次移植RL-FLASHFS。LUA精华是可以和其它语言(如C语言)相互调用起胶水作用
步骤:
1.修改luaconf.h,在其中增加宏定义#define LUA_32BITS;
2.重新实现print函数的底层,Lua的print函数的C语言实现部分是lbaselib.c文件的luaB_print()函数,修改lauxlib.h中宏定义lua_writestring,lua_writeline
/* print a string */
#if !defined(lua_writestring)
#define lua_writestring(s,l)   printf(s)//fwrite((s), sizeof(char), (l), stdout)
#endif
/* print a newline and flush the output */
#if !defined(lua_writeline)
#define lua_writeline()        printf("\n")//(lua_writestring("\n", 1), fflush(stdout))
#endif
3.移植RL-FLASHFS的SD卡文件系统
1)定义getc函数
int getc(FILE *stream)
        char ch = 0;
        int res;
        res = fread(&ch, 1, 1,  stream);
        if(!res)
                return EOF;
        return ch;
2)修改luaconf.h默认路径
#define LUA_PATH_DEFAULT  "M0:\\?.lua;"
#define LUA_CPATH_DEFAULT "M0:\\?.so;"
4.LUA调用C函数必须按LUA格式重新封装并注册
1)格式typedef int (*lua_CFunction) (lua_State *L);
2)封装
static int lua_led_on(lua_State *L)
        bsp_LedOn(1);
        return 1;
static int lua_led_off(lua_State *L)
        bsp_LedOff(1);
        return 1;
static int lua_delay(lua_State *L)
        int num;
        num= lua_tointeger(L, 1);
        bsp_DelayMS(num);
        return 1;
static const struct luaL_Reg mylib[]=
        {"led_on",lua_led_on},
        {"led_off",lua_led_off},
        {"delay",lua_delay},
        {NULL,NULL}
3)注册luaL_setfuncs(L, mylib, 0);
5.C调用LUA函数
  lua_getglobal(L, "ledrun"); //LuaoˉêyÃû
  if (lua_pcall(L, 0, 0, 0) != 0) //ÔËDDoˉêy
        lua_tostring(L, -1);
6.LUA源码led.lua
function ledrun()
        n = 1
        while (n < 20)
        do
                led_on()
                delay(500)
                print("led ok")
                led_off()
                delay(500)
                n = n + 1
        end
end
7.C源码
int main(void)
        lua_State *L;
        bsp_Init();                /* ó2&#188;t3&#245;ê&#188;&#187;ˉ */
        L = luaL_newstate(); /* &#189;¨á¢Lua&#212;&#203;DD&#187;·&#190;3 */
        luaopen_base(L);
//        luaL_openlibs(L);
        while (1)
                luaL_dostring(L, "print(\"Hello,I am lua!\\n--this is newline printf\")\n");
                if (luaL_dofile(L, "M0:\\led.lua"))//&#188;ó&#212;&#216;&#206;&#196;&#188;t
                lua_getglobal(L, "ledrun"); //Luaoˉêy&#195;&#251;
                if (lua_pcall(L, 0, 0, 0) != 0) //&#212;&#203;DDoˉêy
                lua_close(L);
                while (1);
V6 LUA-RL-Flash+SD.zip
2.35 MB, 下载次数: 116
参与人数 1金币 +100 收起 理由
eric2013 + 100 赞一个!
发表于 2019-9-4 15:00:37 | 显示全部楼层
非常感谢楼主分享
发表于 2019-9-21 10:07:28 | 显示全部楼层
楼主测试过可以跑多少行lua吗?
 楼主| 发表于 2019-9-21 11:52:10 | 显示全部楼层
飞行少年 发表于 2019-9-21 10:07
楼主测试过可以跑多少行lua吗?
可以,完全没问题
 楼主| 发表于 2019-9-21 11:56:05 | 显示全部楼层
楼主测试过可以跑多少行lua吗?
多少行是内存的问题
发表于 2020-7-30 16:47:41 | 显示全部楼层
takent 发表于 2019-9-21 11:56
多少行是内存的问题
请问下这个工程 fopen,fread可以使用吗
发表于 2020-7-30 17:05:21 | 显示全部楼层
lua + FatFS,实现lua调用其他lua文件,需要重载c库文件操作函数
https://forum.anfulai.cn/forum.p ... 7441&fromuid=58
GMT+8, 2026-11-25 17:03 , Processed in 0.381186 second(s), 28 queries .
