查看: 7383|回复: 3
[DSP] CMSIS-DSP的不同库版本含义和几个相关宏定义的作用
发表于 2019-7-29 11:00:42 | 显示全部楼层 |阅读模式
不同版本:
  • arm_cortexM7lfdp_math.lib (Cortex-M7, Little endian, Double Precision Floating Point Unit)
  • arm_cortexM7bfdp_math.lib (Cortex-M7, Big endian, Double Precision Floating Point Unit)
  • arm_cortexM7lfsp_math.lib (Cortex-M7, Little endian, Single Precision Floating Point Unit)
  • arm_cortexM7bfsp_math.lib (Cortex-M7, Big endian and Single Precision Floating Point Unit on)
  • arm_cortexM7l_math.lib (Cortex-M7, Little endian)
  • arm_cortexM7b_math.lib (Cortex-M7, Big endian)
  • arm_cortexM4lf_math.lib (Cortex-M4, Little endian, Floating Point Unit)
  • arm_cortexM4bf_math.lib (Cortex-M4, Big endian, Floating Point Unit)
  • arm_cortexM4l_math.lib (Cortex-M4, Little endian)
  • arm_cortexM4b_math.lib (Cortex-M4, Big endian)
  • arm_cortexM3l_math.lib (Cortex-M3, Little endian)
  • arm_cortexM3b_math.lib (Cortex-M3, Big endian)
  • arm_cortexM0l_math.lib (Cortex-M0 / Cortex-M0+, Little endian)
  • arm_cortexM0b_math.lib (Cortex-M0 / Cortex-M0+, Big endian)
  • arm_ARMv8MBLl_math.lib (Armv8-M Baseline, Little endian)
  • arm_ARMv8MMLl_math.lib (Armv8-M Mainline, Little endian)
  • arm_ARMv8MMLlfsp_math.lib (Armv8-M Mainline, Little endian, Single Precision Floating Point Unit)
  • arm_ARMv8MMLld_math.lib (Armv8-M Mainline, Little endian, DSP instructions)
  • arm_ARMv8MMLldfsp_math.lib (Armv8-M Mainline, Little endian, DSP instructions, Single Precision Floating Point Unit)
宏定义:
Each library project have different preprocessor macros.
  • ARM_MATH_BIG_ENDIAN:
Define macro ARM_MATH_BIG_ENDIAN to build the library for big endian targets. By default library builds for little endian targets.
  • ARM_MATH_MATRIX_CHECK:
Define macro ARM_MATH_MATRIX_CHECK for checking on the input and output sizes of matrices
  • ARM_MATH_ROUNDING:
Define macro ARM_MATH_ROUNDING for rounding on support functions
  • ARM_MATH_LOOPUNROLL:
Define macro ARM_MATH_LOOPUNROLL to enable manual loop unrolling in DSP functions
  • ARM_MATH_NEON:
Define macro ARM_MATH_NEON to enable Neon versions of the DSP functions. It is not enabled by default when Neon is available because performances are dependent on the compiler and target architecture.
  • ARM_MATH_NEON_EXPERIMENTAL:
Define macro ARM_MATH_NEON_EXPERIMENTAL to enable experimental Neon versions of of some DSP functions. Experimental Neon versions currently do not have better performances than the scalar versions.
 楼主| 发表于 2019-7-29 11:03:29 | 显示全部楼层
对于H7的话,我们用这个版本
小端,双精度浮点。
发表于 2019-8-2 22:30:48 | 显示全部楼层
终于恢复了,机动
发表于 2019-8-5 10:20:42 | 显示全部楼层
测试是不是缓存
GMT+8, 2026-10-26 21:49 , Processed in 0.173539 second(s), 24 queries .
