查看: 6833|回复: 6
[MDK] MDK-ARM Version 5.28 发布(20190529)
发表于 2019-5-29 11:26:33 | 显示全部楼层 |阅读模式
暂时应该还能下载http://www.keil.com/fid/3pgdf0wt ... les/eval/mdk528.exe
(MD5:E7BEC2DE697CBAB4D8D14B3AA5609C7C)
 楼主| 发表于 2019-5-29 11:36:42 | 显示全部楼层
Microcontroller Development Kit - Version 5.28 release -development-
[uVision updated to V5.28.0.0]
μVision now allows to set the trace clock in the debug configuration independently from the core clock. For those devices using a separate trace clock, trace is now captured and processed correctly. This is available for all ULINK debug adapters and CMSIS-DAP.
The System Analyzer data can now be saved as a comma separated or tab separated value file for post processing.
[Arm Compiler included]
Included Arm Compiler 5 version 5.06u6 - same as in MDK version 5.26: see Release Notes for further details.
Updated Arm Compiler 6 to version 6.12: - same as in MDK version 5.27: see Release Notes for further details.
[Software Packs included]
ARM - CMSIS 5.5.1 - same as in MDK version 5.27.
Keil - MDK Middleware 7.8.0 - same as in MDK version 5.27.
Keil - Arm Compiler Extensions 1.6.1 - same as in MDK version 5.27.
ARM - CMSIS-Driver 2.4.0 - same as in MDK version 5.27.
[Target debugging]
Added: P&E Micro Debugger driver installation can be launched from within μVision Options for Target Debug Settings dialog.
Updated: Segger J-Link debug driver to version 6.46.
Updated: NULink driver to version 3.00.6909.
[Licensing]
This version of MDK introduces the new editions Keil MDK Holtek Edition - Cortex-M0+ and Keil MDK Holtek Edition - Cortex-M.
This version of MDK does not support the MDK Professional 7-day evaluation license.
[Supported Operating Systems]
Refer to System Requirements Overview for hardware and operating system requirements.
发表于 2019-5-29 17:46:28 | 显示全部楼层
已经可以下载了,希望修复调试时卡死的问题,升级5.27后调试经常卡死!
发表于 2019-5-30 09:52:32 | 显示全部楼层
非常感谢楼主分享,刚注意到楼主发的是MDK528上线了,仅随IAR8.40
发表于 2019-5-30 09:59:50 | 显示全部楼层
更新的东西有点少
http://www2.keil.com/mdk5/528
发表于 2019-5-30 10:05:13 | 显示全部楼层
发表于 2019-6-25 10:54:44 | 显示全部楼层
谢谢楼主分享,连接还有效,正在下载。
GMT+8, 2026-11-24 08:47 , Processed in 0.193514 second(s), 27 queries .
