查看: 4920|回复: 1
[有问必答] 用定时器主从模式时最后一个脉冲结束时为高电平,怎么让其输出完整的脉冲并最后为低电平?
发表于 2019-5-19 14:43:09 | 显示全部楼层 |阅读模式
用定时器的主从模式输出精确脉冲时,最后一个脉冲结束时一直为高电平,等于只输出了半个脉冲,有什么办法可以输出一个完整的脉冲最后为低电平?
仿真如下,输出3个脉冲时
以下为主从模式配置的代码,TIM2为主,TIM3为从
  1. void TIM2_Master__TIM3_Slave_Configuration(u32 PulseFrequency)
  2. {
  3.         TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
  4.         TIM_OCInitTypeDef TIM_OCInitStructure;
  5.
  6.         u16 nPDTemp ;
  7.         TIM_Cmd(TIM2, DISABLE);
  8.         nPDTemp = 72000UL/PulseFrequency;
  9.
  10.         // TIM2
  11.         /* Time base configuration */
  12.         TIM_TimeBaseStructure.TIM_Period = nPDTemp-1;
  13.         TIM_TimeBaseStructure.TIM_Prescaler = 999;
  14.         TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  15.         TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  16.         TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
  17.         TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  18.
  19.         // TIM2
  20.         /* PWM1 Mode configuration: Channel1 */
  21.         TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  22.         TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  23.         TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  24.         TIM_OCInitStructure.TIM_Pulse = nPDTemp>>1;//50%
  25.         TIM_OC1Init(TIM2, &TIM_OCInitStructure);
  26.         TIM_OC1PreloadConfig(TIM2, TIM_OCPreload_Enable);
  27.         TIM_ARRPreloadConfig(TIM2, ENABLE);
  28.
  29.         // TIM3
  30.         TIM_TimeBaseStructure.TIM_Period = 0xFFFF;
  31.         TIM_TimeBaseStructure.TIM_Prescaler = 0;
  32.         TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  33.         TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  34.         TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
  35.         TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
  36.
  37.         NVIC_InitTypeDef NVIC_InitStructure;
  38.         NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;
  39.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  40.         NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  41.         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  42.         NVIC_Init(&NVIC_InitStructure);
  43.
  44.         // Output Compare Active Mode configuration: Channel1
  45.         TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Inactive;
  46.         TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  47.         TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  48.         TIM_OCInitStructure.TIM_Pulse = 0xFFFF; // ÕâÀïµÄÅäÖÃÖµÒâÒå²»´ó
  49.         TIM_OC1Init(TIM3, &TIM_OCInitStructure);
  50.
  51.         // Select the Master Slave Mode
  52.         TIM_SelectMasterSlaveMode(TIM2, TIM_MasterSlaveMode_Enable);
  53.         // Master Mode selection
  54.         TIM_SelectOutputTrigger(TIM2, TIM_TRGOSource_Update);
  55.         // Slave Mode selection: TIM3
  56.         TIM_SelectSlaveMode(TIM3, TIM_SlaveMode_Gated);
  57.         TIM_SelectInputTrigger(TIM3, TIM_TS_ITR1);
  58.         TIM_ITRxExternalClockConfig(TIM3, TIM_TS_ITR1);
  59. //        TIM_ITConfig(TIM3, TIM_IT_CC1, ENABLE);
  60.
  61.         TIM_Cmd(TIM2, DISABLE);
  62.         TIM_Cmd(TIM3, DISABLE);
  63. }
  64. void Frequence_Setting(u32 PulseFrequency)
  65. {
  66.         u16 nPDTemp ;
  67.         TIM_Cmd(TIM2, DISABLE);
  68.         nPDTemp = 72000UL/PulseFrequency;
  69.         TIM_SetAutoreload(TIM2,nPDTemp);
  70.         TIM_GenerateEvent(TIM2,TIM_EventSource_Update);
  71.         TIM_SetCompare1(TIM2,nPDTemp/2);
  72. }
  73. void Output_Pulse(u16 Num)
  74. {
  75.                 TIM_Cmd(TIM3, ENABLE);
  76.                 TIM3->CCR1 = Num;
  77.                 TIM3->CNT = 0;
  78.                 TIM_ITConfig(TIM3, TIM_IT_CC1, ENABLE);
  79.                 TIM_Cmd(TIM2, ENABLE);
  80. <div>}</div><div>
  81. </div><div>void TIM3_IRQHandler(void)
  82. {
  83. if (TIM_GetITStatus(TIM3, TIM_IT_CC1) != RESET)     // TIM_IT_CC1
  84. {
  85.   TIM_ClearITPendingBit(TIM3, TIM_IT_CC1);
  86.   TIM_Cmd(TIM2, DISABLE);
  87.   TIM_ITConfig(TIM3, TIM_IT_CC1, DISABLE);
  88.   TIM_Cmd(TIM3, DISABLE);
  89. }
  90. }
  91. </div>
发表于 2019-5-19 14:47:02 | 显示全部楼层
F1的没研究过,H7有研究
借助STM32H7的DMAMUX的定时器触+DMA控制任意IO做PWM和脉冲数控制,爽歪歪
https://forum.anfulai.cn/forum.p ... 1148&fromuid=58
(出处: 安富莱电子论坛)
GMT+8, 2026-11-22 16:46 , Processed in 0.327063 second(s), 27 queries .
