查看: 6184|回复: 2
[MDK] [请教]MDK5.27 AC6编译是产生错误
发表于 2019-5-12 09:04:53 | 显示全部楼层 |阅读模式
我是V5板用户,最近在多个地方看见Eric发的MDK AC6编译速度快,所以决定试一下。
工程是使用stm32cube产生的带Freertos 的工程,默认使用AC5正常编译,无警告。
选用AC6后,出现一堆错误,看起来主要是port.c的汇编产生的。
在论坛里坛友有分享了一篇“Migrate ARM compiler 5 to ARM Compiler 6”,在第10页提到inline assembler的问题,但不知道怎么改?
请问是否可以指导一下?
感谢感谢。
../Middlewares/Third_Party/FreeRTOS/Source/portable/RVDS/ARM_CM0/port.c(162): error: expected '(' after 'asm'
__asm void prvPortStartFirstTask( void )
../Middlewares/Third_Party/FreeRTOS/Source/portable/RVDS/ARM_CM0/port.c(162): error: expected ';' after top-level asm block
../Middlewares/Third_Party/FreeRTOS/Source/portable/RVDS/ARM_CM0/port.c(166): error: use of undeclared identifier 'PRESERVE8'
        PRESERVE8
../Middlewares/Third_Party/FreeRTOS/Source/portable/RVDS/ARM_CM0/port.c(255): error: expected '(' after 'asm'
__asm uint32_t ulSetInterruptMaskFromISR( void )
../Middlewares/Third_Party/FreeRTOS/Source/portable/RVDS/ARM_CM0/port.c(255): error: expected ';' after top-level asm block
../Middlewares/Third_Party/FreeRTOS/Source/portable/RVDS/ARM_CM0/port.c(257): error: use of undeclared identifier 'mrs'
        mrs r0, PRIMASK
../Middlewares/Third_Party/FreeRTOS/Source/portable/RVDS/ARM_CM0/port.c(263): error: expected '(' after 'asm'
__asm void vClearInterruptMaskFromISR( uint32_t ulMask )
../Middlewares/Third_Party/FreeRTOS/Source/portable/RVDS/ARM_CM0/port.c(263): error: expected ';' after top-level asm block
../Middlewares/Third_Party/FreeRTOS/Source/portable/RVDS/ARM_CM0/port.c(265): error: use of undeclared identifier 'msr'
        msr PRIMASK, r0
../Middlewares/Third_Party/FreeRTOS/Source/portable/RVDS/ARM_CM0/port.c(270): error: expected '(' after 'asm'
__asm void xPortPendSVHandler( void )
../Middlewares/Third_Party/FreeRTOS/Source/portable/RVDS/ARM_CM0/port.c(270): error: expected ';' after top-level asm block
../Middlewares/Third_Party/FreeRTOS/Source/portable/RVDS/ARM_CM0/port.c(272): error: unknown type name 'vTaskSwitchContext'
        extern vTaskSwitchContext
../Middlewares/Third_Party/FreeRTOS/Source/portable/RVDS/ARM_CM0/port.c(273): error: expected identifier or '('
        extern pxCurrentTCB
../Middlewares/Third_Party/FreeRTOS/Source/portable/RVDS/ARM_CM0/port.c(285): error: use of undeclared identifier 'mov'
        mov r4, r8                              /* Store the high registers. */
14 errors generated.
发表于 2019-5-12 09:44:15 | 显示全部楼层
要移植MDK里面带的FreeRTOS源码,他们对AC6做了支持,
例子的话,参考我这个帖子:
基于V7开发板的RTX5和FreeRTOS带CMSIS-RTOS V2封装层的模板例程下载,AC6和AC5两个版本
https://forum.anfulai.cn/forum.p ... 3238&fromuid=58
(出处: 安富莱电子论坛)
发表于 2021-12-2 16:59:35 | 显示全部楼层
刚好搞这个用GCC/ARM_CM0覆盖到RVDS/ARM_CM0编译OK
GMT+8, 2026-11-24 12:30 , Processed in 0.525382 second(s), 24 queries .
