查看: 4657|回复: 4
[NUCLEO-H743ZI] Micrium发布的uCOS-II/III + uC/TCPIP的Web Server例子
发表于 2019-4-30 02:35:42 | 显示全部楼层 |阅读模式
Micrium_STM32H743ZI-Nucleo_Webserver.zip (4.97 MB, 下载次数: 96)
BLINKY EXAMPLE FOR THE ST STM32H743ZI Nucleo-144, REVISION B
This example project demonstrates how to initialize uC/TCPIP with uC/DHCPc and uC/HTTP server to display a simple webpage.
MICRIUM PRODUCT VERSIONS
- uC/OS-II  v2.92.16
- uC/OS-III v3.07.03
- uC/CPU    v1.31.04
- uC/LIB    v1.38.03
- uC/Common v1.01.01
- uC/TCPIP  v3.05.00
- uC/HTTP   v3.00.06
- uC/DHCPc  v2.10.01
IDE/COMPILER VERSIONS
- IAR/EWARM v8.32.1
HARDWARE SETUP
- Connect USB Micro-B cable to CN1 to provide power.
- Connect a Ethernet from your local network into the board's Ethernet port.
WORKSPACE LOCATIONS
- ST/STM32H743_Nucleo/Webserver/<OS2|OS3>/IAR/Webserver.eww
BUILD CONFIGURATIONS
- Several build configurations are available with this project:
    source      A full source build that generates an executable
    libgen      A full source build that generates a library
    library     A partial source build that links with the library created by "libgen"
- The "library" configuration can be run by users who do not have access to the source code for Micrium products.
- Users with access to the product source code can copy it into Micrium/Software/<product> and use the "source" and "libgen" configurations.
- Select the appropriate configuration that suits your needs by clicking on Project->Edit Configurations...
USAGE INSTRUCTIONS
IAR
- Open the workspace in IAR.
- Press F7 to build the project and Ctrl+D to start the debug session.
- Once the debug session has started, open the IAR terminal by selecting View->Terminal I/O.
- Press F5 to run the example.
- The uC/TCPIP stack will initialize first with DHCPc enabled and attempt to obtain an IP address from the LAN's DHCP server.
- Should the DHCP server fail to assign an IP address to the board, the application will assign a static IP defined in app_tcpip.c by:
    #define  IP_ADDR
    #define  SUBNET_MASK_ADDR
    #define  DFLT_GATEWAY_ADDR
- Once an IP is assigned to the board, you may point your web browser to the board's IP address and it will load a simple web page.
- Try toggling LEDs by clicking on the "Toggle LED 1" or "Toggle LED 2" buttons on the web page.
Please feel free to post questions or comments related to this example project at Micrium's forum page:
https://www.micrium.com/forums/t ... cleo-144-webserver/
发表于 2019-4-30 10:59:17 | 显示全部楼层
哎,为啥就是和KEIL不对付呢
发表于 2019-4-30 11:38:34 | 显示全部楼层
编译无法通过,不过倒是可以参考下。
发表于 2019-4-30 19:25:35 | 显示全部楼层
目前的支持ipv6不?  应该马上就全换6了。国家连路由器都要强制弄了。
发表于 2019-5-3 18:05:34 | 显示全部楼层
支持。
GMT+8, 2026-10-27 21:27 , Processed in 0.144167 second(s), 27 queries .
