查看: 1784|回复: 1
[emWin] LISTBOX_SetBkColor();函数在仿真中无法调用
发表于 2019-4-26 23:00:06 | 显示全部楼层 |阅读模式
代码如下
*                SEGGER Microcontroller GmbH & Co. KG                *
*        Solutions for real time microcontroller applications        *
* C-file generated by:                                               *
*        GUI_Builder for emWin version 5.32                          *
*        Compiled Oct  8 2015, 11:59:02                              *
*        (c) 2015 Segger Microcontroller GmbH & Co. KG               *
*        Internet: www.segger.com  Support: support@segger.com       *
// USER START (Optionally insert additional includes)
// USER END
#include "DIALOG.h"
*       Defines
#define ID_FRAMEWIN_0    (GUI_ID_USER + 0x00)
#define ID_LISTVIEW_0    (GUI_ID_USER + 0x02)
#define Color 0XE7F2E2
// USER START (Optionally insert additional defines)
// USER END
*       Static data
// USER START (Optionally insert additional static data)
// USER END
*       _aDialogCreate
  { FRAMEWIN_CreateIndirect, "Framewin", ID_FRAMEWIN_0, 0, 0, 800, 480, 0, 0x0, 0 },
  { LISTVIEW_CreateIndirect, "Listview", ID_LISTVIEW_0, 0, 0, 790, 400, 0, 0x0, 0 },
  // USER START (Optionally insert additional widgets)
  // USER END
*       Static code
// USER START (Optionally insert additional static code)
// USER END
*       _cbDialog
  WM_HWIN hItem;
  int     NCode;
  int     Id;
  // USER END
  switch (pMsg->MsgId) {
  case WM_INIT_DIALOG:
    // Initialization of 'Framewin'
    hItem = pMsg->hWin;
        FRAMEWIN_SetClientColor(hItem, Color );
    FRAMEWIN_SetFont(hItem, GUI_FONT_24_ASCII);
    // Initialization of 'Listview'
    hItem = WM_GetDialogItem(pMsg->hWin, ID_LISTVIEW_0);
        LISTBOX_SetBkColor(hItem,LISTBOX_CI_UNSEL,GUI_RED);
        LISTBOX_SetDefaultBkColor(LISTBOX_CI_UNSEL,GUI_RED);
    LISTVIEW_AddColumn(hItem, 100, "1", GUI_TA_HCENTER | GUI_TA_VCENTER);
    LISTVIEW_AddColumn(hItem, 130, "2", GUI_TA_HCENTER | GUI_TA_VCENTER);
    LISTVIEW_AddRow(hItem, NULL);
    LISTVIEW_SetGridVis(hItem, 1);
    LISTVIEW_AddColumn(hItem, 180, "3", GUI_TA_HCENTER | GUI_TA_VCENTER);
    LISTVIEW_AddColumn(hItem, 130, "4", GUI_TA_HCENTER | GUI_TA_VCENTER);
    LISTVIEW_AddColumn(hItem, 130, "5", GUI_TA_HCENTER | GUI_TA_VCENTER);
    LISTVIEW_AddColumn(hItem, 130, "6", GUI_TA_HCENTER | GUI_TA_VCENTER);
    LISTVIEW_SetFont(hItem, GUI_FONT_13B_ASCII);
        LISTVIEW_SetHeaderHeight(hItem,40);
        LISTVIEW_SetRowHeight(hItem,60);
    // USER START (Optionally insert additional code for further widget initialization)
    // USER END
  case WM_NOTIFY_PARENT:
    NCode = pMsg->Data.v;
    switch(Id) {
    case ID_LISTVIEW_0: // Notifications sent by 'Listview'
      switch(NCode) {
      case WM_NOTIFICATION_CLICKED:
        // USER END
        // USER END
      case WM_NOTIFICATION_SEL_CHANGED:
        // USER END
      // USER END
    // USER START (Optionally insert additional code for further Ids)
    // USER END
  // USER START (Optionally insert additional message handling)
  // USER END
  default:
    WM_DefaultProc(pMsg);
*       Public code
*       CreateFramewin
WM_HWIN CreateFramewin(void);
WM_HWIN CreateFramewin(void) {
  WM_HWIN hWin;
  hWin = GUI_CreateDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), _cbDialog, WM_HBKWIN, 0, 0);
  return hWin;
// USER START (Optionally insert additional public code)
// USER END
void MainTask(void)
        /* 初始化 */
        GUI_Init();
        /* 窗口自动使用存储设备 */
        /* 创建对话框,使用GUIBulder5.32生成的对话框创建函数 */
        CreateFramewin();
        while(1)
                GUI_Delay(50);
发表于 2019-4-27 00:28:32 | 显示全部楼层
GMT+8, 2026-11-24 16:46 , Processed in 0.342792 second(s), 27 queries .
