查看: 3861|回复: 4
[开发工具] 为了支持双核STM32H745xx/H755xx/H747xx/H757xx,ST提供的MDK和IAR支持包
发表于 2019-4-25 03:38:11 | 显示全部楼层 |阅读模式
MDK:
Keil.STM32H7xx_DFP.2.2.1.zip (32.3 MB, 下载次数: 196)
  1. /******************** (C) COPYRIGHT 2019 STMicroelectronics ********************
  2. * File Name          : readme.txt
  3. * Author             : STMicroelectronics
  4. * Description        : This file describes how to add STM32Hxxx devices  support on MDK-ARM
  5. ********************************************************************************
  6. Running the "Keil.STM32H7xx_DFP.2.2.1.pack" adds the following:
  7.
  8. 1. Part numbers for  :
  9. - Dual Core lines: STM32H745xx/H755xx/H747xx/H757xx
  10. - Value line: STM32H750xx
  11. - New single core line: STM32H742xx (with reduced internal RAM and without LTDC, JPEG peripherals)
  12. - Legacy single core lines: STM32H743/H753
  13. 2. Automatic STM32H7 flash algorithm selection
  14. 3. SVD file
  15. How to use:
  16. ==========
  17. * Before installing the files mentioned above, you need to have MDK-ARM v5.25
  18. or later installed.
  19. You can download pack from keil web site @ www.keil.com
  20. * Double Clic on  "Keil.STM32H7xx_DFP.2.2.1.pack" in order to install this pack in
  21. the Keil install directory.
  22. ******************* (C) COPYRIGHT 2019 STMicroelectronics *****END OF FILE***************
IAR:
EWARMv8_STM32H7xx_Support_V1.zip (435.5 KB, 下载次数: 40)
  4. * Description        : This file describes how to add STM32Hxx devices  support on EWARM
  6. Running the "EWARMv8_STM32H7xx_Support_V1.exe" adds the following:
  7.
  14. 3. SVD file
  15. How to use:
  16. ==========
  17. * Before installing the files mentioned above, you need to have EWARM v8.xx
  19. You can download EWARM from IAR web site @ www.iar.com
  20. * Run "EWARMv8_STM32H7xx_Support_V1.exe"  at EWARM install directory.
  21. EWARM Install Directory is set by default to "C:\Program Files\IAR Systems\Embedded Workbench ",
  22. please change it manually if you have EWARM installed at different location.
  23. ******************* (C) COPYRIGHT 2019 STMicroelectronics *****END OF FILE***************
  24.
发表于 2019-4-25 09:41:48 | 显示全部楼层
不知Segger embedded Studio会不会放出双核H7的支持包
 楼主| 发表于 2019-4-25 10:44:57 | 显示全部楼层
会有的。
发表于 2019-4-25 16:15:11 | 显示全部楼层
MDK官方已经有了
发表于 2019-4-25 16:20:55 | 显示全部楼层
双核好... 一个核放心的跑GUI
GMT+8, 2026-10-27 01:14 , Processed in 0.230700 second(s), 27 queries .
