查看: 4433|回复: 1
[DMA2D] STM32H7的DMA2D做Alpha混合和颜色混合比之前F429方便很多了
发表于 2019-4-22 03:13:07 | 显示全部楼层 |阅读模式
后实测下Alpha混合的性能。
  1. /**
  2.   * @brief  DMA2D Alpha blending bulk
  3.   * @param  pColorFG : Foregroung color
  4.   * @param  pColorBG : Backgroung color
  5.   * @param  pColorDst: Destination color
  6.   * @param  NumItems : Number of lines
  7.   * @retval None
  8.   */
  9. static void _DMA_AlphaBlendingBulk(LCD_COLOR * pColorFG, LCD_COLOR * pColorBG, LCD_COLOR * pColorDst, U32 NumItems)
  10. {
  11.   /* Wait if there is a transfer in progress */
  12.   _DMA2D_ExecOperation();
  13.
  14.   /* Take the TransferInProgress flag */
  15.   TransferInProgress = 1;
  16.
  17.   /* Setup DMA2D Configuration */
  18.   DMA2D->CR      = 0x00020000UL | (1 << 9);
  19.   DMA2D->FGMAR   = (U32)pColorFG;
  20.   DMA2D->BGMAR   = (U32)pColorBG;
  21.   DMA2D->OMAR    = (U32)pColorDst;
  22.   DMA2D->FGOR    = 0;
  23.   DMA2D->BGOR    = 0;
  24.   DMA2D->OOR     = 0;
  25.   DMA2D->FGPFCCR = LTDC_PIXEL_FORMAT_ARGB8888;
  26.   DMA2D->BGPFCCR = LTDC_PIXEL_FORMAT_ARGB8888;
  27.   DMA2D->OPFCCR  = LTDC_PIXEL_FORMAT_ARGB8888;
  28.   DMA2D->NLR     = (U32)(NumItems << 16) | 1;
  29.
  30.   /* Start the transfer, and enable the transfer complete IT */
  31.   DMA2D->CR     |= (1|DMA2D_IT_TC);
  32.
  33.   /* Wait for the end of the transfer */
  34.   _DMA2D_ExecOperation();
  35. }
  36. /**
  37.   * @brief  Mixing bulk colors
  38.   * @param  pColorFG : Foregroung color
  39.   * @param  pColorBG : Backgroung color
  40.   * @param  pColorDst: Destination color
  41.   * @param  Intens   : Color intensity
  42.   * @param  NumItems : Number of lines
  43.   * @retval None
  44.   */
  45. static void _DMA_MixColorsBulk(LCD_COLOR * pColorFG, LCD_COLOR * pColorBG, LCD_COLOR * pColorDst, U8 Intens, U32 NumItems)
  46. {
  47.   /* Wait if there is a transfer in progress */
  48.   _DMA2D_ExecOperation();
  49.
  50.   /* Take the TransferInProgress flag */
  51.   TransferInProgress = 1;
  52.   /* Setup DMA2D Configuration */
  53.   DMA2D->CR      = 0x00020000UL | (1 << 9);
  54.   DMA2D->FGMAR   = (U32)pColorFG;
  55.   DMA2D->BGMAR   = (U32)pColorBG;
  56.   DMA2D->OMAR    = (U32)pColorDst;
  57.   DMA2D->FGPFCCR = LTDC_PIXEL_FORMAT_ARGB8888
  58.                  | (1UL << 16)
  59.                  | ((U32)Intens << 24);
  60.   DMA2D->BGPFCCR = LTDC_PIXEL_FORMAT_ARGB8888
  61.                  | (0UL << 16)
  62.                  | ((U32)(255 - Intens) << 24);
  63.   DMA2D->OPFCCR  = LTDC_PIXEL_FORMAT_ARGB8888;
  64.   DMA2D->NLR     = (U32)(NumItems << 16) | 1;
  65.
  66.   /* Start the transfer, and enable the transfer complete IT */
  67.   DMA2D->CR     |= (1|DMA2D_IT_TC);
  68.   /* Wait for the end of the transfer */
  69.   _DMA2D_ExecOperation();
  70. }
发表于 2019-4-24 16:04:07 | 显示全部楼层
看来后续的 gui 界面很快就要出来了哟,期待中 ...
GMT+8, 2026-10-27 00:05 , Processed in 0.205486 second(s), 24 queries .
