查看: 5518|回复: 10
[emWin] 关于emWin下png图片显示运行出错的问题
发表于 2019-4-17 11:40:09 | 显示全部楼层 |阅读模式
我需要在屏幕创建了一个窗口,在窗口下创建TEXT控件显示一个动态的数字,为了避免刷新是闪烁,在主函数里添加代码:
但是添加了之后背景图片却显示不了(不添加上面函数图片显示正常),运行报错提示:
GUI_PNG.c:Error in _png_cexcept_errot().
详细代码如下:
#include "DIALOG.h"
#include "backgrond.h"
#define ID_WINDOW_0         (GUI_ID_USER + 0x00)
#define ID_IMAGE_0         (GUI_ID_USER + 0x01)
#define ID_TEXT_0         (GUI_ID_USER + 0x02)
#define ID_IMAGE_0_IMAGE_0       0x00
#define RECOMMENDED_MEMORY (1024L * 160)
  { WINDOW_CreateIndirect, "Window", ID_WINDOW_0, 0, 0, 800, 480, 0, 0x0, 0 },
  { IMAGE_CreateIndirect, "Image_png", ID_IMAGE_0, 0, 0, 800, 480, 0, 0, 0 },
   { TEXT_CreateIndirect, "Text1", ID_TEXT_0, 30, 198, 100, 41, 0, 0x64, 0 },
static const void * _GetImageById(U32 Id, U32 * pSize) {
  switch (Id) {
  case ID_IMAGE_0_IMAGE_0:
    *pSize = sizeof(_acBackgrond);
    return (const void *)_acBackgrond;
  return NULL;
  const void * pData;
  WM_HWIN      hItem;
  U32          FileSize;
  switch (pMsg->MsgId) {
  case WM_INIT_DIALOG:
      WINDOW_SetBkColor(pMsg->hWin, GUI_GRAY);
    // Initialization of 'Image_png'
    hItem = WM_GetDialogItem(pMsg->hWin, ID_IMAGE_0);
    pData = _GetImageById(ID_IMAGE_0_IMAGE_0, &FileSize);
    IMAGE_SetPNG(hItem, pData, FileSize);
    // Initialization of 'Text1'
    hItem = WM_GetDialogItem(pMsg->hWin, ID_TEXT_0);
    TEXT_SetFont(hItem, GUI_FONT_D32);
    TEXT_SetTextColor(hItem, GUI_MAKE_COLOR(0x00FFFFFF));
    TEXT_SetText(hItem, "00");
  default:
    WM_DefaultProc(pMsg);
// USER START (Optionally insert additional public code)
void MainTask(void) {
    WM_HWIN  hWin;
    WM_HWIN hText;
    char acText[3] = { 0 };
    int value=0;
    GUI_Init();
    if (GUI_ALLOC_GetNumFreeBytes() < RECOMMENDED_MEMORY) {
        GUI_ErrorOut("Not enough memory available.");
        return;
    hWin = GUI_CreateDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), _cbDialog, WM_HBKWIN, 0, 0);
    while (1) {
        GUI_Delay(10);
        sprintf(acText, "%2d", value++);
        hText = WM_GetDialogItem(hWin, ID_TEXT_0);
        TEXT_SetText(hText, acText);
// USER END
添加
错误提示:
不添加下行代码会出现闪烁,图片中看不出来
png_xx.zip
883.41 KB, 下载次数: 8
发表于 2019-4-17 11:45:15 | 显示全部楼层
是不是在模拟器上面测试的,将完整的模拟器程序压缩上传下,我试试。
 楼主| 发表于 2019-4-17 12:04:10 | 显示全部楼层
上面上传了附件
png_xx.zip你看看
发表于 2019-4-17 12:05:27 | 显示全部楼层
凡吹羽_xXQqf 发表于 2019-4-17 12:04
上面上传了附件
png_xx.zip你看看
这个看不出问题来,直接上完整模拟器程序,否则无法帮助你
 楼主| 发表于 2019-4-17 12:38:42 | 显示全部楼层
麻烦了,工程打包好附件已上传
SeggerEval_WIN32_MSVC_MinGW_GUI_V548.zip
8.29 MB, 下载次数: 9
发表于 2019-4-17 14:03:33 | 显示全部楼层
凡吹羽_xXQqf 发表于 2019-4-17 12:38
麻烦了,工程打包好附件已上传
你没有移植PNG的库,从5.3x版本开始,由于版权问题,emWin已经没有自带PNG库了。
 楼主| 发表于 2019-4-17 14:23:32 | 显示全部楼层
我把代码    WM_SetCreateFlags(WM_CF_MEMDEV);
注释掉就图片显示正常,应该不是png库的问题,把548的库加进去也还是一样
发表于 2019-4-17 15:05:19 | 显示全部楼层
帮你直接在我们V6板子上面测试了,没问题
发表于 2019-4-17 15:51:31 | 显示全部楼层
我用vc6帮你测试了下,你的例子是对的,WM_SetCreateFlags(WM_CF_MEMDEV);开不开都可以
 楼主| 发表于 2019-4-17 16:25:51 | 显示全部楼层
找到原因了,主要是因为在GUIConf.c文件中内存设置是默认的2M,打开WM_CF_MEMDEV 会消耗一些资源,把内存设置改大一点(比如改成5M #define GUI_NUMBYTES  0x500000)就行了
 楼主| 发表于 2019-4-17 16:26:58 | 显示全部楼层
嗯问题找到了,非常感谢
GMT+8, 2026-11-24 16:46 , Processed in 0.327976 second(s), 27 queries .
