查看: 3612|回复: 1
[HAL] HAL库BDMA多组通道统一命名
发表于 2019-1-26 10:25:31 | 显示全部楼层 |阅读模式
定义方式
typedef struct
  __IO uint32_t CCR; /*!< DMA channel x configuration register  Addr offset: 0x08 + 0x14 * x,x = 0 to 7 */
  __IO uint32_t CNDTR;/*!< DMA channel x number of data register Addr offset: 0x0C + 0x14 * x,x = 0 to 7 */
  __IO uint32_t CPAR; /*!< DMA channel x peripheral address register Addr offset: 0x10 + 0x14 * x, x = 0 to 7*/
  __IO uint32_t CMAR; /*!< DMA channel x memory address register, Addr offset: 0x14 + 0x14 * x, x = 0 to 7 */
} BDMA_Channel_TypeDef;
地址
#define BDMA_Channel0  ((BDMA_Channel_TypeDef *) BDMA_Channel0_BASE)
#define BDMA_Channel1  ((BDMA_Channel_TypeDef *) BDMA_Channel1_BASE)
#define BDMA_Channel2  ((BDMA_Channel_TypeDef *) BDMA_Channel2_BASE)
#define BDMA_Channel3  ((BDMA_Channel_TypeDef *) BDMA_Channel3_BASE)
#define BDMA_Channel4  ((BDMA_Channel_TypeDef *) BDMA_Channel4_BASE)
#define BDMA_Channel5  ((BDMA_Channel_TypeDef *) BDMA_Channel5_BASE)
#define BDMA_Channel6  ((BDMA_Channel_TypeDef *) BDMA_Channel6_BASE)
#define BDMA_Channel7  ((BDMA_Channel_TypeDef *) BDMA_Channel7_BASE)
发表于 2019-1-26 11:14:26 | 显示全部楼层
谢谢分享
GMT+8, 2026-10-27 00:01 , Processed in 0.125997 second(s), 24 queries .
