查看: 6820|回复: 7
[TIMER] 测试发现STM32H7的LPTIM1的中断可以唤醒停机模式,其它几个LPTIM2-5无法唤醒,邪门
发表于 2019-1-5 18:22:40 | 显示全部楼层 |阅读模式
对于LPTIM1,各种中断方式都可以唤醒停机模式,比如PWM中断,超时中断等(含软件触发和外部触发)。
而LPTIM2-LPTIM5的各种中断方式却都无法唤醒停机模式,但不做唤醒使用,也都正常,邪门了,看勘误手册也没有这种bug。
邪门,备份下这个问题吧。
停机模式下使用的LSE或者LSI为LPTIM提供时钟。
LPTIM1软件触发超时中断方式。
程序里面配置了8分频,4秒后唤醒。
  1. LPTIM_HandleTypeDef             LptimHandle = {0};
  2. void bsp_InitLPTIM2(void)
  3. {
  4.         GPIO_InitTypeDef   GPIO_InitStruct = {0};
  5.         RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  6.         /* ## - 1 - Enable LPTIM clock ############################################ */
  7.         __HAL_RCC_LPTIM1_CLK_ENABLE();
  8.         __HAL_RCC_LPTIM2_CLK_ENABLE();
  9.
  10.         __HAL_RCC_GPIOE_CLK_ENABLE();
  11.
  12.         GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
  13.         GPIO_InitStruct.Pull = GPIO_PULLUP;
  14.         GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
  15.         GPIO_InitStruct.Alternate = GPIO_AF1_LPTIM1;
  16.         GPIO_InitStruct.Pin = GPIO_PIN_0;
  17.         HAL_GPIO_Init(GPIOE, &GPIO_InitStruct);
  18.         RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_LSE;
  19.         RCC_OscInitStruct.LSEState = RCC_LSE_ON;
  20.         RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
  21.         if (HAL_RCC_OscConfig(&RCC_OscInitStruct)!= HAL_OK)
  22.         {
  23.         Error_Handler(__FILE__, __LINE__);
  24.         }
  25.         RCC_PeriphCLKInitStruct.PeriphClockSelection = RCC_PERIPHCLK_LPTIM1;
  26.         RCC_PeriphCLKInitStruct.Lptim1ClockSelection = RCC_LPTIM1CLKSOURCE_LSE;
  27.         HAL_RCCEx_PeriphCLKConfig(&RCC_PeriphCLKInitStruct);
  28.         /* ### - 2 - Initialize the LPTIM peripheral ############################## */
  29.         LptimHandle.Instance = LPTIM1;
  30.         LptimHandle.Init.Clock.Source    = LPTIM_CLOCKSOURCE_APBCLOCK_LPOSC;
  31.         LptimHandle.Init.Clock.Prescaler = LPTIM_PRESCALER_DIV8;
  32.         LptimHandle.Init.CounterSource   = LPTIM_COUNTERSOURCE_INTERNAL;
  33.         LptimHandle.Init.Trigger.Source  = LPTIM_TRIGSOURCE_SOFTWARE;
  34. //        LptimHandle.Init.Trigger.Source     = LPTIM_TRIGSOURCE_0;
  35. //        LptimHandle.Init.Trigger.ActiveEdge = LPTIM_ACTIVEEDGE_FALLING;
  36.         LptimHandle.Init.OutputPolarity  = LPTIM_OUTPUTPOLARITY_HIGH;
  37.         LptimHandle.Init.UpdateMode      = LPTIM_UPDATE_IMMEDIATE;
  38.         LptimHandle.Init.Input1Source    = LPTIM_INPUT1SOURCE_GPIO;
  39.         LptimHandle.Init.Input2Source    = LPTIM_INPUT2SOURCE_GPIO;
  40.         /* Initialize LPTIM peripheral according to the passed parameters */
  41.         if (HAL_LPTIM_Init(&LptimHandle) != HAL_OK)
  42.         {
  43.         Error_Handler(__FILE__, __LINE__);
  44.         }
  45.         /* Enable and set LPTIM Interrupt to the highest priority */
  46.         HAL_NVIC_SetPriority(LPTIM1_IRQn, 1, 0);
  47.         HAL_NVIC_EnableIRQ(LPTIM1_IRQn);
  48.
  49.         /* ### - 3 - Start counting in interrupt mode ############################# */
  50.         if (HAL_LPTIM_TimeOut_Start_IT(&LptimHandle, 32768, 32768/2) != HAL_OK)
  51.         {
  52.         Error_Handler(__FILE__, __LINE__);
  53.         }
  54.
  55. //        if (HAL_LPTIM_PWM_Start_IT(&LptimHandle, 32768, 32768/2) != HAL_OK)
  56. //         {
  57. //       Error_Handler(__FILE__, __LINE__);
  58. //         }
  59.
  60.         /* ### - 4 - Enter in Stop mode ########################################### */
  61.         HAL_PWR_EnterSTOPMode(PWR_LOWPOWERREGULATOR_ON, PWR_STOPENTRY_WFI);
  62.         SystemClock_Config();
  63. }
  64. void LPTIM1_IRQHandler(void)
  65. {
  66.         HAL_LPTIM_IRQHandler(&LptimHandle);
  67.         bsp_LedToggle(4);
  68. }
同样的配置LPTIM2却不行,其它的LPTIM345也不行。但注释掉进入停机模式函数执行却又正常,就是无法唤醒停机模式。
  1. void bsp_InitLPTIM2(void)
  2. {
  3.         GPIO_InitTypeDef   GPIO_InitStruct = {0};
  4.         RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  5.         /* ## - 1 - Enable LPTIM clock ############################################ */
  6.         __HAL_RCC_LPTIM1_CLK_ENABLE();
  7.         __HAL_RCC_LPTIM2_CLK_ENABLE();
  8.
  9. //        __HAL_RCC_GPIOE_CLK_ENABLE();
  10.
  11. //        GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
  12. //        GPIO_InitStruct.Pull = GPIO_PULLUP;
  13. //        GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
  14. //        GPIO_InitStruct.Alternate = GPIO_AF1_LPTIM1;
  15. //        GPIO_InitStruct.Pin = GPIO_PIN_0;
  16. //        HAL_GPIO_Init(GPIOE, &GPIO_InitStruct);
  17.         RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_LSE;
  18.         RCC_OscInitStruct.LSEState = RCC_LSE_ON;
  19.         RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
  20.         if (HAL_RCC_OscConfig(&RCC_OscInitStruct)!= HAL_OK)
  21.         {
  22.         Error_Handler(__FILE__, __LINE__);
  23.         }
  24.         RCC_PeriphCLKInitStruct.PeriphClockSelection = RCC_PERIPHCLK_LPTIM2;
  25.         RCC_PeriphCLKInitStruct.Lptim2ClockSelection = RCC_LPTIM2CLKSOURCE_LSE;
  26.         HAL_RCCEx_PeriphCLKConfig(&RCC_PeriphCLKInitStruct);
  27.         /* ### - 2 - Initialize the LPTIM peripheral ############################## */
  28.         LptimHandle.Instance = LPTIM2;
  29.         LptimHandle.Init.Clock.Source    = LPTIM_CLOCKSOURCE_APBCLOCK_LPOSC;
  30.         LptimHandle.Init.Clock.Prescaler = LPTIM_PRESCALER_DIV8;
  31.         LptimHandle.Init.CounterSource   = LPTIM_COUNTERSOURCE_INTERNAL;
  32.         LptimHandle.Init.Trigger.Source  = LPTIM_TRIGSOURCE_SOFTWARE;
  33. //        LptimHandle.Init.Trigger.Source     = LPTIM_TRIGSOURCE_0;
  34. //        LptimHandle.Init.Trigger.ActiveEdge = LPTIM_ACTIVEEDGE_FALLING;
  35.         LptimHandle.Init.OutputPolarity  = LPTIM_OUTPUTPOLARITY_HIGH;
  36.         LptimHandle.Init.UpdateMode      = LPTIM_UPDATE_IMMEDIATE;
  37.         LptimHandle.Init.Input1Source    = LPTIM_INPUT1SOURCE_GPIO;
  38.         LptimHandle.Init.Input2Source    = LPTIM_INPUT2SOURCE_GPIO;
  39.         /* Initialize LPTIM peripheral according to the passed parameters */
  40.         if (HAL_LPTIM_Init(&LptimHandle) != HAL_OK)
  41.         {
  42.         Error_Handler(__FILE__, __LINE__);
  43.         }
  44.         /* Enable and set LPTIM Interrupt to the highest priority */
  45.         HAL_NVIC_SetPriority(LPTIM2_IRQn, 1, 0);
  46.         HAL_NVIC_EnableIRQ(LPTIM2_IRQn);
  47.
  48.         /* ### - 3 - Start counting in interrupt mode ############################# */
  49.         if (HAL_LPTIM_TimeOut_Start_IT(&LptimHandle, 32768, 32768/2) != HAL_OK)
  50.         {
  51.         Error_Handler(__FILE__, __LINE__);
  52.         }
  53.
  54. //        if (HAL_LPTIM_PWM_Start_IT(&LptimHandle, 32768, 32768/2) != HAL_OK)
  55. //         {
  56. //       Error_Handler(__FILE__, __LINE__);
  57. //         }
  58.
  59.         /* ### - 4 - Enter in Stop mode ########################################### */
  60.         HAL_PWR_EnterSTOPMode(PWR_LOWPOWERREGULATOR_ON, PWR_STOPENTRY_WFI);
  61.         SystemClock_Config();
  62. }
  63. void LPTIM2_IRQHandler(void)
  64. {
  65.         HAL_LPTIM_IRQHandler(&LptimHandle);
  66.         bsp_LedToggle(4);
  67. }
 楼主| 发表于 2019-1-7 01:21:51 | 显示全部楼层
根据手册,其它定时器也是有唤醒触发功能的,但就是不起作用
发表于 2020-3-30 17:38:35 | 显示全部楼层
勘误手册更新了,不知道有没有说明。
 楼主| 发表于 2020-3-30 17:56:57 | 显示全部楼层
王海靖 发表于 2020-3-30 17:38
勘误手册更新了,不知道有没有说明。
还没有使用新版的库测试过,后面了试试
 楼主| 发表于 2020-3-31 11:01:23 | 显示全部楼层
勘误手册更新了,不知道有没有说明。
今天看了下勘误手册,还真是个bug
发表于 2020-3-31 13:17:55 | 显示全部楼层
eric2013 发表于 2020-3-31 11:01
今天看了下勘误手册,还真是个bug
下一版用户手册 可以加上了
发表于 2024-9-18 23:04:59 | 显示全部楼层
update event能触发唤醒中断吗?不是timeout方式,就和普通的定时器一样,定时到了产生中断,不使用cc1比较值
 楼主| 发表于 2024-9-19 09:34:59 | 显示全部楼层
AquilaRift 发表于 2024-9-18 23:04
update event能触发唤醒中断吗?不是timeout方式,就和普通的定时器一样,定时到了产生中断,不使用cc1比较 ...
LPTIM1都正常,其他定时器不正常。
后面没有再测试研究了。
GMT+8, 2026-10-24 23:53 , Processed in 1.169716 second(s), 27 queries .
