查看: 3647|回复: 0
[TIMER] STM32H7的低功耗定时器用于低功耗方向的研究(2018-12-29)
发表于 2018-12-29 11:11:18 | 显示全部楼层 |阅读模式
整理中
System Clock source            = PLL (HSE BYPASS)
SYSCLK(Hz)                     = 400000000 (CPU Clock)
HCLK(Hz)                       = 200000000 (AXI and AHBs Clock)
AHB Prescaler                  = 2
D1 APB3 Prescaler              = 2 (APB3 Clock  100MHz)
D2 APB1 Prescaler              = 2 (APB1 Clock  100MHz)
D2 APB2 Prescaler              = 2 (APB2 Clock  100MHz)
D3 APB4 Prescaler              = 2 (APB4 Clock  100MHz)
    因为APB1 prescaler != 1, 所以 APB1上的TIMxCLK = APB1 x 2 = 200MHz;
    因为APB2 prescaler != 1, 所以 APB2上的TIMxCLK = APB2 x 2  =  200MHz;
    APB4上面的TIMxCLK没有分频,所以就是100MHz;
    APB1 定时器有 TIM2, TIM3 ,TIM4, TIM5, TIM6, TIM7, TIM12, TIM13, TIM14,LPTIM1
    APB2 定时器有 TIM1, TIM8 , TIM15, TIM16,TIM17
    APB4 定时器有 LPTIM2,LPTIM3,LPTIM4,LPTIM5
默认情况下LPTIM用的是APB时钟
  1. /** @defgroup RCCEx_LPTIM1_Clock_Source  RCCEx LPTIM1 Clock Source
  2.   * @{
  3.   */
  4. #define RCC_LPTIM1CLKSOURCE_D2PCLK1        ((uint32_t)0x00000000)
  5. #define RCC_LPTIM1CLKSOURCE_PLL2          RCC_D2CCIP2R_LPTIM1SEL_0
  6. #define RCC_LPTIM1CLKSOURCE_PLL3          RCC_D2CCIP2R_LPTIM1SEL_1
  7. #define RCC_LPTIM1CLKSOURCE_LSE           (RCC_D2CCIP2R_LPTIM1SEL_0 | RCC_D2CCIP2R_LPTIM1SEL_1)
  8. #define RCC_LPTIM1CLKSOURCE_LSI            RCC_D2CCIP2R_LPTIM1SEL_2
  9. #define RCC_LPTIM1CLKSOURCE_CLKP          (RCC_D2CCIP2R_LPTIM1SEL_0 | RCC_D2CCIP2R_LPTIM1SEL_2)
  10. /**
  11.   * @}
  12.   */
  13. /** @defgroup RCCEx_LPTIM2_Clock_Source  RCCEx LPTIM2 Clock Source
  14.   * @{
  15.   */
  16. #define RCC_LPTIM2CLKSOURCE_D3PCLK1        ((uint32_t)0x00000000)
  17. #define RCC_LPTIM2CLKSOURCE_PLL2          RCC_D3CCIPR_LPTIM2SEL_0
  18. #define RCC_LPTIM2CLKSOURCE_PLL3          RCC_D3CCIPR_LPTIM2SEL_1
  19. #define RCC_LPTIM2CLKSOURCE_LSE           (RCC_D3CCIPR_LPTIM2SEL_0 | RCC_D3CCIPR_LPTIM2SEL_1)
  20. #define RCC_LPTIM2CLKSOURCE_LSI            RCC_D3CCIPR_LPTIM2SEL_2
  21. #define RCC_LPTIM2CLKSOURCE_CLKP          (RCC_D3CCIPR_LPTIM2SEL_0 | RCC_D3CCIPR_LPTIM2SEL_2)
  22. /**
  23.   * @}
  24.   */
  25. /** @defgroup RCCEx_LPTIM345_Clock_Source  RCCEx LPTIM3/4/5 Clock Source
  26.   * @{
  27.   */
  28. #define RCC_LPTIM345CLKSOURCE_D3PCLK1        ((uint32_t)0x00000000)
  29. #define RCC_LPTIM345CLKSOURCE_PLL2          RCC_D3CCIPR_LPTIM345SEL_0
  30. #define RCC_LPTIM345CLKSOURCE_PLL3          RCC_D3CCIPR_LPTIM345SEL_1
  31. #define RCC_LPTIM345CLKSOURCE_LSE           (RCC_D3CCIPR_LPTIM345SEL_0 | RCC_D3CCIPR_LPTIM345SEL_1)
  32. #define RCC_LPTIM345CLKSOURCE_LSI            RCC_D3CCIPR_LPTIM345SEL_2
  33. #define RCC_LPTIM345CLKSOURCE_CLKP          (RCC_D3CCIPR_LPTIM345SEL_0 | RCC_D3CCIPR_LPTIM345SEL_2)
  34. /**
  35.   * @}
  36.   */
  37. /** @defgroup RCCEx_LPTIM3_Clock_Source  RCCEx LPTIM3 Clock Source
  38.   * @{
  39.   */
  40. #define RCC_LPTIM3CLKSOURCE_D3PCLK1       RCC_LPTIM345CLKSOURCE_D3PCLK1
  41. #define RCC_LPTIM3CLKSOURCE_PLL2          RCC_LPTIM345CLKSOURCE_PLL2
  42. #define RCC_LPTIM3CLKSOURCE_PLL3          RCC_LPTIM345CLKSOURCE_PLL3
  43. #define RCC_LPTIM3CLKSOURCE_LSE           RCC_LPTIM345CLKSOURCE_LSE
  44. #define RCC_LPTIM3CLKSOURCE_LSI           RCC_LPTIM345CLKSOURCE_LSI
  45. #define RCC_LPTIM3CLKSOURCE_CLKP          RCC_LPTIM345CLKSOURCE_CLKP
  46. /**
  47.   * @}
  48.   */
  49. /** @defgroup RCCEx_LPTIM4_Clock_Source  RCCEx LPTIM4 Clock Source
  50.   * @{
  51.   */
  52. #define RCC_LPTIM4CLKSOURCE_D3PCLK1       RCC_LPTIM345CLKSOURCE_D3PCLK1
  53. #define RCC_LPTIM4CLKSOURCE_PLL2          RCC_LPTIM345CLKSOURCE_PLL2
  54. #define RCC_LPTIM4CLKSOURCE_PLL3          RCC_LPTIM345CLKSOURCE_PLL3
  55. #define RCC_LPTIM4CLKSOURCE_LSE           RCC_LPTIM345CLKSOURCE_LSE
  56. #define RCC_LPTIM4CLKSOURCE_LSI           RCC_LPTIM345CLKSOURCE_LSI
  57. #define RCC_LPTIM4CLKSOURCE_CLKP          RCC_LPTIM345CLKSOURCE_CLKP
  58. /**
  59.   * @}
  60.   */
  61. /** @defgroup RCCEx_LPTIM5_Clock_Source  RCCEx LPTIM5 Clock Source
  62.   * @{
  63.   */
  64. #define RCC_LPTIM5CLKSOURCE_D3PCLK1       RCC_LPTIM345CLKSOURCE_D3PCLK1
  65. #define RCC_LPTIM5CLKSOURCE_PLL2          RCC_LPTIM345CLKSOURCE_PLL2
  66. #define RCC_LPTIM5CLKSOURCE_PLL3          RCC_LPTIM345CLKSOURCE_PLL3
  67. #define RCC_LPTIM5CLKSOURCE_LSE           RCC_LPTIM345CLKSOURCE_LSE
  68. #define RCC_LPTIM5CLKSOURCE_LSI           RCC_LPTIM345CLKSOURCE_LSI
  69. #define RCC_LPTIM5CLKSOURCE_CLKP          RCC_LPTIM345CLKSOURCE_CLKP
上面时钟源里面CLKP是指的
GMT+8, 2026-10-27 02:17 , Processed in 0.220917 second(s), 27 queries .
