查看: 3320|回复: 4
[emWin] 复选框控件设置为禁用后还可以聚焦?
发表于 2018-12-25 10:55:19 | 显示全部楼层 |阅读模式
在模拟器上试的结果复选框控件设置为禁用后不能在聚焦,但是在我的板子上复选框控件设置为禁用后还可以聚焦,板子上使用的是emwin5.22版本。什么模拟器上的结果和实际的显示结果不一样呢?,我把程序附在后面了,是不是我使用的有问题呀?
*                SEGGER Microcontroller GmbH & Co. KG                *
*        Solutions for real time microcontroller applications        *
* C-file generated by:                                               *
*        GUI_Builder for emWin version 5.22                          *
*        Compiled Jul  4 2013, 15:16:01                              *
*        (c) 2013 Segger Microcontroller GmbH & Co. KG               *
*        Internet: www.segger.com  Support: support@segger.com       *
// USER START (Optionally insert additional includes)
// USER END
#include "DIALOG.h"
*       Defines
#define ID_FRAMEWIN_0    (GUI_ID_USER + 0x00)
#define ID_CHECKBOX_0    (GUI_ID_USER + 0x01)
#define ID_CHECKBOX_1    (GUI_ID_USER + 0x02)
#define ID_CHECKBOX_2    (GUI_ID_USER + 0x03)
#define ID_CHECKBOX_3    (GUI_ID_USER + 0x04)
#define ID_CHECKBOX_4    (GUI_ID_USER + 0x05)
#define ID_CHECKBOX_5    (GUI_ID_USER + 0x06)
#define ID_BUTTON_0    (GUI_ID_USER + 0x07)
// USER START (Optionally insert additional defines)
// USER END
*       Static data
WM_HWIN CreateFramewin_Test(void);
// USER START (Optionally insert additional static data)
// USER END
*       _aDialogCreate
    { FRAMEWIN_CreateIndirect, "Framewin", ID_FRAMEWIN_0, 62, 60, 360, 160, 0, 0x64, 0 },
    { CHECKBOX_CreateIndirect, "Checkbox", ID_CHECKBOX_0, 60, 30, 80, 20, 0, 0x0, 0 },
    { CHECKBOX_CreateIndirect, "Checkbox", ID_CHECKBOX_1, 150, 30, 80, 20, 0, 0x0, 0 },
    { CHECKBOX_CreateIndirect, "Checkbox", ID_CHECKBOX_2, 240, 30, 80, 20, 0, 0x0, 0 },
    { CHECKBOX_CreateIndirect, "Checkbox", ID_CHECKBOX_3, 60, 80, 80, 20, 0, 0x0, 0 },
    { CHECKBOX_CreateIndirect, "Checkbox", ID_CHECKBOX_4, 150, 80, 80, 20, 0, 0x0, 0 },
    { CHECKBOX_CreateIndirect, "Checkbox", ID_CHECKBOX_5, 240, 80, 80, 20, 0, 0x0, 0 },
    { BUTTON_CreateIndirect, "Button", ID_BUTTON_0, 126, 113, 80, 20, 0, 0x0, 0 },
    // USER START (Optionally insert additional widgets)
    // USER END
*       Static code
// USER START (Optionally insert additional static code)
// USER END
*       _cbDialog
    WM_HWIN hItem;
    int     NCode;
    int     Id;
    // USER END
    switch (pMsg->MsgId) {
    case WM_KEY:
        WM_KEY_INFO* pData = (WM_KEY_INFO*)(pMsg->Data.p);        //获得消息结构体中的按键消息
        switch (pData->Key)
        case GUI_KEY_ESCAPE:                //按下ESCAPE键进入主菜单界面
            WM_DeleteWindow(pMsg->hWin);                //删除窗口
        case GUI_KEY_DOWN://对下一个控件聚焦
            WM_SetFocusOnNextChild(WM_GetClientWindow(pMsg->hWin));        //由于使用了框架窗口控件,必须先要获得客户端窗口句柄,才能进行焦点切换
            break;        //因为控件的父窗口是客户端窗口,而框架窗口是客户端窗口的父窗口
        case GUI_KEY_UP://对上一个控件聚焦
            WM_SetFocusOnPrevChild(WM_GetClientWindow(pMsg->hWin));
    case WM_INIT_DIALOG:
        // Initialization of 'Framewin'
        hItem = pMsg->hWin;
        FRAMEWIN_SetFont(hItem, GUI_FONT_16B_1);
        FRAMEWIN_SetText(hItem, "Framewin");
        FRAMEWIN_SetTextAlign(hItem, GUI_TA_HCENTER | GUI_TA_VCENTER);
        // Initialization of 'Checkbox'
        hItem = WM_GetDialogItem(pMsg->hWin, ID_CHECKBOX_0);
        CHECKBOX_SetText(hItem, "Check");
        hItem = WM_GetDialogItem(pMsg->hWin, ID_CHECKBOX_1);
        hItem = WM_GetDialogItem(pMsg->hWin, ID_CHECKBOX_2);
        hItem = WM_GetDialogItem(pMsg->hWin, ID_CHECKBOX_3);
        hItem = WM_GetDialogItem(pMsg->hWin, ID_CHECKBOX_4);
        hItem = WM_GetDialogItem(pMsg->hWin, ID_CHECKBOX_5);
        WM_DisableWindow(WM_GetDialogItem(pMsg->hWin, ID_CHECKBOX_3));//指定窗口设置为禁用状态
        WM_DisableWindow(WM_GetDialogItem(pMsg->hWin, ID_CHECKBOX_4));//指定窗口设置为禁用状态
        WM_DisableWindow(WM_GetDialogItem(pMsg->hWin, ID_CHECKBOX_5));//指定窗口设置为禁用状态
        // USER START (Optionally insert additional code for further widget initialization)
        // USER END
    case WM_NOTIFY_PARENT:
        NCode = pMsg->Data.v;
        switch(Id) {
        case ID_CHECKBOX_0: // Notifications sent by 'Checkbox'
            switch(NCode) {
            case WM_NOTIFICATION_CLICKED:
                // USER END
                // USER END
            case WM_NOTIFICATION_VALUE_CHANGED:
                // USER END
                // USER END
        case ID_CHECKBOX_1: // Notifications sent by 'Checkbox'
            switch(NCode) {
                // USER END
                // USER END
                // USER END
                // USER END
        case ID_CHECKBOX_2: // Notifications sent by 'Checkbox'
            switch(NCode) {
                // USER END
                // USER END
                // USER END
                // USER END
        case ID_CHECKBOX_3: // Notifications sent by 'Checkbox'
            switch(NCode) {
                // USER END
                // USER END
                // USER END
                // USER END
        case ID_CHECKBOX_4: // Notifications sent by 'Checkbox'
            switch(NCode) {
                // USER END
                // USER END
                // USER END
                // USER END
        case ID_CHECKBOX_5: // Notifications sent by 'Checkbox'
            switch(NCode) {
                // USER END
                // USER END
                // USER END
                // USER END
        case ID_BUTTON_0: // Notifications sent by 'Button'
            switch(NCode) {
//                WM_DeleteWindow(pMsg->hWin);                //删除窗口
                GUI_EndDialog(pMsg->hWin, 0);
                // USER END
                // USER END
            // USER START (Optionally insert additional code for further Ids)
            // USER END
    // USER START (Optionally insert additional message handling)
    // USER END
    default:
        WM_DefaultProc(pMsg);
*       Public code
*       CreateFramewin
WM_HWIN CreateFramewin_Test(void) {
    WM_HWIN hWin;
    hWin = GUI_CreateDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), _cbDialog, WM_HBKWIN, 0, 0);
    return hWin;
// USER START (Optionally insert additional public code)
// USER END
发表于 2018-12-25 11:19:01 | 显示全部楼层
使用5.40及其以上版本里面的WIDGET_SetFocusable可以解决此问题
 楼主| 发表于 2018-12-25 20:18:39 | 显示全部楼层
好的,还想问一下上面程序中函数使用方法正确吗?
发表于 2018-12-26 10:46:39 | 显示全部楼层
以你实际测试为准,如果测试不行,就是不可以。
 楼主| 发表于 2018-12-27 14:33:03 | 显示全部楼层
好的,谢谢你
GMT+8, 2026-11-23 14:50 , Processed in 0.668058 second(s), 24 queries .
