查看: 5385|回复: 1
[有问必答] CUBEMX F41.2.3 CAN 配置问题
发表于 2018-12-11 22:16:38 | 显示全部楼层 |阅读模式
....请教个问题,用HAL库(F4V1.2.3)配置CAN,总是在HAL_CAN_Init中  hcan->State = HAL_CAN_STATE_ERROR;初始一直失败
while ((hcan->Instance->MSR & CAN_MSR_INAK) != RESET)
      /* Check for the Timeout */
      if ((HAL_GetTick() - tickstart) > CAN_TIMEOUT_VALUE)
        /* Update error code */
        hcan->ErrorCode |= HAL_CAN_ERROR_TIMEOUT;
        /* Change CAN state */
        return HAL_ERROR;
请问怎么解决
void MX_CAN1_Init(void)
        hcan1.Instance = CAN1;
        hcan1.Init.Prescaler = 14;
        hcan1.Init.Mode = CAN_MODE_NORMAL;
        hcan1.Init.SyncJumpWidth = CAN_SJW_1TQ;
        hcan1.Init.TimeSeg1 = CAN_BS1_6TQ;
        hcan1.Init.TimeSeg2 = CAN_BS2_5TQ;
        hcan1.Init.TimeTriggeredMode = DISABLE;
        hcan1.Init.AutoBusOff = DISABLE;
        hcan1.Init.AutoWakeUp = DISABLE;
        hcan1.Init.AutoRetransmission = DISABLE;
        hcan1.Init.ReceiveFifoLocked = DISABLE;
        hcan1.Init.TransmitFifoPriority = DISABLE;
        if (HAL_CAN_Init(&hcan1) != HAL_OK)
                Error_Handler();
        CanFilter();
        /*##-3- Start the CAN peripheral ###########################################*/
        if (HAL_CAN_Start(&hcan1) != HAL_OK)
                /* Start Error */
                Error_Handler();
        /*##-4- Activate CAN RX notification #######################################*/
        if (HAL_CAN_ActivateNotification(&hcan1, CAN_IT_RX_FIFO0_MSG_PENDING) != HAL_OK)
                /* Notification Error */
                Error_Handler();
发表于 2018-12-12 00:26:57 | 显示全部楼层
帮顶,没整过F4的HAL。
GMT+8, 2026-11-28 15:55 , Processed in 0.853320 second(s), 24 queries .
