查看: 4770|回复: 6
[emWin] 模拟器仿真又出问题了
发表于 2015-5-15 12:59:23 | 显示全部楼层 |阅读模式
又来向大神讨教了,在模拟器运行emwin时出现了如下情况,请问如何解决?再者什么原因?
发表于 2015-5-15 16:49:21 | 显示全部楼层
这个是你调用错误,方便的话,贴出部分代码看下。
 楼主| 发表于 2015-5-17 20:33:33 | 显示全部楼层
eric2013:
//设置界面、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、
static const GUI_WIDGET_CREATE_INFO _aDialogSetting[] = {
    { FRAMEWIN_CreateIndirect,  " ",           0,                       0,  0,  800,600,FRAMEWIN_CF_ACTIVE,0},
    { TEXT_CreateIndirect,      "10:32:36",          GUI_ID_TEXT3,            644,24, 111,46, 0,0},
    { BUTTON_CreateIndirect,    NULL,                BUTTON_ID_0,          655,140,128,53, 0,0},
    { BUTTON_CreateIndirect,    NULL,                BUTTON_ID_1,          655,235,128,53, 0,0},
    { BUTTON_CreateIndirect,    NULL,                BUTTON_ID_2,          655,330,128,53, 0,0},
    { BUTTON_CreateIndirect,    NULL,                BUTTON_ID_3,          655,425,128,53, 0,0},
    { BUTTON_CreateIndirect,    NULL,                BUTTON_ID_4,          655,520,128,53, 0,0},
    { BUTTON_CreateIndirect,    "探 头 个 数",           BUTTON_ID_5,          60, 239,210,70, 0,0},
    { BUTTON_CreateIndirect,    "报 警 设 置",           BUTTON_ID_6,          356,239,210,70, 0,0},
    { BUTTON_CreateIndirect,    "IP 地 址 ",            BUTTON_ID_7,          60, 369,210,70, 0,0},
    { BUTTON_CreateIndirect,    "时 间 设 置",           BUTTON_ID_8,          357,369,210,70, 0,0}
void PaintDialog2(WM_MESSAGE * pMsg)
    WM_HWIN hWin = pMsg->hWin;
    GUI_SetColor(0xe16941);
    GUI_FillRect(0,0,799,99);
    GUI_FillRect(650,101,799,599);
    GUI_DrawBitmap(&bmLOGO2,10,30);
void InitDialog2(WM_MESSAGE * pMsg)
    //FRAMEWIN
    FRAMEWIN_SetClientColor(hWin,0xffffff);
    FRAMEWIN_SetTitleVis(hWin,0);
    _CreatText(hWin, "",  GUI_ID_TEXT0,  215,26, 440,65,TEXT_ID_HITETL);
    switch(Language)
    case 0:
        BUTTON_SetText      (WM_GetDialogItem(hWin,BUTTON_ID_0),  GetLang(TEXT_ID_MEASURE));
        BUTTON_SetFont      (WM_GetDialogItem(hWin,BUTTON_ID_0),   &GUI_FontHZ_NewSimSun_35);
        BUTTON_SetBkColor(WM_GetDialogItem(hWin,BUTTON_ID_0),BUTTON_CI_UNPRESSED,0xe16941);
        BUTTON_SetText      (WM_GetDialogItem(hWin,BUTTON_ID_1),   GetLang(TEXT_ID_SET));
        BUTTON_SetFont      (WM_GetDialogItem(hWin,BUTTON_ID_1),   &GUI_FontHZ_NewSimSun_35);
        BUTTON_SetBkColor(WM_GetDialogItem(hWin,BUTTON_ID_1),BUTTON_CI_UNPRESSED,0xe16941);
        BUTTON_SetText      (WM_GetDialogItem(hWin,BUTTON_ID_2),  GetLang(TEXT_ID_SCAN));
        BUTTON_SetFont      (WM_GetDialogItem(hWin,BUTTON_ID_2),   &GUI_FontHZ_NewSimSun_35);
        BUTTON_SetBkColor(WM_GetDialogItem(hWin,BUTTON_ID_2),BUTTON_CI_UNPRESSED,0xe16941);
        BUTTON_SetText      (WM_GetDialogItem(hWin,BUTTON_ID_3),   GetLang(TEXT_ID_PAGEON));
        BUTTON_SetFont      (WM_GetDialogItem(hWin,BUTTON_ID_3),   &GUI_FontHZ_NewSimSun_35);
        BUTTON_SetBkColor(WM_GetDialogItem(hWin,BUTTON_ID_3),BUTTON_CI_UNPRESSED,0xe16941);
        BUTTON_SetText      (WM_GetDialogItem(hWin,BUTTON_ID_4),   GetLang(TEXT_ID_PANGEDOWN));
        BUTTON_SetFont      (WM_GetDialogItem(hWin,BUTTON_ID_4),   &GUI_FontHZ_NewSimSun_35);
        BUTTON_SetBkColor(WM_GetDialogItem(hWin,BUTTON_ID_4),BUTTON_CI_UNPRESSED,0xe16941);
        BUTTON_SetText      (WM_GetDialogItem(hWin,BUTTON_ID_5),  GetLang(TEXT_ID_Snumber));
        BUTTON_SetFont      (WM_GetDialogItem(hWin,BUTTON_ID_5),   &GUI_FontHZ_NewSimSun_35);
        BUTTON_SetBkColor(WM_GetDialogItem(hWin,BUTTON_ID_5),BUTTON_CI_UNPRESSED,0xe16941);
        BUTTON_SetText      (WM_GetDialogItem(hWin,BUTTON_ID_6),   GetLang(TEXT_ID_Salarm));
        BUTTON_SetFont      (WM_GetDialogItem(hWin,BUTTON_ID_6),   &GUI_FontHZ_NewSimSun_35);
        BUTTON_SetBkColor(WM_GetDialogItem(hWin,BUTTON_ID_6),BUTTON_CI_UNPRESSED,0xe16941);
        BUTTON_SetText      (WM_GetDialogItem(hWin,BUTTON_ID_7),  GetLang(TEXT_ID_SIP));
        BUTTON_SetFont      (WM_GetDialogItem(hWin,BUTTON_ID_7),   &GUI_FontHZ_NewSimSun_35);
        BUTTON_SetBkColor(WM_GetDialogItem(hWin,BUTTON_ID_7),BUTTON_CI_UNPRESSED,0xe16941);
        BUTTON_SetText      (WM_GetDialogItem(hWin,BUTTON_ID_8),   GetLang(TEXT_ID_Stime));
        BUTTON_SetFont      (WM_GetDialogItem(hWin,BUTTON_ID_8),   &GUI_FontHZ_NewSimSun_35);
        BUTTON_SetBkColor(WM_GetDialogItem(hWin,BUTTON_ID_8),BUTTON_CI_UNPRESSED,0xe16941);
        BUTTON_SetText      (WM_GetDialogItem(hWin,BUTTON_ID_9),   GetLang(TEXT_ID_PAGEON));
        BUTTON_SetFont      (WM_GetDialogItem(hWin,BUTTON_ID_9),   &GUI_FontHZ_NewSimSun_35);
        BUTTON_SetBkColor(WM_GetDialogItem(hWin,BUTTON_ID_9),BUTTON_CI_UNPRESSED,0xe16941);
    case 1:
        BUTTON_SetFont      (WM_GetDialogItem(hWin,BUTTON_ID_0),   &GUI_Font32B_ASCII);
        BUTTON_SetFont      (WM_GetDialogItem(hWin,BUTTON_ID_1),   &GUI_Font32B_ASCII);
        BUTTON_SetFont      (WM_GetDialogItem(hWin,BUTTON_ID_2),   &GUI_Font32B_ASCII);
        BUTTON_SetFont      (WM_GetDialogItem(hWin,BUTTON_ID_3),   &GUI_Font32B_ASCII);
        BUTTON_SetFont      (WM_GetDialogItem(hWin,BUTTON_ID_4),   &GUI_Font32B_ASCII);
        BUTTON_SetFont      (WM_GetDialogItem(hWin,BUTTON_ID_5),   &GUI_Font32B_ASCII);
        BUTTON_SetFont      (WM_GetDialogItem(hWin,BUTTON_ID_6),   &GUI_Font32B_ASCII);
        BUTTON_SetFont      (WM_GetDialogItem(hWin,BUTTON_ID_7),   &GUI_Font32B_ASCII);
        BUTTON_SetFont      (WM_GetDialogItem(hWin,BUTTON_ID_8),   &GUI_Font32B_ASCII);
        BUTTON_SetFont      (WM_GetDialogItem(hWin,BUTTON_ID_9),   &GUI_Font32B_ASCII);
*       Dialog callback routine
static void _cbSetting(WM_MESSAGE * pMsg)
    int NCode, Id;
    switch (pMsg->MsgId)
        case WM_DELETE:
             SettingState=0;
        case WM_PAINT:
            PaintDialog2(pMsg);
        case WM_INIT_DIALOG:
            InitDialog2(pMsg);
        case WM_KEY:
            switch (((WM_KEY_INFO*)(pMsg->Data.p))->Key)
                case GUI_KEY_ESCAPE:
                    GUI_EndDialog(hWin, 1);
                case GUI_KEY_ENTER:
                    GUI_EndDialog(hWin, 0);
        case WM_NOTIFY_PARENT:
            Id = WM_GetId(pMsg->hWinSrc);
            NCode = pMsg->Data.v;
            switch (Id)
                case GUI_ID_OK:
                    if(NCode==WM_NOTIFICATION_RELEASED)
                case GUI_ID_CANCEL:
                case BUTTON_ID_0:
                            MeasureState=1;
                            OpenMeasure();
                case  BUTTON_ID_1:
                case BUTTON_ID_2:
                case  BUTTON_ID_3:
                case BUTTON_ID_4:
                case  BUTTON_ID_5:           //探头个数设置
                            MeasureState=1;
                            OPenSetNum();
                case BUTTON_ID_6:
                            WarnState=1;
                            OpenSetwarn();
                case BUTTON_ID_7:         //IP设置
                        IPState=1;
                        OpenSetIP();
        default:
            WM_DefaultProc(pMsg);
void OpenSetting(void)
    WM_HWIN Setting;
    SettingState=1;
     Setting = GUI_ExecDialogBox(_aDialogSetting, GUI_COUNTOF(_aDialogSetting), &_cbSetting, 0, 0, 0);//非阻塞式,否则定时器建立不成功
    while(SettingState)
         GUI_Delay(50);
//传感器个数设置、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、、
static const GUI_WIDGET_CREATE_INFO _aDialogCreateS1[] = {
    { FRAMEWIN_CreateIndirect,  "Caption",           0,                       0,  0,  800,600,FRAMEWIN_CF_ACTIVE,0},
    { TEXT_CreateIndirect,      "10:32:36",          GUI_ID_TEXT1,            647,13, 111,46, 0,0},
    //{ TEXT_CreateIndirect,       NULL,               GUI_ID_TEXT2,            19, 229,290,86, 0,0},
    { EDIT_CreateIndirect,       NULL,               GUI_EDIT_ID_0,            288,242,134,68, 0,0},
    { BUTTON_CreateIndirect,    "1",                 GUI_ID_BUTTON5,          12, 358,151,75, 0,0},
    { BUTTON_CreateIndirect,    "2",                 GUI_ID_BUTTON6,          169,358,151,75, 0,0},
    { BUTTON_CreateIndirect,    "3",                 GUI_ID_BUTTON7,          326,358,151,75, 0,0},
    { BUTTON_CreateIndirect,    "DEL",               GUI_ID_BUTTON8,          483,358,151,75, 0,0},
    { BUTTON_CreateIndirect,    "4",                 GUI_ID_BUTTON9,          12, 439,151,75, 0,0},
    { BUTTON_CreateIndirect,    "5",                 GUI_ID_BUTTON10,         169,439,151,75, 0,0},
    { BUTTON_CreateIndirect,    "6",                 GUI_ID_BUTTON11,         326,439,151,75, 0,0},
    { BUTTON_CreateIndirect,    "0",                 GUI_ID_BUTTON12,         483,439,151,75, 0,0},
    { BUTTON_CreateIndirect,    "7",                 GUI_ID_BUTTON13,         12, 520,151,75, 0,0},
    { BUTTON_CreateIndirect,    "8",                 GUI_ID_BUTTON15,         169,520,151,75, 0,0},
    { BUTTON_CreateIndirect,    "9",                 GUI_ID_BUTTON16,         326,520,151,75, 0,0},
    { BUTTON_CreateIndirect,    "ENT",               GUI_ID_BUTTON17,         483,520,151,75, 0,0}
void PaintDialogS1(WM_MESSAGE * pMsg)
void InitDialogS1(WM_MESSAGE * pMsg)
    //FRAMEWIN
     _CreatText(hWin, "",  GUI_ID_TEXT2,  5,180, 450,60,TEXT_ID_Enter);
     //TEXT_SetFont(WM_GetDialogItem(hWin,GUI_ID_TEXT2),&GUI_Font24B_1);
     TEXT_SetTextColor(WM_GetDialogItem(hWin,GUI_ID_TEXT2),GUI_BLACK);
     TEXT_SetBkColor(WM_GetDialogItem(hWin,GUI_ID_TEXT2),GUI_WHITE);
    switch(Language)
        case 0:
      case 1:
    //GUI_ID_TEXT3
    TEXT_SetFont(WM_GetDialogItem(hWin,GUI_ID_TEXT3),&GUI_Font24_ASCII);
    TEXT_SetTextAlign(WM_GetDialogItem(hWin,GUI_ID_TEXT3),GUI_TA_VCENTER|GUI_TA_CENTER);
    //GUI_ID_EDIT0
    EDIT_SetFont(WM_GetDialogItem(hWin,GUI_EDIT_ID_0),&GUI_Font32_ASCII);
    EDIT_SetTextAlign(WM_GetDialogItem(hWin,GUI_EDIT_ID_0),GUI_TA_VCENTER|GUI_TA_CENTER);
    //GUI_ID_TEXT4
    TEXT_SetFont(WM_GetDialogItem(hWin,GUI_ID_TEXT4),&GUI_FontHZ_NewSimSun_35);
    TEXT_SetTextAlign(WM_GetDialogItem(hWin,GUI_ID_TEXT4),GUI_TA_VCENTER|GUI_TA_CENTER);
    //GUI_ID_BUTTON5
    BUTTON_SetBkColor(WM_GetDialogItem(hWin,GUI_ID_BUTTON5),BUTTON_CI_UNPRESSED,0xffffff);
    BUTTON_SetTextColor(WM_GetDialogItem(hWin,GUI_ID_BUTTON5),BUTTON_CI_UNPRESSED,0xe16941);
    BUTTON_SetFont(WM_GetDialogItem(hWin,GUI_ID_BUTTON5),&GUI_FontHZ_NewSimSun_35);
    //GUI_ID_BUTTON6
    BUTTON_SetBkColor(WM_GetDialogItem(hWin,GUI_ID_BUTTON6),BUTTON_CI_UNPRESSED,0xffffff);
    BUTTON_SetTextColor(WM_GetDialogItem(hWin,GUI_ID_BUTTON6),BUTTON_CI_UNPRESSED,0xe16941);
    BUTTON_SetFont(WM_GetDialogItem(hWin,GUI_ID_BUTTON6),&GUI_FontHZ_NewSimSun_35);
    //GUI_ID_BUTTON7
    BUTTON_SetBkColor(WM_GetDialogItem(hWin,GUI_ID_BUTTON7),BUTTON_CI_UNPRESSED,0xffffff);
    BUTTON_SetTextColor(WM_GetDialogItem(hWin,GUI_ID_BUTTON7),BUTTON_CI_UNPRESSED,0xe16941);
    BUTTON_SetFont(WM_GetDialogItem(hWin,GUI_ID_BUTTON7),&GUI_FontHZ_NewSimSun_35);
    //GUI_ID_BUTTON8
    BUTTON_SetBkColor(WM_GetDialogItem(hWin,GUI_ID_BUTTON8),BUTTON_CI_UNPRESSED,0xffffff);
    BUTTON_SetTextColor(WM_GetDialogItem(hWin,GUI_ID_BUTTON8),BUTTON_CI_UNPRESSED,0xe16941);
    BUTTON_SetFont(WM_GetDialogItem(hWin,GUI_ID_BUTTON8),&GUI_FontHZ_NewSimSun_35);
    //GUI_ID_BUTTON9
    BUTTON_SetBkColor(WM_GetDialogItem(hWin,GUI_ID_BUTTON9),BUTTON_CI_UNPRESSED,0xffffff);
    BUTTON_SetTextColor(WM_GetDialogItem(hWin,GUI_ID_BUTTON9),BUTTON_CI_UNPRESSED,0xed9564);
    BUTTON_SetFont(WM_GetDialogItem(hWin,GUI_ID_BUTTON9),&GUI_FontHZ_NewSimSun_35);
    //GUI_ID_BUTTON10
    BUTTON_SetBkColor(WM_GetDialogItem(hWin,GUI_ID_BUTTON10),BUTTON_CI_UNPRESSED,0xffffff);
    BUTTON_SetTextColor(WM_GetDialogItem(hWin,GUI_ID_BUTTON10),BUTTON_CI_UNPRESSED,0xed9564);
    BUTTON_SetFont(WM_GetDialogItem(hWin,GUI_ID_BUTTON10),&GUI_FontHZ_NewSimSun_35);
    //GUI_ID_BUTTON11
    BUTTON_SetBkColor(WM_GetDialogItem(hWin,GUI_ID_BUTTON11),BUTTON_CI_UNPRESSED,0xffffff);
    BUTTON_SetTextColor(WM_GetDialogItem(hWin,GUI_ID_BUTTON11),BUTTON_CI_UNPRESSED,0xed9564);
    BUTTON_SetFont(WM_GetDialogItem(hWin,GUI_ID_BUTTON11),&GUI_FontHZ_NewSimSun_35);
    //GUI_ID_BUTTON12
    BUTTON_SetBkColor(WM_GetDialogItem(hWin,GUI_ID_BUTTON12),BUTTON_CI_UNPRESSED,0xffffff);
    BUTTON_SetTextColor(WM_GetDialogItem(hWin,GUI_ID_BUTTON12),BUTTON_CI_UNPRESSED,0xed9564);
    BUTTON_SetFont(WM_GetDialogItem(hWin,GUI_ID_BUTTON12),&GUI_FontHZ_NewSimSun_35);
    //GUI_ID_BUTTON13
    BUTTON_SetBkColor(WM_GetDialogItem(hWin,GUI_ID_BUTTON13),BUTTON_CI_UNPRESSED,0xffffff);
    BUTTON_SetTextColor(WM_GetDialogItem(hWin,GUI_ID_BUTTON13),BUTTON_CI_UNPRESSED,0xed9564);
    BUTTON_SetFont(WM_GetDialogItem(hWin,GUI_ID_BUTTON13),&GUI_FontHZ_NewSimSun_35);
    //GUI_ID_BUTTON15
    BUTTON_SetBkColor(WM_GetDialogItem(hWin,GUI_ID_BUTTON15),BUTTON_CI_UNPRESSED,0xffffff);
    BUTTON_SetTextColor(WM_GetDialogItem(hWin,GUI_ID_BUTTON15),BUTTON_CI_UNPRESSED,0xed9564);
    BUTTON_SetFont(WM_GetDialogItem(hWin,GUI_ID_BUTTON15),&GUI_FontHZ_NewSimSun_35);
    //GUI_ID_BUTTON16
    BUTTON_SetBkColor(WM_GetDialogItem(hWin,GUI_ID_BUTTON16),BUTTON_CI_UNPRESSED,0xffffff);
    BUTTON_SetTextColor(WM_GetDialogItem(hWin,GUI_ID_BUTTON16),BUTTON_CI_UNPRESSED,0xed9564);
    BUTTON_SetFont(WM_GetDialogItem(hWin,GUI_ID_BUTTON16),&GUI_FontHZ_NewSimSun_35);
    //GUI_ID_BUTTON17
    BUTTON_SetBkColor(WM_GetDialogItem(hWin,GUI_ID_BUTTON17),BUTTON_CI_UNPRESSED,0xffffff);
    BUTTON_SetTextColor(WM_GetDialogItem(hWin,GUI_ID_BUTTON17),BUTTON_CI_UNPRESSED,0xed9564);
    BUTTON_SetFont(WM_GetDialogItem(hWin,GUI_ID_BUTTON17),&GUI_FontHZ_NewSimSun_35);
    disnum=WM_GetDialogItem(hWin,GUI_EDIT_ID_0); //??????????????
    EDIT_SetText(disnum,n_input);
static int Set_InputString1(char input)
    if (len<3)
        n_input[len++]=input;
        n_input[len]=0;
        EDIT_SetMaxLen(disnum,4);
        EDIT_SetText(disnum,n_input);//显示
        number = atoi(n_input);
        if(number>127)
            number=0;
            EDIT_SetMaxLen(disnum,5);
            EDIT_SetText(disnum,"error");
     return number;
    else return 0;
static void _cbSetNum(WM_MESSAGE * pMsg)
    //GUI_RECT r;
    int NCode, Id;
    case WM_DELETE:
            NumberState=0;
       case WM_PAINT:
             PaintDialogS1(pMsg);
            InitDialogS1(pMsg);
        case WM_KEY:
                case GUI_KEY_ENTER:
            switch (Id)
                case GUI_ID_OK:
                case GUI_ID_CANCEL:
                        case GUI_ID_BUTTON5:
                                Set_InputString1('1');
                        case GUI_ID_BUTTON6:
                                Set_InputString1('2');
                        case GUI_ID_BUTTON7:
                                Set_InputString1('3');
                        case GUI_ID_BUTTON8:
                                n_input[0]=0;
                                    len=0;
                        case GUI_ID_BUTTON9:
                                Set_InputString1('4');
                        case GUI_ID_BUTTON10:
                                Set_InputString1('5');
                        case GUI_ID_BUTTON11:
                                Set_InputString1('6');
                        case GUI_ID_BUTTON12:
                                Set_InputString1('0');
                        case GUI_ID_BUTTON13:
                                Set_InputString1('7');
                        case GUI_ID_BUTTON15:
                                Set_InputString1('8');
                       case GUI_ID_BUTTON16:
                                Set_InputString1('9');
                    case GUI_ID_BUTTON17:
                                snumber=number;
                                SettingState=1;
                                OpenSetting();
                    case BUTTON_ID_0:
                                snumber=number;
                                MeasureState=1;
                                OpenMeasure();
        default:
页面切换2,3次后就提示嵌套过多了。。。。我到现在还没有解决。
void OPenSetNum(void)
  WM_HWIN Number;
  NumberState=1;
  Number=GUI_ExecDialogBox(_aDialogCreateS1, GUI_COUNTOF(_aDialogCreateS1), &_cbSetNum, 0, 0, 0);
  while(1)
       GUI_Delay(10);
发表于 2015-5-17 22:11:27 | 显示全部楼层
我记得这个函数不是阻塞式的吗,你看下手册是不是搞错了, GUI_ExecDialogBox
 楼主| 发表于 2015-5-17 22:16:22 | 显示全部楼层
eric2013:我记得这个函数不是阻塞式的吗,你看下手册是不是搞错了, GUI_ExecDialogBox (2015-05-17 22:11)
我换成了GUI_CreateDialogBox效果一样。GUI_ExecDialogBox()函数是创建对话框并且马上执行对话框的回调函数,一直到该对话框的动作处理完成之后才返回,所以在对话框的回调函数中调用这个函数就相当调用了一个同步函数。如果在两个对话框的回调函数中利用这个函数相互调创建对方的话,就会导致无限的同步函数嵌套调用,就会进入一个死循环,回调函数就永远无法返回。
我后来在GUI_CreateDialogBox后面加了while(1){GUI_Exec();}一样要死
 楼主| 发表于 2015-5-18 11:27:48 | 显示全部楼层
case BUTTON_ID_0:
                                GUI_EndDialog(hWin, 0);////////////////////结束对话框////////////////
                                snumber=number;
                                MeasureState=1;
                                OpenMeasure();
我在这里结束前一个对话框还是不行。。。现在使用的GUI_CreateDialogBox()非阻塞方式建立的
 楼主| 发表于 2015-5-19 12:32:11 | 显示全部楼层
已解决。。。。不需要while(1)
GMT+8, 2026-11-23 07:29 , Processed in 0.454484 second(s), 27 queries .
