查看: 3950|回复: 1
[emWin] WM_SetUserData問題
发表于 2018-11-30 10:24:08 | 显示全部楼层 |阅读模式
請問已窗口的額外字節數設為12。卻無法將hWin_temp的12個字節資料傳入。但設為8個字節卻沒問題,請問是哪裡出問題呢 感謝~
  { WINDOW_CreateIndirect, "Window", ID_WINDOW_0, 0, 0, 480, 272, 0, 0x0, 12 },
  { BUTTON_CreateIndirect, "B", ID_BUTTON_0, 145, 183, 80, 60, 0, 0x0, 0 },
  { BUTTON_CreateIndirect, "A", ID_BUTTON_1, 26, 187, 80, 56, 0, 0x0, 0 },
  { BUTTON_CreateIndirect, "C", ID_BUTTON_2, 292, 190, 80, 46, 0, 0x0, 0 },
  // USER START (Optionally insert additional widgets)
  // USER END
WM_HWIN CreateWindow(void) {
  WM_HWIN hWin,hWin_temp[3];
  hWin = GUI_CreateDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), _cbDialog, WM_HBKWIN, 0, 0);
  hWin_temp[0] =33;
  hWin_temp[1] =55;
  hWin_temp[2] =66;
  WM_SetUserData(hWin,hWin_temp,12);
  return hWin;
发表于 2018-11-30 10:25:59 | 显示全部楼层
GMT+8, 2026-11-23 14:30 , Processed in 0.571917 second(s), 24 queries .
