查看: 2734|回复: 4
[emWin] 复选框控件设置为禁用后还可以聚焦?
发表于 2018-11-26 18:22:32 | 显示全部楼层 |阅读模式
现在我使用的是emwin5.22版本,用键盘作操作界面。在一个窗口中放置了4个复选框控件,窗口建立时使用WM_DisableWindo()函数把两个复选框设置为禁用状态,调试的时候使用键盘给窗口发送GUI_SendKeyMsg(GUI_KEY_TAB, 1);按键消息,发现输入焦点也能聚焦到禁用的两个复选框控件上。然后我在emwin5.32模拟器上模拟了一下发现设置成禁用的复选框无法聚焦。两个程序都是一样的,为什么会有两种不同的结果?模拟器上的应该是正确的现象。在模拟器上的程序如下
#include "DIALOG.h"
#define ID_FRAMEWIN_0 (GUI_ID_USER + 0x00)
#define ID_CHECKBOX_0 (GUI_ID_USER + 0x01)
#define ID_CHECKBOX_1 (GUI_ID_USER + 0x02)
#define ID_CHECKBOX_2 (GUI_ID_USER + 0x03)
*       _aDialogCreate
  { FRAMEWIN_CreateIndirect, "Framewin", ID_FRAMEWIN_0, 0, 0, 800, 480, 0, 0x64, 0 },
  { CHECKBOX_CreateIndirect, "Checkbox", ID_CHECKBOX_0, 45, 42, 121, 31, 0, 0x0, 0 },
  { CHECKBOX_CreateIndirect, "Checkbox", ID_CHECKBOX_1, 45, 104, 93, 32, 0, 0x0, 0 },
  { CHECKBOX_CreateIndirect, "Checkbox", ID_CHECKBOX_2, 45, 146, 93, 32, 0, 0x0, 0 },
  // USER START (Optionally insert additional widgets)
  // USER END
*       _cbDialog
  WM_HWIN hItem;
  int     NCode;
  int     Id;
  switch (pMsg->MsgId) {
  case WM_INIT_DIALOG:
    // Initialization of 'Framewin'
    hItem = pMsg->hWin;
    FRAMEWIN_SetFont(hItem, GUI_FONT_32B_ASCII);
    FRAMEWIN_SetTextAlign(hItem, GUI_TA_HCENTER | GUI_TA_VCENTER);
    FRAMEWIN_SetText(hItem, "armfly");
    // Initialization of 'Checkbox'
    hItem = WM_GetDialogItem(pMsg->hWin, ID_CHECKBOX_0);
    CHECKBOX_SetText(hItem, "LED1");
    CHECKBOX_SetFont(hItem, GUI_FONT_24B_ASCII);
    hItem = WM_GetDialogItem(pMsg->hWin, ID_CHECKBOX_1);
    CHECKBOX_SetText(hItem, "LED2");
    WM_DisableWindow(WM_GetDialogItem(pMsg->hWin, ID_CHECKBOX_1));//指定窗口设置为禁用状态
    hItem = WM_GetDialogItem(pMsg->hWin, ID_CHECKBOX_2);
    CHECKBOX_SetText(hItem, "LED3");
  case WM_NOTIFY_PARENT:
   省略
*       Public code
*       CreateFramewin
WM_HWIN CreateFramewin(void);
WM_HWIN CreateFramewin(void) {
  WM_HWIN hWin;
  hWin = GUI_CreateDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), _cbDialog, WM_HBKWIN, 0, 0);
  return hWin;
*       MainTask
void MainTask(void)
        /* 初始化 */
        GUI_Init();
        /* 窗口自动使用存储设备 */
        /* 创建对话框,使用GUIBulder5.32生成的对话框创建函数 */
        CreateFramewin();
        while(1)
                GUI_Delay(10);
发表于 2018-11-27 04:02:48 | 显示全部楼层
新版的emWin5.40可以设置各个控件的聚焦状态,有个专门的API。
 楼主| 发表于 2018-11-28 21:33:11 | 显示全部楼层
为什么模拟器上的结果和实际的显示结果不一样呢?
发表于 2018-11-29 03:15:59 | 显示全部楼层
发个完整的测试程序,我试试。
 楼主| 发表于 2018-12-20 10:51:05 | 显示全部楼层
eric2013 发表于 2018-11-29 03:15
发个完整的测试程序,我试试。
*                SEGGER Microcontroller GmbH & Co. KG                *
*        Solutions for real time microcontroller applications        *
* C-file generated by:                                               *
*        GUI_Builder for emWin version 5.22                          *
*        Compiled Jul  4 2013, 15:16:01                              *
*        (c) 2013 Segger Microcontroller GmbH & Co. KG               *
*        Internet: www.segger.com  Support: support@segger.com       *
// USER START (Optionally insert additional includes)
// USER END
#include "DIALOG.h"
*       Defines
#define ID_CHECKBOX_3    (GUI_ID_USER + 0x04)
#define ID_CHECKBOX_4    (GUI_ID_USER + 0x05)
#define ID_CHECKBOX_5    (GUI_ID_USER + 0x06)
#define ID_BUTTON_0    (GUI_ID_USER + 0x07)
// USER START (Optionally insert additional defines)
// USER END
*       Static data
WM_HWIN CreateFramewin_Test(void);
// USER START (Optionally insert additional static data)
// USER END
*       _aDialogCreate
    { FRAMEWIN_CreateIndirect, "Framewin", ID_FRAMEWIN_0, 62, 60, 360, 160, 0, 0x64, 0 },
    { CHECKBOX_CreateIndirect, "Checkbox", ID_CHECKBOX_0, 60, 30, 80, 20, 0, 0x0, 0 },
    { CHECKBOX_CreateIndirect, "Checkbox", ID_CHECKBOX_1, 150, 30, 80, 20, 0, 0x0, 0 },
    { CHECKBOX_CreateIndirect, "Checkbox", ID_CHECKBOX_2, 240, 30, 80, 20, 0, 0x0, 0 },
    { CHECKBOX_CreateIndirect, "Checkbox", ID_CHECKBOX_3, 60, 80, 80, 20, 0, 0x0, 0 },
    { CHECKBOX_CreateIndirect, "Checkbox", ID_CHECKBOX_4, 150, 80, 80, 20, 0, 0x0, 0 },
    { CHECKBOX_CreateIndirect, "Checkbox", ID_CHECKBOX_5, 240, 80, 80, 20, 0, 0x0, 0 },
    { BUTTON_CreateIndirect, "Button", ID_BUTTON_0, 126, 113, 80, 20, 0, 0x0, 0 },
    // USER END
*       Static code
// USER START (Optionally insert additional static code)
// USER END
*       _cbDialog
    WM_HWIN hItem;
    int     NCode;
    int     Id;
    // USER END
    case WM_KEY:
        WM_KEY_INFO* pData = (WM_KEY_INFO*)(pMsg->Data.p);        //获得消息结构体中的按键消息
        switch (pData->Key)
        case GUI_KEY_ESCAPE:                //按下ESCAPE键进入主菜单界面
            WM_DeleteWindow(pMsg->hWin);                //删除窗口
        case GUI_KEY_DOWN://对下一个控件聚焦
            WM_SetFocusOnNextChild(WM_GetClientWindow(pMsg->hWin));        //由于使用了框架窗口控件,必须先要获得客户端窗口句柄,才能进行焦点切换
            break;        //因为控件的父窗口是客户端窗口,而框架窗口是客户端窗口的父窗口
        case GUI_KEY_UP://对上一个控件聚焦
            WM_SetFocusOnPrevChild(WM_GetClientWindow(pMsg->hWin));
        hItem = pMsg->hWin;
        FRAMEWIN_SetFont(hItem, GUI_FONT_16B_1);
        FRAMEWIN_SetText(hItem, "Framewin");
        CHECKBOX_SetText(hItem, "Check");
        hItem = WM_GetDialogItem(pMsg->hWin, ID_CHECKBOX_3);
        hItem = WM_GetDialogItem(pMsg->hWin, ID_CHECKBOX_4);
        hItem = WM_GetDialogItem(pMsg->hWin, ID_CHECKBOX_5);
        WM_DisableWindow(WM_GetDialogItem(pMsg->hWin, ID_CHECKBOX_3));//指定窗口设置为禁用状态
        WM_DisableWindow(WM_GetDialogItem(pMsg->hWin, ID_CHECKBOX_4));//指定窗口设置为禁用状态
        WM_DisableWindow(WM_GetDialogItem(pMsg->hWin, ID_CHECKBOX_5));//指定窗口设置为禁用状态
        // USER START (Optionally insert additional code for further widget initialization)
        // USER END
        NCode = pMsg->Data.v;
        switch(Id) {
        case ID_CHECKBOX_0: // Notifications sent by 'Checkbox'
            switch(NCode) {
            case WM_NOTIFICATION_CLICKED:
                // USER END
                // USER END
            case WM_NOTIFICATION_VALUE_CHANGED:
                // USER END
                // USER END
        case ID_CHECKBOX_1: // Notifications sent by 'Checkbox'
            switch(NCode) {
                // USER END
                // USER END
                // USER END
                // USER END
        case ID_CHECKBOX_2: // Notifications sent by 'Checkbox'
            switch(NCode) {
                // USER END
                // USER END
                // USER END
                // USER END
        case ID_CHECKBOX_3: // Notifications sent by 'Checkbox'
            switch(NCode) {
                // USER END
                // USER END
                // USER END
                // USER END
        case ID_CHECKBOX_4: // Notifications sent by 'Checkbox'
            switch(NCode) {
                // USER END
                // USER END
                // USER END
                // USER END
        case ID_CHECKBOX_5: // Notifications sent by 'Checkbox'
            switch(NCode) {
                // USER END
                // USER END
                // USER END
                // USER END
        case ID_BUTTON_0: // Notifications sent by 'Button'
            switch(NCode) {
//                WM_DeleteWindow(pMsg->hWin);                //删除窗口
                GUI_EndDialog(pMsg->hWin, 0);
                // USER END
                // USER END
            // USER START (Optionally insert additional code for further Ids)
            // USER END
    // USER START (Optionally insert additional message handling)
    // USER END
    default:
        WM_DefaultProc(pMsg);
*       Public code
*       CreateFramewin
WM_HWIN CreateFramewin_Test(void) {
    WM_HWIN hWin;
    return hWin;
// USER START (Optionally insert additional public code)
// USER END
这段程序在我的板子上试了,设置为禁用状态的三个复选框仍然可以聚焦,您可以试一下
GMT+8, 2026-11-23 14:44 , Processed in 1.149188 second(s), 24 queries .
