查看: 5427|回复: 2
[LibJPEG] 【LibJPEG专题系列十八】算术编码
春暖花开
发表于 2015-5-12 14:40:14 | 显示全部楼层 |阅读模式
           Section - [18] What about arithmetic coding?
The JPEG spec defines two different "back end" modules for the final output of compressed data: either Huffman
coding or arithmetic coding is allowed. The choice has no impact on image quality, but arithmetic coding usually
produces a smaller compressed file.  On typical images, arithmetic coding produces a file 5 to 10 percent smaller
than Huffman coding.  (All the file-size numbers previously cited are for Huffman coding.)
Unfortunately, the particular variant of arithmetic coding specified by the JPEG standard is subject to patents owned
by IBM, AT&T, and Mitsubishi. Thus *you cannot legally use JPEG arithmetic coding* unless you obtain licenses
from these companies.  (Patent law's "experimental use" exception allows people to test a patented method in the
context of scientific research, but any commercial or routine personal use is infringement.)
I recommend that people not use JPEG arithmetic coding; the space savings isn't great enough to justify the potential
legal hassles.  In particular, arithmetic coding *should not* be used for any images to be exchanged on the Internet.
Even if you don't care about US patent law, other folks do.
努力打造安富莱高质量微信公众号:点击扫描图片关注
发表于 2015-5-13 09:47:33 | 显示全部楼层
不熟悉[s:151] [s:151] [s:151]
春暖花开
 楼主| 发表于 2015-5-13 13:17:58 | 显示全部楼层
                                         Section 18—算术编码
        JPEG规范定义了两种不同的“后端”模块用于压缩数据的最终输出:哈夫曼编码或算术编码都是允许的。
二者的选择对于图像的质量没有影响,但算术编码通常会产生更小的压缩文件。对于典型的图像,算术编码
产生的文件将比哈夫曼编码产生的文件小5%到10%。(前面提到的所有文件大小的数字都是哈夫曼编码情况
下的。)
    不幸的是,由JPEG标准指定的算术编码的特定变型从属于IBM、AT&T以及Mitsubishi公司拥有的专利。
因此,除非你获得这些公司的许可,您才能合法使用JPEG算术编码。(专利法“实验性使用”的例外允许人
们在科研方面测试一个有专利的方法,但任何商业用途或个人日常使用是侵权的。)
    建议不要使用算术编码,节省空间的目的还不至于大到去挑战法律的权威。特别是,算术编码本不应该
用于任何网络上的图像交换。尽管你不在意美国的专利法,其他人还是会遵守的。
GMT+8, 2026-11-23 07:29 , Processed in 0.312324 second(s), 24 queries .
