查看: 6958|回复: 4
[ADC] STM32CubeMX什么鬼,怎么不让选择ADC使用AHB时钟,估计是个bug
发表于 2018-9-6 11:58:46 | 显示全部楼层 |阅读模式
 楼主| 发表于 2018-9-6 12:01:54 | 显示全部楼层
个人认为是CubeMX的bug,手册说明是支持的。
而CubMX里面就是没有来自AHB的时钟多路选项,真是坑!!!!!!!!
寄存器说明:
发表于 2018-9-6 19:41:33 | 显示全部楼层
直接改source code吧
  1. /** @defgroup ADC_ClockPrescaler ADC clock source and clock prescaler
  2.   * @{
  3.   */
  4. #define ADC_CLOCK_SYNC_PCLK_DIV1      ((uint32_t)ADC_CCR_CKMODE_0)  /*!< ADC synchronous clock derived from AHB clock not divided  */
  5. #define ADC_CLOCK_SYNC_PCLK_DIV2      ((uint32_t)ADC_CCR_CKMODE_1)  /*!< ADC synchronous clock derived from AHB clock divided by 2 */
  6. #define ADC_CLOCK_SYNC_PCLK_DIV4      ((uint32_t)ADC_CCR_CKMODE)    /*!< ADC synchronous clock derived from AHB clock divided by 4 */
  7. #define ADC_CLOCKPRESCALER_PCLK_DIV1   ADC_CLOCK_SYNC_PCLK_DIV1     /*!< Obsolete naming, kept for compatibility with some other devices */
  8. #define ADC_CLOCKPRESCALER_PCLK_DIV2   ADC_CLOCK_SYNC_PCLK_DIV2     /*!< Obsolete naming, kept for compatibility with some other devices */
  9. #define ADC_CLOCKPRESCALER_PCLK_DIV4   ADC_CLOCK_SYNC_PCLK_DIV4     /*!< Obsolete naming, kept for compatibility with some other devices */
  10. #define ADC_CLOCK_ASYNC_DIV1       ((uint32_t)0x00000000)                                        /*!< ADC asynchronous clock not divided    */
  11. #define ADC_CLOCK_ASYNC_DIV2       ((uint32_t)ADC_CCR_PRESC_0)                                   /*!< ADC asynchronous clock divided by 2   */
  12. #define ADC_CLOCK_ASYNC_DIV4       ((uint32_t)ADC_CCR_PRESC_1)                                   /*!< ADC asynchronous clock divided by 4   */
  13. #define ADC_CLOCK_ASYNC_DIV6       ((uint32_t)(ADC_CCR_PRESC_1|ADC_CCR_PRESC_0))                 /*!< ADC asynchronous clock divided by 6   */
  14. #define ADC_CLOCK_ASYNC_DIV8       ((uint32_t)(ADC_CCR_PRESC_2))                                 /*!< ADC asynchronous clock divided by 8   */
  15. #define ADC_CLOCK_ASYNC_DIV10      ((uint32_t)(ADC_CCR_PRESC_2|ADC_CCR_PRESC_0))                 /*!< ADC asynchronous clock divided by 10  */
  16. #define ADC_CLOCK_ASYNC_DIV12      ((uint32_t)(ADC_CCR_PRESC_2|ADC_CCR_PRESC_1))                 /*!< ADC asynchronous clock divided by 12  */
  17. #define ADC_CLOCK_ASYNC_DIV16      ((uint32_t)(ADC_CCR_PRESC_2|ADC_CCR_PRESC_1|ADC_CCR_PRESC_0)) /*!< ADC asynchronous clock divided by 16  */
  18. #define ADC_CLOCK_ASYNC_DIV32      ((uint32_t)(ADC_CCR_PRESC_3))                                 /*!< ADC asynchronous clock divided by 32  */
  19. #define ADC_CLOCK_ASYNC_DIV64      ((uint32_t)(ADC_CCR_PRESC_3|ADC_CCR_PRESC_0))                 /*!< ADC asynchronous clock divided by 64  */
  20. #define ADC_CLOCK_ASYNC_DIV128     ((uint32_t)(ADC_CCR_PRESC_3|ADC_CCR_PRESC_1))                 /*!< ADC asynchronous clock divided by 128 */
  21. #define ADC_CLOCK_ASYNC_DIV256     ((uint32_t)(ADC_CCR_PRESC_3|ADC_CCR_PRESC_1|ADC_CCR_PRESC_0)) /*!< ADC asynchronous clock divided by 256 */
 楼主| 发表于 2018-9-7 00:55:13 | 显示全部楼层
Stanley 发表于 2018-9-6 19:41
直接改source code吧
是的,手动设置即可。
发表于 2023-2-7 13:20:36 | 显示全部楼层
我也遇到了同样的问题,我试了下,这三个时钟源只有在ADC异步模式下才可以选择,看样子这三个源都被视作异步时钟源了,如果ADC使用同步模式,这里直接就被禁用了 image.png ,可能CUBE软件在ADC为同步模式下,直接就把AHB的时钟赋给ADC了,然后在ADC配置页面再分频,最终确定ADC外设频率
400MHz这里,我试了下,只要CUBE上面,STM32主频低于400MHz,ADC同步模式就不能选,401就可以选,目前我也是手动地修改代码里面的配置进行解决的
GMT+8, 2026-10-25 14:52 , Processed in 0.181016 second(s), 27 queries .
