查看: 7312|回复: 4
[HRTIM] STM32H7的HRTIM生成任意波形
发表于 2018-8-31 01:46:56 | 显示全部楼层 |阅读模式
说明:
这个例程的配置也是有点复杂,可以合成任意波形效果。
关键还是这两个参数成员的配置:
sConfig_output_config.SetSource = HRTIM_OUTPUTSET_TIMPER + HRTIM_OUTPUTSET_TIMCMP1 + HRTIM_OUTPUTSET_TIMCMP2;
sConfig_output_config.ResetSource  = HRTIM_OUTPUTRESET_TIMPER + HRTIM_OUTPUTRESET_TIMCMP1 + HRTIM_OUTPUTRESET_TIMCMP2;
波形效果:
代码:
  1. /* Private typedef -----------------------------------------------------------*/
  2. /* Private define ------------------------------------------------------------*/
  3. #define HRTIM_MAX_PERIOD  0xFFFF
  4. /* Private macro -------------------------------------------------------------*/
  5. /* Private variables ---------------------------------------------------------*/
  6. /* Timer handler declaration */
  7. HRTIM_HandleTypeDef                 HrtimHandle;
  8. HRTIM_TimeBaseCfgTypeDef            sConfig_time_base;
  9. HRTIM_TimerCfgTypeDef               sConfig_timerD;
  10. HRTIM_OutputCfgTypeDef              sConfig_output_config;
  11. HRTIM_CompareCfgTypeDef             sConfig_compare;
  12.
  13. /* Private function prototypes -----------------------------------------------*/
  14. static void SystemClock_Config(void);
  15. static void Error_Handler(void);
  16. static void CPU_CACHE_Enable(void);
  17. /* Private functions ---------------------------------------------------------*/
  18. /**
  19.   * @brief  Main program
  20.   * @param  None
  21.   * @retval None
  22.   */
  23. int main(void)
  24. {
  25.   /* Enable the CPU Cache */
  26.   CPU_CACHE_Enable();
  27.   /* STM32H7xx HAL library initialization:
  28.        - Configure the Systick to generate an interrupt each 1 msec
  29.        - Set NVIC Group Priority to 4
  30.        - Low Level Initialization
  31.   */
  32.   HAL_Init();
  33.   /* Configure the system clock to 400 MHz */
  34.   SystemClock_Config();
  35.   /*##-1- Configure the HRTIM peripheral ######################################################*/
  36.   /* Initialize the HRTIM structure (minimal configuration) */
  37.   HrtimHandle.Instance = HRTIM1;
  38.   HrtimHandle.Init.HRTIMInterruptResquests = HRTIM_IT_NONE;
  39.   HrtimHandle.Init.SyncOptions = HRTIM_SYNCOPTION_NONE;
  40.   /* Initialize HRTIM */
  41.   HAL_HRTIM_Init(&HrtimHandle);
  42.   /*##-2- Configure the HRTIM TIMA PWM channels 1 & 2 #########################################*/
  43.   sConfig_time_base.Period = HRTIM_MAX_PERIOD;
  44.   sConfig_time_base.RepetitionCounter = 0;
  45.   sConfig_time_base.PrescalerRatio = HRTIM_PRESCALERRATIO_DIV1;
  46.   sConfig_time_base.Mode = HRTIM_MODE_CONTINUOUS;
  47.   HAL_HRTIM_TimeBaseConfig(&HrtimHandle, HRTIM_TIMERINDEX_TIMER_D, &sConfig_time_base);
  48.   /* TIMERD global configuration: preload enabled on REP event */
  49.   sConfig_timerD.DMARequests = HRTIM_TIM_DMA_NONE;
  50.   sConfig_timerD.HalfModeEnable = HRTIM_HALFMODE_DISABLED;
  51.   sConfig_timerD.StartOnSync = HRTIM_SYNCSTART_DISABLED;
  52.   sConfig_timerD.ResetOnSync = HRTIM_SYNCRESET_DISABLED;
  53.   sConfig_timerD.DACSynchro = HRTIM_DACSYNC_NONE;
  54.   sConfig_timerD.PreloadEnable = HRTIM_PRELOAD_ENABLED;
  55.   sConfig_timerD.UpdateGating = HRTIM_UPDATEGATING_INDEPENDENT;
  56.   sConfig_timerD.BurstMode = HRTIM_TIMERBURSTMODE_MAINTAINCLOCK;
  57.   sConfig_timerD.RepetitionUpdate = HRTIM_UPDATEONREPETITION_ENABLED;
  58.   sConfig_timerD.ResetUpdate = HRTIM_TIMUPDATEONRESET_DISABLED;
  59.   sConfig_timerD.InterruptRequests = HRTIM_TIM_IT_NONE;
  60.   sConfig_timerD.PushPull = HRTIM_TIMPUSHPULLMODE_DISABLED;
  61.   sConfig_timerD.FaultEnable = HRTIM_TIMFAULTENABLE_NONE;
  62.   sConfig_timerD.FaultLock = HRTIM_TIMFAULTLOCK_READWRITE;
  63.   sConfig_timerD.DeadTimeInsertion = HRTIM_TIMDEADTIMEINSERTION_DISABLED;
  64.   sConfig_timerD.DelayedProtectionMode = HRTIM_TIMER_A_B_C_DELAYEDPROTECTION_DISABLED;
  65.   sConfig_timerD.UpdateTrigger= HRTIM_TIMUPDATETRIGGER_NONE;
  66.   sConfig_timerD.ResetTrigger = HRTIM_TIMRESETTRIGGER_NONE;
  67.
  68.   HAL_HRTIM_WaveformTimerConfig(&HrtimHandle, HRTIM_TIMERINDEX_TIMER_D,&sConfig_timerD);
  69.   /* TD1 waveform description: toggles on TIMD period, CMP1 and CMP2 event */
  70.   sConfig_output_config.Polarity = HRTIM_OUTPUTPOLARITY_HIGH;
  71.   sConfig_output_config.SetSource = HRTIM_OUTPUTSET_TIMPER + HRTIM_OUTPUTSET_TIMCMP1 + HRTIM_OUTPUTSET_TIMCMP2;
  72.   sConfig_output_config.ResetSource  = HRTIM_OUTPUTRESET_TIMPER + HRTIM_OUTPUTRESET_TIMCMP1 + HRTIM_OUTPUTRESET_TIMCMP2;
  73.   sConfig_output_config.IdleMode = HRTIM_OUTPUTIDLEMODE_NONE;
  74.   sConfig_output_config.IdleLevel = HRTIM_OUTPUTIDLELEVEL_INACTIVE;
  75.   sConfig_output_config.FaultLevel = HRTIM_OUTPUTFAULTLEVEL_NONE;
  76.   sConfig_output_config.ChopperModeEnable = HRTIM_OUTPUTCHOPPERMODE_DISABLED;
  77.   sConfig_output_config.BurstModeEntryDelayed = HRTIM_OUTPUTBURSTMODEENTRY_REGULAR;
  78.
  79.   HAL_HRTIM_WaveformOutputConfig(&HrtimHandle, HRTIM_TIMERINDEX_TIMER_D, HRTIM_OUTPUT_TD1, &sConfig_output_config);
  80.   /* TD2 waveform description: set on TIMD PER and CMP2 and */
  81.   /* reset on TIMD CMP1 and CMP3 event                      */
  82.   sConfig_output_config.SetSource = HRTIM_OUTPUTSET_TIMPER + HRTIM_OUTPUTSET_TIMCMP2;
  83.   sConfig_output_config.ResetSource  = HRTIM_OUTPUTRESET_TIMCMP1 + HRTIM_OUTPUTRESET_TIMCMP3;
  84.
  85.   HAL_HRTIM_WaveformOutputConfig(&HrtimHandle, HRTIM_TIMERINDEX_TIMER_D, HRTIM_OUTPUT_TD2, &sConfig_output_config);
  86.   /* Set compare register 1 in Timer D */
  87.   sConfig_compare.CompareValue = HRTIM_MAX_PERIOD/4;     /* 25% of the period */
  88.   HAL_HRTIM_WaveformCompareConfig(&HrtimHandle, HRTIM_TIMERINDEX_TIMER_D, HRTIM_COMPAREUNIT_1, &sConfig_compare);
  89.   /* Set compare register 2 in Timer D */
  90.   sConfig_compare.AutoDelayedMode = HRTIM_AUTODELAYEDMODE_REGULAR;
  91.   sConfig_compare.AutoDelayedTimeout = 0;
  92.   sConfig_compare.CompareValue = (3*HRTIM_MAX_PERIOD)/8;     /* 37.5% of the period */
  93.   HAL_HRTIM_WaveformCompareConfig(&HrtimHandle, HRTIM_TIMERINDEX_TIMER_D, HRTIM_COMPAREUNIT_2, &sConfig_compare);
  94.   /* Set compare register 3 in Timer D */
  95.   sConfig_compare.CompareValue = HRTIM_MAX_PERIOD/2;     /* 50% of the period */
  96.   HAL_HRTIM_WaveformCompareConfig(&HrtimHandle, HRTIM_TIMERINDEX_TIMER_D, HRTIM_COMPAREUNIT_3, &sConfig_compare);
  97.
  98.   /*##-7- Start Waveform signals generation ########################################################*/
  99.   if (HAL_HRTIM_WaveformOutputStart(&HrtimHandle, HRTIM_OUTPUT_TD1 + HRTIM_OUTPUT_TD2) != HAL_OK)
  100.   {
  101.     /* Waveform Generation Error */
  102.     Error_Handler();
  103.   }
  104.         if (HAL_HRTIM_WaveformCounterStart(&HrtimHandle, HRTIM_TIMERID_TIMER_D) != HAL_OK)
  105.   {
  106.     /* Waveform Generation Error */
  107.     Error_Handler();
  108.   }
  109.   /* Infinite loop */
  110.   while (1)
  111.   {
  112.   }
  113. }
发表于 2018-8-31 20:45:58 | 显示全部楼层
控制12路步进电机  S加减速曲线。。。。不占用CPU。。。。
发表于 2026-1-15 00:04:26 | 显示全部楼层
硬汉哥,这个HRTIM生成任意波形是有官方例程吗,我没有找到。
 楼主| 发表于 2026-1-16 09:55:25 | 显示全部楼层
这个就是官方的例子,下载STM32CubeH7软件包,HRTIM文件夹里面有个例子是。
参与人数 1金币 +10 收起 理由
778899 + 10 谢谢硬汉哥
发表于 2026-1-23 14:54:08 | 显示全部楼层
搜索引擎可以找一下,有相关的帖子的。在cubemx上配置还是蛮方便的
GMT+8, 2026-10-24 09:26 , Processed in 0.693927 second(s), 28 queries .
