查看: 10474|回复: 3
[TIMER] STM32H7实现单个定时器中不同通道配置不同频率PWM的方法
发表于 2018-8-16 01:20:52 | 显示全部楼层 |阅读模式
说明:感觉这种方式实用价值不大,因为要每次都进入中断里面更新CCR比较捕获寄存器。
不如用户自己搞个定时器中断,在中断里面直接操作IO即可,简单省事。
调用函数HAL_TIM_OC_Init,HAL_TIM_OC_ConfigChannel和HAL_TIM_OC_Start_IT即可实现
官方例子里面是测试了4路,我这里用示波器测试了前两路效果:
PA.08 (TIM1_Channel1)
PA.09 (TIM1_Channel2)
PA.10 (TIM1_Channel3)
PE.14 (TIM1_Channel4)
实现的代码如下:
  1. /* Private typedef -----------------------------------------------------------*/
  2. /* Private define ------------------------------------------------------------*/
  3. /* Private macro -------------------------------------------------------------*/
  4. /* Private variables ---------------------------------------------------------*/
  5. __IO uint32_t uhCCR1_Val = 40960;
  6. __IO uint32_t uhCCR2_Val = 20480;
  7. __IO uint32_t uhCCR3_Val = 10240;
  8. __IO uint32_t uhCCR4_Val = 5120;
  9. uint32_t uhCapture = 0;
  10. /* Timer handler declaration */
  11. TIM_HandleTypeDef    TimHandle;
  12. /* Timer Output Compare Configuration Structure declaration */
  13. TIM_OC_InitTypeDef sConfig;
  14. /* Counter Prescaler value */
  15. uint32_t uwPrescalerValue = 0;
  16. /* Private function prototypes -----------------------------------------------*/
  17. static void SystemClock_Config(void);
  18. static void Error_Handler(void);
  19. static void CPU_CACHE_Enable(void);
  20. /* Private functions ---------------------------------------------------------*/
  21. /**
  22.   * @brief  Main program.
  23.   * @param  None
  24.   * @retval None
  25.   */
  26. int main(void)
  27. {
  28.   /* Enable the CPU Cache */
  29.   CPU_CACHE_Enable();
  30.
  31.   /* STM32H7xx HAL library initialization:
  32.        - Systick timer is configured by default as source of time base, but user
  33.          can eventually implement his proper time base source (a general purpose
  34.          timer for example or other time source), keeping in mind that Time base
  35.          duration should be kept 1ms since PPP_TIMEOUT_VALUEs are defined and
  36.          handled in milliseconds basis.
  37.        - Set NVIC Group Priority to 4
  38.        - Low Level Initialization
  39.      */
  40.   HAL_Init();
  41.   /* Configure the system clock to 400 MHz */
  42.   SystemClock_Config();
  43.   /* Configure LED2 */
  44.   BSP_LED_Init(LED2);
  45.    /*##-1- Configure the TIM peripheral #######################################*/
  46.   /* ---------------------------------------------------------------------------
  47.   TIM1 Configuration: Output Compare Toggle Mode:
  48.   To get TIM1 counter clock at 20 MHz, the prescaler is computed as follows:
  49.   Prescaler = (TIM1CLK / TIM1 counter clock) - 1
  50.   Prescaler = (SystemCoreClock /2*20000000) - 1
  51.   CC1 update rate = TIM1 counter clock / uhCCR1_Val
  52.                   = 20 MHz/40961 = 488.269 Hz
  53.   ==> So the TIM1 Channel 1 generates a periodic signal with a frequency equal
  54.       to 244.13 Hz.
  55.   CC2 update rate = TIM1 counter clock / uhCCR2_Val
  56.                   = 20 MHz/20480 = 976.56 Hz
  57.   ==> So the TIM1 Channel 2 generates a periodic signal with a frequency equal
  58.       to 488.28 Hz.
  59.   CC3 update rate = TIM1 counter clock / uhCCR3_Val
  60.                   = 20 MHz/10240 = 1953.1 Hz
  61.   ==> So the TIM1 Channel 3 generates a periodic signal with a frequency equal
  62.       to 976.56 Hz.
  63.   CC4 update rate = TIM1 counter clock / uhCCR4_Val
  64.                   = 20 MHz/5120 = 3906.25 Hz
  65.   ==> So the TIM1 Channel 4 generates a periodic signal with a frequency equal
  66.       to 1953.12 Hz.
  67.   --------------------------------------------------------------------------- */
  68.   /* Compute the prescaler value to have TIM1 counter clock equal to 20 MHz */
  69.   uwPrescalerValue = (uint32_t)((SystemCoreClock / 40000000) - 1);
  70.
  71.   TimHandle.Instance = TIM1;
  72.
  73.   TimHandle.Init.Period        = 65535;
  74.   TimHandle.Init.Prescaler     = uwPrescalerValue;
  75.   TimHandle.Init.ClockDivision = 0;
  76.   TimHandle.Init.CounterMode   = TIM_COUNTERMODE_UP;
  77.   if(HAL_TIM_OC_Init(&TimHandle) != HAL_OK)
  78.   {
  79.     /* Initialization Error */
  80.     Error_Handler();
  81.   }
  82.
  83.   /*##-2- Configure the Output Compare channels ##############################*/
  84.   /* Common configuration for all channels */
  85.   sConfig.OCMode     = TIM_OCMODE_TOGGLE;
  86.   sConfig.OCPolarity = TIM_OCPOLARITY_LOW;
  87.   /* Output Compare Toggle Mode configuration: Channel1 */
  88.   sConfig.Pulse = uhCCR1_Val;
  89.   if(HAL_TIM_OC_ConfigChannel(&TimHandle, &sConfig, TIM_CHANNEL_1) != HAL_OK)
  90.   {
  91.     /* Configuration Error */
  92.     Error_Handler();
  93.   }
  94.
  95.   /* Output Compare Toggle Mode configuration: Channel2 */
  96.   sConfig.Pulse = uhCCR2_Val;
  97.   if(HAL_TIM_OC_ConfigChannel(&TimHandle, &sConfig, TIM_CHANNEL_2) != HAL_OK)
  98.   {
  99.     /* Configuration Error */
  100.     Error_Handler();
  101.   }
  102.
  103.   /* Output Compare Toggle Mode configuration: Channel3 */
  104.   sConfig.Pulse = uhCCR3_Val;
  105.   if(HAL_TIM_OC_ConfigChannel(&TimHandle, &sConfig, TIM_CHANNEL_3) != HAL_OK)
  106.   {
  107.     /* Configuration Error */
  108.     Error_Handler();
  109.   }
  110.
  111.   /* Output Compare Toggle Mode configuration: Channel4 */
  112.   sConfig.Pulse = uhCCR4_Val;
  113.   if(HAL_TIM_OC_ConfigChannel(&TimHandle, &sConfig, TIM_CHANNEL_4) != HAL_OK)
  114.   {
  115.     /* Configuration Error */
  116.     Error_Handler();
  117.   }
  118.   /*##-3- Start signals generation #######################################*/
  119.   /* Start channel 1 in Output compare mode */
  120.   if(HAL_TIM_OC_Start_IT(&TimHandle, TIM_CHANNEL_1) != HAL_OK)
  121.   {
  122.     /* Starting Error */
  123.     Error_Handler();
  124.   }
  125.   /* Start channel 2 in Output compare mode */
  126.   if(HAL_TIM_OC_Start_IT(&TimHandle, TIM_CHANNEL_2) != HAL_OK)
  127.   {
  128.     /* Starting Error */
  129.     Error_Handler();
  130.   }
  131.   /* Start channel 3 in Output compare mode */
  132.   if(HAL_TIM_OC_Start_IT(&TimHandle, TIM_CHANNEL_3) != HAL_OK)
  133.   {
  134.     /* Starting Error */
  135.     Error_Handler();
  136.   }
  137.   /* Start channel 4 in Output compare mode */
  138.   if(HAL_TIM_OC_Start_IT(&TimHandle, TIM_CHANNEL_4) != HAL_OK)
  139.   {
  140.     /* Starting Error */
  141.     Error_Handler();
  142.   }
  143.   while (1)
  144.   {}
  145. }
  146. /**
  147.   * @brief  Output Compare callback in non blocking mode
  148.   * @param  htim : TIM OC handle
  149.   * @retval None
  150.   */
  151. void HAL_TIM_OC_DelayElapsedCallback(TIM_HandleTypeDef *htim)
  152. {
  153.   /* TIM1_CH1 toggling with frequency = 244.13 Hz */
  154.   if(htim->Channel == HAL_TIM_ACTIVE_CHANNEL_1)
  155.   {
  156.     uhCapture = HAL_TIM_ReadCapturedValue(htim, TIM_CHANNEL_1);
  157.     /* Set the Capture Compare Register value */
  158.     __HAL_TIM_SET_COMPARE(&TimHandle, TIM_CHANNEL_1, (uhCapture + uhCCR1_Val));
  159.   }
  160.
  161.   /* TIM1_CH2 toggling with frequency = 488.28 Hz */
  162.   if(htim->Channel == HAL_TIM_ACTIVE_CHANNEL_2)
  163.   {
  164.     uhCapture = HAL_TIM_ReadCapturedValue(htim, TIM_CHANNEL_2);
  165.     /* Set the Capture Compare Register value */
  166.     __HAL_TIM_SET_COMPARE(&TimHandle, TIM_CHANNEL_2, (uhCapture + uhCCR2_Val));
  167.   }
  168.
  169.   /* TIM1_CH3 toggling with frequency = 976.56 Hz */
  170.   if(htim->Channel == HAL_TIM_ACTIVE_CHANNEL_3)
  171.   {
  172.     uhCapture = HAL_TIM_ReadCapturedValue(htim, TIM_CHANNEL_3);
  173.     /* Set the Capture Compare Register value */
  174.     __HAL_TIM_SET_COMPARE(&TimHandle, TIM_CHANNEL_3, (uhCapture + uhCCR3_Val));
  175.   }
  176.
  177.   /* TIM1_CH4 toggling with frequency = 1953.12 Hz */
  178.   if(htim->Channel == HAL_TIM_ACTIVE_CHANNEL_4)
  179.   {
  180.     uhCapture = HAL_TIM_ReadCapturedValue(htim, TIM_CHANNEL_4);
  181.     /* Set the Capture Compare Register value */
  182.     __HAL_TIM_SET_COMPARE(&TimHandle, TIM_CHANNEL_4, (uhCapture + uhCCR4_Val));
  183.   }
  184. }
参与人数 1金币 +10 收起 理由
朱日天 + 10
发表于 2020-3-26 23:53:10 | 显示全部楼层
管理员, 我玩这个demo出现了两个问题,
1. 就是不知道为什么, 我只使能了CCR4中断 HAL_TIM_OC_Start_IT(&htim2,TIM_CHANNEL_4);  但是我看SR寄存器为啥是0x1f?, 而且即使在这句话前面加上__HAL_TIM_CLEAR_FLAG(&htim2,TIM_FLAG_UPDATE|TIM_FLAG_CC1|TIM_FLAG_CC2|TIM_FLAG_CC3|TIM_FLAG_CC4);  问题仍然存在
2. 感觉我的中断只能进一次似的;而且cubeide仿真跟容易挂掉, 各种莫名其妙,
以上求解答, 谢谢
/* 定时器回调函�???  */
        uint32_t uhCapture;
        if(htim->Instance == TIM2)
                if(htim->Channel == HAL_TIM_ACTIVE_CHANNEL_1)                //1ms
                        //timerEvent();
                if(htim->Channel == HAL_TIM_ACTIVE_CHANNEL_2)                //10ms
                if(htim->Channel == HAL_TIM_ACTIVE_CHANNEL_3)                //100ms
                if(htim->Channel == HAL_TIM_ACTIVE_CHANNEL_4)                //1000ms
                        LED0_Turn();
//                        uhCapture = HAL_TIM_ReadCapturedValue(&htim2, HAL_TIM_ACTIVE_CHANNEL_4);
//                        __HAL_TIM_SET_COMPARE(&htim2,HAL_TIM_ACTIVE_CHANNEL_1,(uhCapture+1000));
 楼主| 发表于 2020-3-27 00:29:04 | 显示全部楼层
1. 就是不知道为什么, 我只使能了CCR4中断 HAL_TIM_OC_Start_IT ...
你用MDK跑原始的例子正常吗,我这个是早前使用ST的NUCLEO板子测试的,没问题。
发表于 2025-6-11 23:41:35 | 显示全部楼层
有DMA通道剩余就不用频繁进中断了,外面好放数组里,等DMA传输完成再交换DMA传输源,继续算,所以DMA通道要多,而且这种方式适合做脉冲个数和频率控制而不是PWM控制。
GMT+8, 2026-10-24 01:45 , Processed in 0.232826 second(s), 28 queries .
