查看: 4632|回复: 0
[MPU] STM32H7新版库已经升级MPU支持16个域的配置,早期只能配置8个
发表于 2018-7-31 02:18:06 | 显示全部楼层 |阅读模式
  1. /**
  2.   * @brief  Initializes and configures the Region and the memory to be protected.
  3.   * @param  MPU_Init Pointer to a MPU_Region_InitTypeDef structure that contains
  4.   *                the initialization and configuration information.
  5.   * @retval None
  6.   */
  7. void HAL_MPU_ConfigRegion(MPU_Region_InitTypeDef *MPU_Init)
  8. {
  9.   /* Check the parameters */
  10.   assert_param(IS_MPU_REGION_NUMBER(MPU_Init->Number));
  11.   assert_param(IS_MPU_REGION_ENABLE(MPU_Init->Enable));
  12.   /* Set the Region number */
  13.   MPU->RNR = MPU_Init->Number;
  14.   if ((MPU_Init->Enable) != RESET)
  15.   {
  16.     /* Check the parameters */
  17.     assert_param(IS_MPU_INSTRUCTION_ACCESS(MPU_Init->DisableExec));
  18.     assert_param(IS_MPU_REGION_PERMISSION_ATTRIBUTE(MPU_Init->AccessPermission));
  19.     assert_param(IS_MPU_TEX_LEVEL(MPU_Init->TypeExtField));
  20.     assert_param(IS_MPU_ACCESS_SHAREABLE(MPU_Init->IsShareable));
  21.     assert_param(IS_MPU_ACCESS_CACHEABLE(MPU_Init->IsCacheable));
  22.     assert_param(IS_MPU_ACCESS_BUFFERABLE(MPU_Init->IsBufferable));
  23.     assert_param(IS_MPU_SUB_REGION_DISABLE(MPU_Init->SubRegionDisable));
  24.     assert_param(IS_MPU_REGION_SIZE(MPU_Init->Size));
  25.     MPU->RBAR = MPU_Init->BaseAddress;
  26.     MPU->RASR = ((uint32_t)MPU_Init->DisableExec             << MPU_RASR_XN_Pos)   |
  27.                 ((uint32_t)MPU_Init->AccessPermission        << MPU_RASR_AP_Pos)   |
  28.                 ((uint32_t)MPU_Init->TypeExtField            << MPU_RASR_TEX_Pos)  |
  29.                 ((uint32_t)MPU_Init->IsShareable             << MPU_RASR_S_Pos)    |
  30.                 ((uint32_t)MPU_Init->IsCacheable             << MPU_RASR_C_Pos)    |
  31.                 ((uint32_t)MPU_Init->IsBufferable            << MPU_RASR_B_Pos)    |
  32.                 ((uint32_t)MPU_Init->SubRegionDisable        << MPU_RASR_SRD_Pos)  |
  33.                 ((uint32_t)MPU_Init->Size                    << MPU_RASR_SIZE_Pos) |
  34.                 ((uint32_t)MPU_Init->Enable                  << MPU_RASR_ENABLE_Pos);
  35.   }
  36.   else
  37.   {
  38.     MPU->RBAR = 0x00;
  39.     MPU->RASR = 0x00;
  40.   }
  41. }
GMT+8, 2026-10-24 22:21 , Processed in 0.205755 second(s), 27 queries .
