查看: 3832|回复: 0
串口设备操作例程
发表于 2018-7-11 22:54:34 | 显示全部楼层 |阅读模式
* 程序清单:串口设备操作例程
* 在这个例程中,将启动一个devt线程,然后打开串口1和2
* 当串口1和2有输入时,将读取其中的输入数据然后写入到
* 串口1设备中。
#include <rtthread.h>
/* UART接收消息结构*/
struct rx_msg
  rt_device_t dev;
  rt_size_t size;
/* 消息队列控制块 */
static struct rt_messagequeue mq;
  /* 消息队列中用到的放置消息的内存池 */
/* 数据到达回调函数*/
rt_err_t uart_input(rt_device_t dev, rt_size_t size)
  struct rx_msg msg;
  int result;
char buf[] = "this is message No.x";
  msg.dev = dev;
  msg.size = size;
  /* 发送消息到消息队列中*/
  rt_kprintf("Receive From :%s\r\n",dev->parent.name);
/* 发送消息到消息队列中 */
result = rt_mq_send(&mq, &msg, sizeof(msg));
if ( result == -RT_EFULL)
                /* 消息队列满, 延迟1s时间 */
                rt_kprintf("message queue full, delay 1s\n");
                rt_thread_delay(1000);
  return result;
void device_thread_entry(void* parameter)
  struct rx_msg msg;
  int count = 0;
  rt_device_t device, write_device;
  rt_err_t result = RT_EOK;
  static char uart_rx_buffer[64];
  /* 查找系统中的串口1设备 */
  device = rt_device_find("uart1");
  if (device!= RT_NULL)
    /* 设置回调函数及打开设备*/
    rt_device_set_rx_indicate(device, uart_input);
    rt_device_open(device, RT_DEVICE_OFLAG_RDWR|RT_DEVICE_FLAG_INT_RX);
  /* 设置写设备为uart1设备 */
  write_device = device;
  /* 查找系统中的串口2设备 */
  device= rt_device_find("uart2");
    /* 设置回调函数及打开设备*/
  while (1)
   /* 从消息队列中读取消息*/
                rt_memset(&msg, 0, sizeof(msg));
                result = rt_mq_recv(&mq, &msg, sizeof(msg), 50);
    if (result == -RT_ETIMEOUT)
      /* 接收超时*/
      rt_kprintf("timeout count:%d\n", ++count);
    /* 从消息队列中接收消息 */
    if (result == RT_EOK)
      rt_uint32_t rx_length;
      rx_length = (sizeof(uart_rx_buffer) - 1) > msg.size ?
                  msg.size : sizeof(uart_rx_buffer) - 1;
      /* 读取消息*/
      rx_length = rt_device_read(msg.dev, 0, &uart_rx_buffer[0],
                                 rx_length);
      uart_rx_buffer[rx_length] = '\0';
      rt_kprintf("Receive  data:");
      /* 写到写设备中*/
      if (write_device != RT_NULL)
        rt_device_write(write_device, 0, &uart_rx_buffer[0],
                        rx_length);
      rt_kprintf("\r\n");
int rt_application_init()
static char msg_pool[2048];
  /* 初始化消息队列 */
  rt_mq_init(&mq, "mqt",
             &msg_pool[0], /* 内存池指向msg pool */
             128 - sizeof(void*), /* 每个消息的大小是 128 - void* */
             sizeof(msg_pool), /* 内存池的大小是msg pool的大小 */
             RT_IPC_FLAG_FIFO); /* 如果有多个线程等待,按照先来先得到的方法分配消息 */
  /* 创建devt线程*/
  rt_thread_t thread = rt_thread_create("devt",
                                        device_thread_entry, RT_NULL,
                                        2048, 25, 7);
  /* 创建成功则启动线程*/
  if (thread!= RT_NULL)
    rt_thread_startup(thread);
  return 0;
GMT+8, 2026-11-22 22:44 , Processed in 0.463150 second(s), 23 queries .
