查看: 3175|回复: 0
led应用
发表于 2018-7-10 23:01:06 | 显示全部楼层 |阅读模式
* File      : application.c
* This file is part of RT-Thread RTOS
* COPYRIGHT (C) 2006, RT-Thread Development Team
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rt-thread.org/license/LICENSE
* Change Logs:
* Date           Author       Notes
* 2009-01-05     Bernard      the first version
* 2013-07-12     aozima       update for auto initial.
* @addtogroup STM32
#include <board.h>
#include <rtthread.h>
#ifdef RT_USING_DFS
/* dfs filesystem:ELM filesystem init */
#include <dfs_elm.h>
/* dfs Filesystem APIs */
#include <dfs_fs.h>
#endif
#ifdef RT_USING_RTGUI
#include <rtgui/rtgui.h>
#include <rtgui/rtgui_server.h>
#include <rtgui/rtgui_system.h>
#include <rtgui/driver.h>
#include <rtgui/calibration.h>
#endif
#include "led.h"
ALIGN(RT_ALIGN_SIZE)
static rt_uint8_t led_stack[ 512 ];
static struct rt_thread led_thread;
static void led_thread_entry(void* parameter)
    unsigned int count=0;
    rt_hw_led_init();
    while (1)
        /* led1 on */
#ifndef RT_USING_FINSH
        rt_kprintf("led on, count : %d\r\n",count);
#endif
        count++;
        rt_hw_led_on(0);
        rt_thread_delay( RT_TICK_PER_SECOND/2 ); /* sleep 0.5 second and switch to other thread */
        /* led1 off */
        rt_kprintf("led off\r\n");
#endif
        rt_hw_led_off(0);
rt_bool_t cali_setup(void)
    rt_kprintf("cali setup entered\n");
    return RT_FALSE;
void cali_store(struct calibration_data *data)
    rt_kprintf("cali finished (%d, %d), (%d, %d)\n",
               data->min_x,
               data->max_x,
               data->min_y,
               data->max_y);
#endif /* RT_USING_RTGUI */
void rt_init_thread_entry(void* parameter)
#ifdef RT_USING_COMPONENTS_INIT
    /* initialization RT-Thread Components */
    rt_components_init();
#endif
    /* Filesystem Initialization */
#if defined(RT_USING_DFS) && defined(RT_USING_DFS_ELMFAT)
    /* mount sd card fat partition 1 as root directory */
    if (dfs_mount("sd0", "/", "elm", 0, 0) == 0)
        rt_kprintf("File System initialized!\n");
        rt_kprintf("File System initialzation failed!\n");
#endif  /* RT_USING_DFS */
        extern void rt_hw_lcd_init();
        extern void rtgui_touch_hw_init(void);
        rt_device_t lcd;
        /* init lcd */
        rt_hw_lcd_init();
        /* init touch panel */
        rtgui_touch_hw_init();
        /* find lcd device */
        lcd = rt_device_find("lcd");
        /* set lcd device as rtgui graphic driver */
        rtgui_graphic_set_device(lcd);
#ifndef RT_USING_COMPONENTS_INIT
        /* init rtgui system server */
        rtgui_system_server_init();
#endif
        calibration_set_restore(cali_setup);
        calibration_set_after(cali_store);
        calibration_init();
#endif /* #ifdef RT_USING_RTGUI */
int rt_application_init(void)
    rt_thread_t init_thread;
    rt_err_t result;
    /* init led thread */
    result = rt_thread_init(&led_thread,
                            "led",
                            led_thread_entry,
                            RT_NULL,
                            (rt_uint8_t*)&led_stack[0],
                            sizeof(led_stack),
                            20,
                            5);
    if (result == RT_EOK)
        rt_thread_startup(&led_thread);
#if (RT_THREAD_PRIORITY_MAX == 32)
    init_thread = rt_thread_create("init",
                                   rt_init_thread_entry, RT_NULL,
                                   2048, 8, 20);
#else
                                   2048, 80, 20);
#endif
    if (init_thread != RT_NULL)
        rt_thread_startup(init_thread);
    return 0;
GMT+8, 2026-11-22 22:43 , Processed in 0.982864 second(s), 23 queries .
