查看: 2382|回复: 4
printf打印字符串问题
发表于 2018-7-2 11:09:39 | 显示全部楼层 |阅读模式
  1. static char* const _HMI_MODULE_NAME = "HMI";
  2. static char* const _HMI_MODULE_VERSION = "V0.01";
  3. static char* const _HMI_MODULE_DATE = __DATE__;
  4. //for IDataObject instance of  module information
  5. static void* const _HMIModuleInfoTbl[] =
  6. {
  7.         &_HMI_MODULE_NAME,                //MODULE_INFO_DOSID_NAME,
  8.         &_HMI_MODULE_VERSION,        //MODULE_INFO_DOSID_VERSION,
  9.         &_HMI_MODULE_DATE,//MODULE_INFO_DOSID_DATE,
  10. };
  11. 怎么通过_HMIModuleInfoTbl,直接printf那三个字符串啊
发表于 2018-7-2 11:11:15 | 显示全部楼层
ps:先帮你把标题改了,之前的标题非常不好
 楼主| 发表于 2018-7-2 11:17:22 | 显示全部楼层
好的,下次注意
发表于 2018-7-2 14:37:22 | 显示全部楼层
static char const _HMI_MODULE_NAME[] = "HMI";
static char const _HMI_MODULE_VERSION[] = "V0.01";
static char const _HMI_MODULE_DATE[] = __DATE__;
static char const *_HMIModuleInfoTbl[] =
       _HMI_MODULE_DATE,             //MODULE_INFO_DOSID_DATE,
 楼主| 发表于 2018-7-2 14:45:15 | 显示全部楼层
s ...
先谢谢,不过这是别人提供的接口,不能改
有其他办法吗
GMT+8, 2026-11-24 22:41 , Processed in 0.707467 second(s), 24 queries .
