查看: 4714|回复: 3
[CMSIS-RTOS] 特别注意,RTX5的空闲任务和定时器任务的栈空间都是用的全局变量
发表于 2018-5-25 11:41:33 | 显示全部楼层 |阅读模式
空闲任务:
// Idle Thread Control Block
static osRtxThread_t os_idle_thread_cb \
__attribute__((section(".bss.os.thread.cb")));
// Idle Thread Stack
static uint64_t os_idle_thread_stack[OS_IDLE_THREAD_STACK_SIZE/8] \
__attribute__((section(".bss.os.thread.stack")));
// Idle Thread Attributes
static const osThreadAttr_t os_idle_thread_attr = {
#if defined(OS_IDLE_THREAD_NAME)
  OS_IDLE_THREAD_NAME,
#else
  NULL,
#endif
  osThreadDetached,
  &os_idle_thread_cb,
  (uint32_t)sizeof(os_idle_thread_cb),
  &os_idle_thread_stack[0],
  (uint32_t)sizeof(os_idle_thread_stack),
  osPriorityIdle,
#if defined(OS_IDLE_THREAD_TZ_MOD_ID)
  (uint32_t)OS_IDLE_THREAD_TZ_MOD_ID,
#else
  0U,
#endif
  0U
定时器任务:
// Timer Thread Control Block
static osRtxThread_t os_timer_thread_cb \
// Timer Thread Stack
static uint64_t os_timer_thread_stack[OS_TIMER_THREAD_STACK_SIZE/8] \
// Timer Thread Attributes
static const osThreadAttr_t os_timer_thread_attr = {
#if defined(OS_TIMER_THREAD_NAME)
  OS_TIMER_THREAD_NAME,
#else
  NULL,
#endif
  osThreadDetached,
  &os_timer_thread_cb,
  (uint32_t)sizeof(os_timer_thread_cb),
  &os_timer_thread_stack[0],
  (uint32_t)sizeof(os_timer_thread_stack),
  //lint -e{9030} -e{9034} "cast from signed to enum"
  (osPriority_t)OS_TIMER_THREAD_PRIO,
#if defined(OS_TIMER_THREAD_TZ_MOD_ID)
  (uint32_t)OS_TIMER_THREAD_TZ_MOD_ID,
#else
  0U,
#endif
  0U
 楼主| 发表于 2018-5-25 11:43:12 | 显示全部楼层
如果他们是全局变量的话,那么统计的时候,是不会算在RTX5全局内存池里面的,这点正是此贴要说明的。
发表于 2018-5-25 21:13:19 | 显示全部楼层
是的,因为这些代码实际是在中断例程里运行,所以还得注意代码短小,不要使用阻塞代码
 楼主| 发表于 2018-5-26 02:06:50 | 显示全部楼层
myxiaonia兄好 ,
GMT+8, 2026-11-25 21:57 , Processed in 0.641121 second(s), 27 queries .
