查看: 7623|回复: 4
[Clock] 面对RT1052复杂的时钟配置,使用软件MCUXpresso Config Tools方可一目了然
发表于 2018-5-4 02:34:20 | 显示全部楼层 |阅读模式
    官方评估板的时钟配置代码是通过这个软件生成的,即clock_config.c文件。首次使用这个软件务必要将clock_config.c文件中的函数在配置软件MCUXpresso Config Tools一个一个捋顺一遍,这样心理就踏实多了,要不老是感觉那里没有整明白。官网下载地址:链接
1、根据自己的电脑系统版本选择即可,操作几次基本就熟练了。
2、软件效果:
3、比如配置了个SDRAM的时钟,一目了然:
 楼主| 发表于 2018-5-4 02:36:36 | 显示全部楼层
举例clock_config.c中的配置:
  1. /*
  2. * The Clear BSD License
  3. * Copyright 2017 NXP
  4. * All rights reserved.
  5. *
  6. * Redistribution and use in source and binary forms, with or without modification,
  7. * are permitted (subject to the limitations in the disclaimer below) provided
  8. *  that the following conditions are met:
  9. *
  10. * o Redistributions of source code must retain the above copyright notice, this list
  11. *   of conditions and the following disclaimer.
  12. *
  13. * o Redistributions in binary form must reproduce the above copyright notice, this
  14. *   list of conditions and the following disclaimer in the documentation and/or
  15. *   other materials provided with the distribution.
  16. *
  17. * o Neither the name of the copyright holder nor the names of its
  18. *   contributors may be used to endorse or promote products derived from this
  19. *   software without specific prior written permission.
  20. *
  21. * NO EXPRESS OR IMPLIED LICENSES TO ANY PARTY'S PATENT RIGHTS ARE GRANTED BY THIS LICENSE.
  22. * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
  23. * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
  24. * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  25. * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR
  26. * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
  27. * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
  28. * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON
  29. * ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
  30. * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
  31. * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
  32. */
  33. /*
  34. * How to setup clock using clock driver functions:
  35. *
  36. * 1. Call CLOCK_InitXXXPLL() to configure corresponding PLL clock.
  37. *
  38. * 2. Call CLOCK_InitXXXpfd() to configure corresponding PLL pfd clock.
  39. *
  40. * 3. Call CLOCK_SetMux() to configure corresponding clock source for target clock out.
  41. *
  42. * 4. Call CLOCK_SetDiv() to configure corresponding clock divider for target clock out.
  43. *
  44. * 5. Call CLOCK_SetXtalFreq() to set XTAL frequency based on board settings.
  45. *
  46. */
  47. /* TEXT BELOW IS USED AS SETTING FOR TOOLS *************************************
  48. !!GlobalInfo
  49. product: Clocks v4.0
  50. processor: MIMXRT1052xxxxx
  51. package_id: MIMXRT1052DVL6B
  52. mcu_data: i_mx_1_0
  53. processor_version: 0.0.0
  54. board: IMXRT1050-EVKB
  55. * BE CAREFUL MODIFYING THIS COMMENT - IT IS YAML SETTINGS FOR TOOLS **********/
  56. #include "clock_config.h"
  57. /*******************************************************************************
  58. * Definitions
  59. ******************************************************************************/
  60. /*******************************************************************************
  61. * Variables
  62. ******************************************************************************/
  63. /* System clock frequency. */
  64. extern uint32_t SystemCoreClock;
  65. /*******************************************************************************
  66. ************************ BOARD_InitBootClocks function ************************
  67. ******************************************************************************/
  68. void BOARD_InitBootClocks(void)
  69. {
  70.     BOARD_BootClockRUN();
  71. }
  72. /*******************************************************************************
  73. ********************** Configuration BOARD_BootClockRUN ***********************
  74. ******************************************************************************/
  75. /* TEXT BELOW IS USED AS SETTING FOR TOOLS *************************************
  76. !!Configuration
  77. name: BOARD_BootClockRUN
  78. called_from_default_init: true
  79. outputs:
  80. - {id: AHB_CLK_ROOT.outFreq, value: 600 MHz}
  81. - {id: CAN_CLK_ROOT.outFreq, value: 40 MHz}
  82. - {id: CKIL_SYNC_CLK_ROOT.outFreq, value: 32.768 kHz}
  83. - {id: CLK_1M.outFreq, value: 1 MHz}
  84. - {id: CSI_CLK_ROOT.outFreq, value: 12 MHz}
  85. - {id: ENET_125M_CLK.outFreq, value: 2.4 MHz}
  86. - {id: ENET_25M_REF_CLK.outFreq, value: 1.2 MHz}
  87. - {id: FLEXIO1_CLK_ROOT.outFreq, value: 30 MHz}
  88. - {id: FLEXIO2_CLK_ROOT.outFreq, value: 30 MHz}
  89. - {id: FLEXSPI_CLK_ROOT.outFreq, value: 37.5 MHz}
  90. - {id: IPG_CLK_ROOT.outFreq, value: 150 MHz}
  91. - {id: LCDIF_CLK_ROOT.outFreq, value: 67.5 MHz}
  92. - {id: LPI2C_CLK_ROOT.outFreq, value: 60 MHz}
  93. - {id: LPSPI_CLK_ROOT.outFreq, value: 105.6 MHz}
  94. - {id: LVDS1_CLK.outFreq, value: 1.2 GHz}
  95. - {id: PERCLK_CLK_ROOT.outFreq, value: 75 MHz}
  96. - {id: PLL7_MAIN_CLK.outFreq, value: 24 MHz}
  97. - {id: SAI1_CLK_ROOT.outFreq, value: 1080/17 MHz}
  98. - {id: SAI2_CLK_ROOT.outFreq, value: 1080/17 MHz}
  99. - {id: SAI3_CLK_ROOT.outFreq, value: 1080/17 MHz}
  100. - {id: SEMC_CLK_ROOT.outFreq, value: 75 MHz}
  101. - {id: SPDIF0_CLK_ROOT.outFreq, value: 30 MHz}
  102. - {id: TRACE_CLK_ROOT.outFreq, value: 352/3 MHz}
  103. - {id: UART_CLK_ROOT.outFreq, value: 80 MHz}
  104. - {id: USDHC1_CLK_ROOT.outFreq, value: 198 MHz}
  105. - {id: USDHC2_CLK_ROOT.outFreq, value: 198 MHz}
  106. settings:
  107. - {id: CCM.AHB_PODF.scale, value: '1', locked: true}
  108. - {id: CCM.ARM_PODF.scale, value: '2', locked: true}
  109. - {id: CCM.LPSPI_PODF.scale, value: '5', locked: true}
  110. - {id: CCM.PERCLK_PODF.scale, value: '2', locked: true}
  111. - {id: CCM.SEMC_PODF.scale, value: '8'}
  112. - {id: CCM.TRACE_PODF.scale, value: '3', locked: true}
  113. - {id: CCM_ANALOG.PLL1_BYPASS.sel, value: CCM_ANALOG.PLL1}
  114. - {id: CCM_ANALOG.PLL1_PREDIV.scale, value: '1', locked: true}
  115. - {id: CCM_ANALOG.PLL1_VDIV.scale, value: '50', locked: true}
  116. - {id: CCM_ANALOG.PLL2.denom, value: '1', locked: true}
  117. - {id: CCM_ANALOG.PLL2.num, value: '0', locked: true}
  118. - {id: CCM_ANALOG.PLL2_BYPASS.sel, value: CCM_ANALOG.PLL2_OUT_CLK}
  119. - {id: CCM_ANALOG.PLL2_PFD0_BYPASS.sel, value: CCM_ANALOG.PLL2_PFD0}
  120. - {id: CCM_ANALOG.PLL2_PFD1_BYPASS.sel, value: CCM_ANALOG.PLL2_PFD1}
  121. - {id: CCM_ANALOG.PLL2_PFD2_BYPASS.sel, value: CCM_ANALOG.PLL2_PFD2}
  122. - {id: CCM_ANALOG.PLL2_PFD3_BYPASS.sel, value: CCM_ANALOG.PLL2_PFD3}
  123. - {id: CCM_ANALOG.PLL3_BYPASS.sel, value: CCM_ANALOG.PLL3}
  124. - {id: CCM_ANALOG.PLL3_PFD0_BYPASS.sel, value: CCM_ANALOG.PLL3_PFD0}
  125. - {id: CCM_ANALOG.PLL3_PFD1_BYPASS.sel, value: CCM_ANALOG.PLL3_PFD1}
  126. - {id: CCM_ANALOG.PLL3_PFD2_BYPASS.sel, value: CCM_ANALOG.PLL3_PFD2}
  127. - {id: CCM_ANALOG.PLL3_PFD3_BYPASS.sel, value: CCM_ANALOG.PLL3_PFD3}
  128. - {id: CCM_ANALOG.PLL4.denom, value: '50'}
  129. - {id: CCM_ANALOG.PLL4.div, value: '47'}
  130. - {id: CCM_ANALOG.PLL5.denom, value: '1'}
  131. - {id: CCM_ANALOG.PLL5.div, value: '40'}
  132. - {id: CCM_ANALOG.PLL5.num, value: '0'}
  133. - {id: CCM_ANALOG_PLL_USB1_POWER_CFG, value: 'Yes'}
  134. sources:
  135. - {id: XTALOSC24M.OSC.outFreq, value: 24 MHz, enabled: true}
  136. - {id: XTALOSC24M.RTC_OSC.outFreq, value: 32.768 kHz, enabled: true}
  137. * BE CAREFUL MODIFYING THIS COMMENT - IT IS YAML SETTINGS FOR TOOLS **********/
  138. /*******************************************************************************
  139. * Variables for BOARD_BootClockRUN configuration
  140. ******************************************************************************/
  141. const clock_arm_pll_config_t armPllConfig_BOARD_BootClockRUN = {
  142.     .loopDivider = 88, /* PLL loop divider, Fout = Fin * 50 */
  143. };
  144. const clock_sys_pll_config_t sysPllConfig_BOARD_BootClockRUN = {
  145.     .loopDivider = 1,                         /* PLL loop divider, Fout = Fin * ( 20 + loopDivider*2 + numerator / denominator ) */
  146.     .numerator = 0,                           /* 30 bit numerator of fractional loop divider */
  147.     .denominator = 1,                         /* 30 bit denominator of fractional loop divider */
  148. };
  149. const clock_usb_pll_config_t usb1PllConfig_BOARD_BootClockRUN = {
  150.     .loopDivider = 0, /* PLL loop divider, Fout = Fin * 20 */
  151. };
  152. /*******************************************************************************
  153. * Code for BOARD_BootClockRUN configuration
  154. ******************************************************************************/
  155. void BOARD_BootClockRUN(void)
  156. {
  157.     /* Init RTC OSC clock frequency. */
  158.     CLOCK_SetRtcXtalFreq(32768U);
  159.     /* Set XTAL 24MHz clock frequency. */
  160.     CLOCK_SetXtalFreq(24000000U);
  161.     /* Setting PeriphClk2Mux and PeriphMux to provide stable clock before PLLs are initialed */
  162.     CLOCK_SetMux(kCLOCK_PeriphClk2Mux, 1); /* Set PERIPH_CLK2 MUX to OSC */
  163.     CLOCK_SetMux(kCLOCK_PeriphMux, 1);     /* Set PERIPH_CLK MUX to PERIPH_CLK2 */
  164.     /* Setting the VDD_SOC to 1.5V. It is necessary to config AHB to 600Mhz. */
  165.     DCDC->REG3 = (DCDC->REG3 & (~DCDC_REG3_TRG_MASK)) | DCDC_REG3_TRG(0x12);
  166.     /* Waiting for DCDC_STS_DC_OK bit is asserted */
  167.     while (DCDC_REG0_STS_DC_OK_MASK != (DCDC_REG0_STS_DC_OK_MASK & DCDC->REG0))
  168.     {
  169.     }
  170.     /* Init ARM PLL. */
  171.     CLOCK_InitArmPll(&armPllConfig_BOARD_BootClockRUN);
  172.     /* Init System PLL. */
  173. #ifndef SKIP_SYSCLK_INIT
  174.     CLOCK_InitSysPll(&sysPllConfig_BOARD_BootClockRUN);
  175. #endif
  176.     /* Init Usb1 PLL. */
  177. #if !(defined(XIP_EXTERNAL_FLASH) && (XIP_EXTERNAL_FLASH == 1))
  178.     CLOCK_InitUsb1Pll(&usb1PllConfig_BOARD_BootClockRUN);
  179. #endif
  180.     /* Enbale Audio PLL output. */
  181.     CCM_ANALOG->PLL_AUDIO |= CCM_ANALOG_PLL_AUDIO_ENABLE_MASK;
  182.     /* Enbale Video PLL output. */
  183.     CCM_ANALOG->PLL_VIDEO |= CCM_ANALOG_PLL_VIDEO_ENABLE_MASK;
  184.     /* Enable ENET PLL output. */
  185.     CCM_ANALOG->PLL_ENET |= CCM_ANALOG_PLL_ENET_ENABLE_MASK;
  186.     CCM_ANALOG->PLL_ENET |= CCM_ANALOG_PLL_ENET_ENET_25M_REF_EN_MASK;
  187.     /* Set periph clock2 clock source. */
  188.     CLOCK_SetMux(kCLOCK_PeriphClk2Mux, 0);
  189.     /* Set PERIPH_CLK2_PODF. */
  190.     CLOCK_SetDiv(kCLOCK_PeriphClk2Div, 0);
  191.     /* Set periph clock source. */
  192.     CLOCK_SetMux(kCLOCK_PeriphMux, 0);
  193.     /* Set AHB_PODF. */
  194.     CLOCK_SetDiv(kCLOCK_AhbDiv, 0);
  195.     /* Set IPG_PODF. */
  196.     CLOCK_SetDiv(kCLOCK_IpgDiv, 3);
  197.     /* Set ARM_PODF. */
  198.     CLOCK_SetDiv(kCLOCK_ArmDiv, 1);
  199.     /* Set preperiph clock source. */
  200.     CLOCK_SetMux(kCLOCK_PrePeriphMux, 3);
  201.     /* Set PERCLK_PODF. */
  202.     CLOCK_SetDiv(kCLOCK_PerclkDiv, 1);
  203.     /* Set per clock source. */
  204.     CLOCK_SetMux(kCLOCK_PerclkMux, 0);
  205.     /* Set Usdhc1 clock source. */
  206.     CLOCK_SetMux(kCLOCK_Usdhc1Mux, 0);
  207.     /* Set USDHC1_PODF. */
  208.     CLOCK_SetDiv(kCLOCK_Usdhc1Div, 1);
  209.     /* Set Usdhc2 clock source. */
  210.     CLOCK_SetMux(kCLOCK_Usdhc2Mux, 0);
  211.     /* Set USDHC2_PODF. */
  212.     CLOCK_SetDiv(kCLOCK_Usdhc2Div, 1);
  213. #ifndef SKIP_SYSCLK_INIT
  214.     /* Set Semc alt clock source. */
  215.     CLOCK_SetMux(kCLOCK_SemcAltMux, 0);
  216.     /* Set Semc clock source. */
  217.     CLOCK_SetMux(kCLOCK_SemcMux, 0);
  218.     /* Set SEMC_PODF. */
  219.     CLOCK_SetDiv(kCLOCK_SemcDiv, 7);
  220. #endif
  221. #if !(defined(XIP_EXTERNAL_FLASH) && (XIP_EXTERNAL_FLASH == 1))
  222.     /* Set Flexspi clock source. */
  223.     CLOCK_SetMux(kCLOCK_FlexspiMux, 0);
  224.     /* Set FLEXSPI_PODF. */
  225.     CLOCK_SetDiv(kCLOCK_FlexspiDiv, 1);
  226. #endif
  227.     /* Set Csi clock source. */
  228.     CLOCK_SetMux(kCLOCK_CsiMux, 0);
  229.     /* Set CSI_PODF. */
  230.     CLOCK_SetDiv(kCLOCK_CsiDiv, 1);
  231.     /* Set Lpspi clock source. */
  232.     CLOCK_SetMux(kCLOCK_LpspiMux, 2);
  233.     /* Set LPSPI_PODF. */
  234.     CLOCK_SetDiv(kCLOCK_LpspiDiv, 4);
  235.     /* Set Trace clock source. */
  236.     CLOCK_SetMux(kCLOCK_TraceMux, 2);
  237.     /* Set TRACE_PODF. */
  238.     CLOCK_SetDiv(kCLOCK_TraceDiv, 2);
  239.     /* Set Sai1 clock source. */
  240.     CLOCK_SetMux(kCLOCK_Sai1Mux, 0);
  241.     /* Set SAI1_CLK_PRED. */
  242.     CLOCK_SetDiv(kCLOCK_Sai1PreDiv, 3);
  243.     /* Set SAI1_CLK_PODF. */
  244.     CLOCK_SetDiv(kCLOCK_Sai1Div, 1);
  245.     /* Set Sai2 clock source. */
  246.     CLOCK_SetMux(kCLOCK_Sai2Mux, 0);
  247.     /* Set SAI2_CLK_PRED. */
  248.     CLOCK_SetDiv(kCLOCK_Sai2PreDiv, 3);
  249.     /* Set SAI2_CLK_PODF. */
  250.     CLOCK_SetDiv(kCLOCK_Sai2Div, 1);
  251.     /* Set Sai3 clock source. */
  252.     CLOCK_SetMux(kCLOCK_Sai3Mux, 0);
  253.     /* Set SAI3_CLK_PRED. */
  254.     CLOCK_SetDiv(kCLOCK_Sai3PreDiv, 3);
  255.     /* Set SAI3_CLK_PODF. */
  256.     CLOCK_SetDiv(kCLOCK_Sai3Div, 1);
  257.     /* Set Lpi2c clock source. */
  258.     CLOCK_SetMux(kCLOCK_Lpi2cMux, 0);
  259.     /* Set LPI2C_CLK_PODF. */
  260.     CLOCK_SetDiv(kCLOCK_Lpi2cDiv, 0);
  261.     /* Set Can clock source. */
  262.     CLOCK_SetMux(kCLOCK_CanMux, 2);
  263.     /* Set CAN_CLK_PODF. */
  264.     CLOCK_SetDiv(kCLOCK_CanDiv, 1);
  265.     /* Set Uart clock source. */
  266.     CLOCK_SetMux(kCLOCK_UartMux, 0);
  267.     /* Set UART_CLK_PODF. */
  268.     CLOCK_SetDiv(kCLOCK_UartDiv, 0);
  269.     /* Set Lcdif pre clock source. */
  270.     CLOCK_SetMux(kCLOCK_LcdifPreMux, 5);
  271.     /* Set LCDIF_PRED. */
  272.     CLOCK_SetDiv(kCLOCK_LcdifPreDiv, 1);
  273.     /* Set LCDIF_CLK_PODF. */
  274.     CLOCK_SetDiv(kCLOCK_LcdifDiv, 3);
  275.     /* Set Spdif clock source. */
  276.     CLOCK_SetMux(kCLOCK_SpdifMux, 3);
  277.     /* Set SPDIF0_CLK_PRED. */
  278.     CLOCK_SetDiv(kCLOCK_Spdif0PreDiv, 1);
  279.     /* Set SPDIF0_CLK_PODF. */
  280.     CLOCK_SetDiv(kCLOCK_Spdif0Div, 7);
  281.     /* Set Flexio1 clock source. */
  282.     CLOCK_SetMux(kCLOCK_Flexio1Mux, 3);
  283.     /* Set FLEXIO1_CLK_PRED. */
  284.     CLOCK_SetDiv(kCLOCK_Flexio1PreDiv, 1);
  285.     /* Set FLEXIO1_CLK_PODF. */
  286.     CLOCK_SetDiv(kCLOCK_Flexio1Div, 7);
  287.     /* Set Flexio2 clock source. */
  288.     CLOCK_SetMux(kCLOCK_Flexio2Mux, 3);
  289.     /* Set FLEXIO2_CLK_PRED. */
  290.     CLOCK_SetDiv(kCLOCK_Flexio2PreDiv, 1);
  291.     /* Set FLEXIO2_CLK_PODF. */
  292.     CLOCK_SetDiv(kCLOCK_Flexio2Div, 7);
  293.     /* Set Pll3 sw clock source. */
  294.     CLOCK_SetMux(kCLOCK_Pll3SwMux, 0);
  295.     /* Set lvds1 clock source. */
  296.     CCM_ANALOG->MISC1 =
  297.         (CCM_ANALOG->MISC1 & (~CCM_ANALOG_MISC1_LVDS1_CLK_SEL_MASK)) | CCM_ANALOG_MISC1_LVDS1_CLK_SEL(0);
  298.     /* Set SystemCoreClock variable. */
  299.     SystemCoreClock = BOARD_BOOTCLOCKRUN_CORE_CLOCK;
  300. }
发表于 2018-5-18 16:13:04 | 显示全部楼层
能不能详细介绍一下怎么打开这个时钟配置界面的,我用该软件时报不支持该处理器
 楼主| 发表于 2018-5-18 16:15:48 | 显示全部楼层
好的,今天晚些时候我发个帖子。
 楼主| 发表于 2018-5-19 00:41:14 | 显示全部楼层
发了个帖子:
https://forum.anfulai.cn/forum.php?mod=viewthread&tid=86732
GMT+8, 2026-11-23 04:52 , Processed in 0.199669 second(s), 27 queries .
