查看: 6568|回复: 5
[物联网] 各种语言版本的MQTT实现
发表于 2018-5-2 01:24:38 | 显示全部楼层 |阅读模式
https://github.com/mqtt/mqtt.github.io/wiki/libraries
Note: although there are a range of options available for developers interested in MQTT, not all of the client APIs listed below are current. Some are at an early or experimental stage of development, whilst others are stable and mature. Additionally, some may not provide full support for all of the features of the latest MQTT specification – for example, some may only support QoS 0, not include authentication, etc.
Check with the provider for the current status of your preferred language implementation; and remember to respect the licenses that different implementations are published under.
Device-Specific
(see also devices page for more on hardware with built-in support)
ActionscriptBashCC++ClojureDartDelphiErlangElixir
  • hulaaki - An Elixir library (driver) for clients communicating with MQTT brokers(via the MQTT 3.1.1 protocol).
  • Exmqttc - Elixir wrapper for the emqttc library.
GoHaskellJavaJavascript / Node.jsLotusScriptLua.NET / dotNETObjective-COCamlPerlPHPPythonREXXProlog
  • MQTT Pack - Mosquitto library as a SWI-Prolog pack
RubyQt
  • qmqtt - MQTT Client for Qt
Shell Script
  • bish-bosh, supports bash, ash (including BusyBox), pdksh and mksh.
SmalltalkSwift
  • CocoaMQTT - An MQTT client for iOS and OS X written with Swift
Tcl
 楼主| 发表于 2018-5-2 01:24:52 | 显示全部楼层
发表于 2018-5-4 09:37:14 | 显示全部楼层
硬汉是要开始搞MQTT了吗?
 楼主| 发表于 2018-5-4 10:06:32 | 显示全部楼层
5261zgj 发表于 2018-5-4 09:37
硬汉是要开始搞MQTT了吗?
无意中看到了,先收藏下,方便以后弄。
发表于 2018-5-4 22:38:12 | 显示全部楼层
收藏了,准备搞MQTT。
发表于 2018-5-28 07:05:22 | 显示全部楼层
现在MQTT也不需要搞什么了,已经出了不少GSM模组,里边直接集成MQTT协议了。也就是不超过十个AT指令的事了。本来还准备在研究一下在STM32内实现,反正要用gsm模组。直接用集成的就完了。
GMT+8, 2026-11-25 12:02 , Processed in 1.351019 second(s), 24 queries .
