查看: 2827|回复: 4
[emWin] 关闭对话框还显示的疑惑
发表于 2018-3-30 11:23:56 | 显示全部楼层 |阅读模式
对话框回调函数执行GUI_EndDialog后界面就不该显示对话框了吧?我用模拟器是可以的,关闭对话框后只显示背景窗口,但是我在IAR工程里面执行相同的代码对话框的内容还是显示?请教各位大佬,这是什么原因?小弟先拜谢了。
具体代码如下:
#define ID_FRAMEWIN_0 (GUI_ID_USER + 0x00)
#define ID_EDIT_0     (GUI_ID_USER + 0x01)
#define ID_EDIT_1     (GUI_ID_USER + 0x02)
#define WM_UPDATE (WM_USER + 0x00) /* 自定义消息 */
*                               GUI_WIDGET_CREATE_INFO类型数组
static const GUI_WIDGET_CREATE_INFO _aDialogCreate[] =
        { FRAMEWIN_CreateIndirect, "Framewin", ID_FRAMEWIN_0, 0, 0, 160, 128, 0, 0x64, 0 },
    { EDIT_CreateIndirect, "Edit", ID_EDIT_1, 38, 49, 81, 27, 0, 0x64, 0 },
*        函 数 名: _cbDialog
*        功能说明: 对话框回调函数
*        形    参: pMsg  回调参数
*        返 回 值: 无
static void _cbDialog(WM_MESSAGE * pMsg)
        WM_HWIN hItem;
        int     NCode;
        int     Id;
        WM_HWIN hDlg;
        hDlg = pMsg->hWin;
        switch (pMsg->MsgId)
                case WM_INIT_DIALOG:
                        // 初始化框架窗口
                        hItem = pMsg->hWin;
                        FRAMEWIN_SetFont(hItem, GUI_FONT_32B_ASCII);
                        FRAMEWIN_SetTextAlign(hItem, GUI_TA_HCENTER | GUI_TA_VCENTER);
                        FRAMEWIN_SetText(hItem, "armfly");
                        // 初始化编辑框
                        //hItem = WM_GetDialogItem(pMsg->hWin, ID_EDIT_0);
                        //EDIT_SetText(hItem, "1024");
                        //EDIT_SetFont(hItem, GUI_FONT_24B_ASCII);
                        // 初始化编辑框
                        hItem = WM_GetDialogItem(pMsg->hWin, ID_EDIT_1);
                        EDIT_SetTextAlign(hItem, GUI_TA_LEFT | GUI_TA_VCENTER);
                        EDIT_SetSel(hItem, 0, -1);  /* 设置选中编辑框中所有文本 */
        case  WM_UPDATE:
                                     EDIT_SetText(hItem, "1356");
                case WM_KEY:
                       switch (((WM_KEY_INFO*)(pMsg->Data.p))->Key)
                        case GUI_KEY_ESCAPE:
                             GUI_EndDialog(hDlg, 1);
                        case GUI_KEY_ENTER:
                             GUI_EndDialog(hDlg, 0);
                case WM_NOTIFY_PARENT:
                        NCode = pMsg->Data.v;
                        switch(Id)
                                case ID_EDIT_0:
                                        switch(NCode)
                                                case WM_NOTIFICATION_CLICKED:
                                                case WM_NOTIFICATION_VALUE_CHANGED:
                                case ID_EDIT_1:
                                        switch(NCode)
              case WM_PAINT:
                      // PaintWin(pMsg);
                default:
                        WM_DefaultProc(pMsg);
*       _cbBkWindow
static void _cbBkWindow(WM_MESSAGE * pMsg)
  //unsigned i;
  case WM_PAINT:
    GUI_SetBkColor(GUI_BLUE);
    GUI_Clear();
    GUI_SetColor(GUI_WHITE);
    GUI_SetFont(&GUI_Font24_ASCII);
    GUI_DispStringHCenterAt("Counting Sample", 80, 5);
    default:
void MainTask(void)
     WM_SetCreateFlags(WM_CF_MEMDEV);  // Use memory devices on all windows to avoid flicker
    GUI_Init();
  // Check if recommended memory for the sample is available
  if (GUI_ALLOC_GetNumFreeBytes() < RECOMMENDED_MEMORY) {
    GUI_ErrorOut("Not enough memory available.");
    return;
  WM_SetCallback(WM_HBKWIN, &_cbBkWindow);
  GUI_CreateDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), &_cbDialog, 0, 0, 0);
  while(1)
               WM_Exec();
                GUI_Exec();
            //GUI_Delay(1000);
                GUI_SendKeyMsg(GUI_KEY_ENTER,1); /*直接发消息关闭对话框*/
St 实际显示结果
St 实际显示结果
模拟器显示结果
模拟器显示结果
 楼主| 发表于 2018-3-30 11:36:09 | 显示全部楼层
自己先顶一个,希望高手能指点迷津!
发表于 2018-3-30 14:15:09 | 显示全部楼层
帮你在我们的板子上面测试下,你这个程序没问题的
 楼主| 发表于 2018-3-30 14:48:03 | 显示全部楼层
谢谢硬汉,不知道是不是移植不正常导致的。如果使用SysTick_Handler中断,OS_TimeMS变量加到某个值就不再进入中断了。所以我就不用GUI_Delay,直接调用GUI_Exec刷新界面。
发表于 2018-3-30 17:52:47 | 显示全部楼层
冯超 发表于 2018-3-30 14:48
谢谢硬汉,不知道是不是移植不正常导致的。如果使用SysTick_Handler中断,OS_TimeMS变量加到某个值就不再 ...
估计是你移植的程序模板有问题。
GMT+8, 2026-11-23 13:12 , Processed in 0.173591 second(s), 33 queries .
