查看: 5588|回复: 1
[有问必答] I2S+pt8211实现音频播放.WAV文件
发表于 2018-3-20 20:14:09 | 显示全部楼层 |阅读模式
播放速率,声道,数据长度如何配置
pll_config_t audio_pll_config = {
        .desiredRate = 24576000U, .inputRate = 12000000U,
    pll_setup_t audio_pll_setup;
    CLOCK_EnableClock(kCLOCK_Iocon);
     /* Initialize AUDIO PLL clock */
    CLOCK_SetupAudioPLLData(&audio_pll_config, &audio_pll_setup);
    audio_pll_setup.flags = PLL_SETUPFLAG_POWERUP | PLL_SETUPFLAG_WAITLOCK;
    CLOCK_SetupAudioPLLPrec(&audio_pll_setup, audio_pll_setup.flags);
    /* I2S clocks */
    CLOCK_AttachClk(kAUDIO_PLL_to_FLEXCOMM6);
    /* Attach AUDIO PLL clock to MCLK for I2S, no divider */
    CLOCK_AttachClk(kAUDIO_PLL_to_MCLK);
    SYSCON->MCLKDIV = SYSCON_MCLKDIV_DIV(0U);
    SYSCON->MCLKIO = 1U;
    /* reset FLEXCOMM for I2S */
    RESET_PeripheralReset(kFC6_RST_SHIFT_RSTn);
    /* Enable interrupts for I2S */
    EnableIRQ(FLEXCOMM6_IRQn);
     * masterSlave = kI2S_MasterSlaveNormalMaster;
     * mode = kI2S_ModeI2sClassic;
     * rightLow = false;
     * leftJust = false;
     * pdmData = false;
     * sckPol = false;
     * wsPol = false;
     * divider = 1;
     * oneChannel = false;
     * dataLength = 16;
     * frameLength = 32;
     * position = 0;
     * watermark = 4;
     * txEmptyZero = true;
     * pack48 = false;
    I2S_TxGetDefaultConfig(&s_TxConfig);
    s_TxConfig.divider = I2S_CLOCK_DIVIDER;
    I2S_TxInit(PT8211_I2S_TX, &s_TxConfig);
    DMA_Init(PT8211_DMA);
    DMA_EnableChannel(PT8211_DMA, PT8211_I2S_TX_CHANNEL);
    DMA_SetChannelPriority(PT8211_DMA, PT8211_I2S_TX_CHANNEL, kDMA_ChannelPriority3);
    DMA_CreateHandle(&s_DmaTxHandle, PT8211_DMA, PT8211_I2S_TX_CHANNEL);
发表于 2018-3-21 11:00:22 | 显示全部楼层
参考我们V6板子的音乐播放器例子即可,将WAV的格式信息和配置摘录出来
https://forum.anfulai.cn/forum.php?mod=viewthread&tid=23687
GMT+8, 2026-11-28 14:35 , Processed in 0.146960 second(s), 24 queries .
