查看: 5526|回复: 2
[LibJPEG] 【LibJPEG专题系列七】如何查看Usenet上的JPEG图像
春暖花开
发表于 2015-4-16 17:00:21 | 显示全部楼层 |阅读模式
    Section - [7] How do I view JPEG images posted on Usenet?
Image files posted on the alt.binaries.pictures.* newsgroups are usually "uuencoded".  Uuencoding converts binary
image data into text that can safely be posted.  Most posters also divide large posts into multiple parts, since some
news software can't cope with big articles.  Before your viewer will recognize the image, you must combine the parts
into one file and run the text through a uudecode program.  (This is all true for GIF as well as JPEG, by the way.)
There are programs available to automate this process.
For more info see the alt.binaries.pictures FAQ, which is available fromhttp://www.faqs.org/faqs/pictures-faq/
(see also "[24] Where are FAQ lists archived?").
努力打造安富莱高质量微信公众号:点击扫描图片关注
春暖花开
 楼主| 发表于 2015-4-16 17:01:18 | 显示全部楼层
             Section 7—如何查看Usenet上的JPEG图像?
    公布在alt.binaries.pictures.* newsgroups(新闻组)的图像文件通常是uuencode编码的。Uuencode编码将二进制
图像数据转化为可以被安全发布的文本。由于一些新闻软件无法处理大型的文章,大多数的海报也将大型的帖子分为
多个部分。在查看器识别图像之前,你必须将这些小部分合并成一个文件,然后通过一个uuencode程序来运行此文本。
(顺便一提的,不管对于GIF还是JPEG这都是真实的。)可以自动实现这一过程的程序也还是有的。
     更多信息请浏览alt.binaries.pictures-FAQ(常见问题解答),可点击网址http://www.faqs.org/faqs/pictures-faq/
(也可见[24]存档的FAQ列表 )
发表于 2015-4-16 22:30:49 | 显示全部楼层
楼主你怎么总是转发硬汉的文章,我看到这个论坛里你发的资料全部是出自硬汉之手,文中未见有你本人的一点见解.你这样转发简直就是浪费网络资源...[s:133] [s:133] [s:133] [s:133] [s:133] [s:133]
GMT+8, 2026-11-23 07:29 , Processed in 0.312445 second(s), 24 queries .
