查看: 3694|回复: 4
[有问必答] 咨询下V5开发板的串口FIFO例程
发表于 2018-3-2 10:28:59 | 显示全部楼层 |阅读模式
  1.   while (1)
  2.                 {
  3.                         uint16_t usCount;
  4.                         DISABLE_INT();
  5.                         usCount = _pUart->usTxCount;
  6.                         ENABLE_INT();
  7.                         if (usCount < _pUart->usTxBufSize)
  8.                         {
  9.                                 break;
  10.                         }
  11.                 }
记得V4开发板代码还有注释有BUG,V5代码没改呀。
发表于 2018-3-2 10:34:44 | 显示全部楼层
这个不用管,只要你发的数据没有超过FIFO大小,就不会卡在里面。
 楼主| 发表于 2018-3-2 14:43:23 | 显示全部楼层
好的
发表于 2018-3-3 18:00:44 | 显示全部楼层
************linux2.4里面提取精简测试过的fifo模块********************************************************
*                         (c) Copyright 2007-2020; , Inc.; , FL
*               All rights reserved.  Protected by international copyright laws.
*               Knowledge of the source code may NOT be used to develop a similar product.
*               Please help us continue to provide the Embedded community with the finest
*               software available.  Your honesty is greatly appreciated.
*                                        includes
* Description :
* Note(s)     :
#include <kfifo.h>
int __kfifo_init(struct __kfifo *fifo, void *buffer, unsigned int size)
    fifo->in = 0;
    fifo->out = 0;
    fifo->mask = 0;
    fifo->data = buffer;
    if (size < 2) {
        return -1;
    if ((size & (size-1)) != 0)
        return -2;            /*** Must be a power of 2 (2,4,8,16,32,64,128,256,512,...) ***/
    fifo->mask = size - 1;
    return 0;
unsigned int __kfifo_push_char(struct __kfifo *fifo,  const char *p)
    if(( ( fifo->in - fifo->out ) & ( ~fifo->mask ) ) == 0 )
        *( (char*)fifo->data + (fifo->in++ & fifo->mask) ) = *p;
        return 1;
    return 0;
unsigned int __kfifo_pop_char(struct __kfifo *fifo, char* p )
    if( fifo->in != fifo->out )
        *p =  *(  (char*)fifo->data + (fifo->out++ &  fifo->mask) ) ;
        return 1;
    return 0;
#ifndef  KFIFO_PRESENT                                    /* See Note #1.                                         */
#define  KFIFO_PRESENT
#ifdef    KFIFO_MODULE
#define   KFIFO_EXT
#else
#define   KFIFO_EXT  extern
#endif
#ifdef __cplusplus
extern "C"
#endif
#include <cpu.h>
//typedef  unsigned  short       CPU_INT16U;                      /* 16-bit unsigned integer                              */
in out
必须为有符号数,
push() 中的这句         fifo->in 否则到了0xffff后,变为0x0000,再也不会增加
if(( ( fifo->in - fifo->out ) & ~fifo->mask ) == 0 )
struct __kfifo {
    int                in;
    int                out;
    int                mask;
    void        *data;
#if defined ( __ICCARM__ )
#pragma inline
KFIFO_EXT          CPU_INT16U  kfifo_unused(struct __kfifo *fifo)
#else
KFIFO_EXT __inline CPU_INT16U  kfifo_unused(struct __kfifo *fifo)
#endif
    return (fifo->mask + 1) - (fifo->in - fifo->out);
KFIFO_EXT int __kfifo_init(struct __kfifo *fifo, void *buffer, unsigned int size);
KFIFO_EXT unsigned int __kfifo_push_char(struct __kfifo *fifo, const char *p);
KFIFO_EXT unsigned int __kfifo_pop_char(struct __kfifo *fifo, char *p );
#ifdef __cplusplus
#endif
*                                              PRESENT END
* Note(s) : See 'PRESENT  Note #1'.
#endif
发表于 2018-3-3 18:03:28 | 显示全部楼层
希望对硬汉有帮助。 用linux成熟的东东替换。
另外看到用dwt实现us延时。   看硬汉能不能搞一个经过严格测试的delay模块。支持裸奔和rtos ms us,不同主频的配置。
GMT+8, 2026-11-28 14:24 , Processed in 1.299664 second(s), 27 queries .
