查看: 5390|回复: 3
[MDK] MDK升级CMSIS到5.3,中间件软件包到7.6,FreeRTOS和LwIP也都升级到最新版并添加各种器件的驱动支持
发表于 2018-2-24 10:47:04 | 显示全部楼层 |阅读模式
The CMSIS support is now extended to Arm Cortex-A5/A7/A9 processors and the RTX5 source code is fully MISRA compliant. A new CMSIS-NN library contains essential algorithms that accelerate machine learning operations.
The MDK Middleware is now fully compatible with CMSIS-RTOS2 and works with RTX5 or FreeRTOS. A separate pack with device-independent drivers allows re-use from other packs that are independent from the MDK Middleware.
Updated software packs with latest versions of FreeRTOS and LwIP TCP/IP networking are available. LwIP now uses Ethernet MAC/PHY CMSIS-Driver interfaces that are available for many devices.
Several new devices are supported by MDK. For example, Redpine Signals offers WiFi enabled Cortex-M devices with complete CMSIS-Drivers for MDK Middleware. Also the STM32F2 and STM32F4 are updated with latest HAL software.
发表于 2018-2-24 14:50:44 | 显示全部楼层
期待freertos和rtx5
发表于 2018-3-1 22:41:12 | 显示全部楼层
又搞了个RTX5 。。。 是不是被silabs收购了换个名字又出来了。ucos基数太大了。没有人好好推不容易火
 楼主| 发表于 2018-3-2 01:39:23 | 显示全部楼层
不是,RTX5很吊,跟uCOS没关系,RTX去年的全球调查报告比uCOS-II使用多点,看此贴可以了解下:https://forum.anfulai.cn/forum.p ... &extra=page%3D1
GMT+8, 2026-11-24 08:16 , Processed in 0.293417 second(s), 24 queries .
