查看: 5543|回复: 7
[官方评估板] 官方板子,SDRAM 32bit读写不稳定,16bit和8bit测试正常
发表于 2018-2-21 09:07:26 | 显示全部楼层 |阅读模式
平台:MIMXRT1050-EVK
原理图版本: SCH-29538 REV A5   (看板子上贴的标签是A5版 BOM,不过官网暂时未下载到A5版原理图,只有A4的)
运行SDRAM测试例子。C:\nxp\SDK_2.3.0_EVK-MIMXRT1050\boards\evkmimxrt1050\driver_examples\semc
执行结果如下:
SEMC SDRAM Example Start!
SEMC SDRAM Memory 32 bit Write Start, Start Address 0x80000000, Data Length 4096 !
SEMC SDRAM Read 32 bit Data Start, Start Address 0x80000000, Data Length 4096 !
SEMC SDRAM 32 bit Data Write and Read Compare Start!
SEMC SDRAM 32 bit Data Write and Read Compare Failed!                     失败
SEMC SDRAM Memory 16 bit Write Start, Start Address 0x80000000, Data Length 4096 !
SEMC SDRAM Read 16 bit Data Start, Start Address 0x80000000, Data Length 4096 !
SEMC SDRAM 16 bit Data Write and Read Compare Start!
SEMC SDRAM 16 bit Data Write and Read Compare Succeed!
SEMC SDRAM Memory 8 bit Write Start, Start Address 0x80000000, Data Length 4096 !
SEMC SDRAM Read 8 bit Data Start, Start Address 0x80000000, Data Length 4096 !
SEMC SDRAM 8 bit Data Write and Read Compare Start!
SEMC SDRAM 8 bit Data Write and Read Compare Succeed!
SEMC SDRAM Example End.
问题: 16bit和8bit读写正常,32bit读写测试失败。
有板子的朋友可以验证下,看是我的板子硬件问题还是SDRAM配置问题。
将错误的数据打印出来的:(读写4096字节,按32bit访问。 序号 0-FFF OK表示期望值,err表示实际值。没有序号的表示成功的单元)人工统计分析:
(1)1-0x200之前的正确,之后就出现部分单元异常,
(2)高位bit25大概率出现1, 比如正确值0x0000 0319, 读回是0x0200 0319
(3)bit10小概率出现0, 比如正确值是 0x0000 0618, 读回是0x0000 0418
(4)推测 SEMC_D9(32bit数据的bit25)、SEMC_D10(bit10) 两个数据线有串扰
原始数据比对结果:
203, ok= 203, err=2000203
209, ok= 209, err=2000209
20D, ok= 20D, err=200020D
20F, ok= 20F, err=200020F
215, ok= 215, err=2000215
271, ok= 271, err=2000271
27D, ok= 27D, err=200027D
27F, ok= 27F, err=200027F
285, ok= 285, err=2000285
2B1, ok= 2B1, err=20002B1
2B5, ok= 2B5, err=20002B5
2BC, ok= 2BC, err=20002BC
2BD, ok= 2BD, err=20002BD
2BE, ok= 2BE, err=20002BE
2C5, ok= 2C5, err=20002C5
2CD, ok= 2CD, err=20002CD
2F3, ok= 2F3, err=20002F3
2F9, ok= 2F9, err=20002F9
2FD, ok= 2FD, err=20002FD
301, ok= 301, err=2000301
303, ok= 303, err=2000303
309, ok= 309, err=2000309
30B, ok= 30B, err=200030B
30D, ok= 30D, err=200030D
30F, ok= 30F, err=200030F
312, ok= 312, err= 112
317, ok= 317, err= 117
319, ok= 319, err=2000319
31B, ok= 31B, err=200031B
31D, ok= 31D, err=200031D
31F, ok= 31F, err=200031F
321, ok= 321, err=2000321
323, ok= 323, err=2000323
32D, ok= 32D, err=200032D
331, ok= 331, err=2000331
333, ok= 333, err= 133
335, ok= 335, err=2000335
337, ok= 337, err= 137
339, ok= 339, err=2000339
349, ok= 349, err=2000349
34D, ok= 34D, err=200034D
34E, ok= 34E, err=200034E
351, ok= 351, err=2000351
352, ok= 352, err=2000352
353, ok= 353, err=2000353
357, ok= 357, err=2000357
35D, ok= 35D, err=200035D
361, ok= 361, err=2000361
365, ok= 365, err=2000365
369, ok= 369, err=2000369
36D, ok= 36D, err=200036D
371, ok= 371, err=2000371
372, ok= 372, err=2000372
375, ok= 375, err=2000375
379, ok= 379, err=2000379
37D, ok= 37D, err=200037D
381, ok= 381, err=2000381
382, ok= 382, err=2000382
387, ok= 387, err=2000387
38D, ok= 38D, err=200038D
38F, ok= 38F, err=200038F
391, ok= 391, err=2000391
393, ok= 393, err= 193
395, ok= 395, err=2000395
39B, ok= 39B, err=200039B
39D, ok= 39D, err=200039D
39F, ok= 39F, err=200039F
3A1, ok= 3A1, err=20003A1
3A5, ok= 3A5, err=20003A5
3A9, ok= 3A9, err=20003A9
3AD, ok= 3AD, err=20003AD
3AF, ok= 3AF, err=20003AF
3B1, ok= 3B1, err=20003B1
3B5, ok= 3B5, err=20003B5
3B6, ok= 3B6, err=20003B6
3B7, ok= 3B7, err=20003B7
3BA, ok= 3BA, err=20003BA
3BD, ok= 3BD, err=20003BD
3C1, ok= 3C1, err=20003C1
3C3, ok= 3C3, err=20003C3
3C5, ok= 3C5, err=20003C5
3C9, ok= 3C9, err=20003C9
3CB, ok= 3CB, err=20003CB
3CD, ok= 3CD, err=20003CD
3CE, ok= 3CE, err=20003CE
3CF, ok= 3CF, err=20003CF
3D1, ok= 3D1, err=20003D1
3D5, ok= 3D5, err=20003D5
3D7, ok= 3D7, err=20003D7
3DD, ok= 3DD, err=20003DD
3DE, ok= 3DE, err=20003DE
3E1, ok= 3E1, err=20003E1
3E5, ok= 3E5, err=20003E5
3E7, ok= 3E7, err=20003E7
3E9, ok= 3E9, err=20003E9
3ED, ok= 3ED, err=20003ED
3EE, ok= 3EE, err=20003EE
3EF, ok= 3EF, err=20003EF
3F1, ok= 3F1, err=20003F1
3F5, ok= 3F5, err=20003F5
3F6, ok= 3F6, err=20003F6
3F7, ok= 3F7, err=20003F7
3F9, ok= 3F9, err=20003F9
3FD, ok= 3FD, err=20003FD
603, ok= 603, err=2000603
605, ok= 605, err=2000605
606, ok= 606, err= 406
607, ok= 607, err=2000607
609, ok= 609, err=2000609
60A, ok= 60A, err=200060A
60B, ok= 60B, err=200060B
60C, ok= 60C, err=200060C
60D, ok= 60D, err=200060D
60E, ok= 60E, err=200040E
60F, ok= 60F, err=200060F
611, ok= 611, err=2000611
612, ok= 612, err= 412
615, ok= 615, err=2000615
616, ok= 616, err=2000616
617, ok= 617, err=2000617
618, ok= 618, err= 418
619, ok= 619, err=2000619
61A, ok= 61A, err=200061A
61B, ok= 61B, err=200061B
61C, ok= 61C, err=200061C
61D, ok= 61D, err=200061D
61E, ok= 61E, err=200061E
61F, ok= 61F, err=200061F
620, ok= 620, err=2000620
621, ok= 621, err=2000621
622, ok= 622, err=2000622
623, ok= 623, err= 423
624, ok= 624, err=2000624
625, ok= 625, err=2000625
626, ok= 626, err=2000426
627, ok= 627, err=2000427
629, ok= 629, err=2000629
62A, ok= 62A, err=200062A
62B, ok= 62B, err=200062B
62C, ok= 62C, err= 42C
62D, ok= 62D, err=200062D
62E, ok= 62E, err=200042E
62F, ok= 62F, err=200062F
631, ok= 631, err=2000631
632, ok= 632, err=2000632
633, ok= 633, err= 433
635, ok= 635, err=2000635
636, ok= 636, err=2000636
637, ok= 637, err=2000637
639, ok= 639, err=2000639
63A, ok= 63A, err=200063A
63B, ok= 63B, err=200063B
63C, ok= 63C, err=200063C
63D, ok= 63D, err=200063D
63E, ok= 63E, err=200063E
63F, ok= 63F, err=200063F
642, ok= 642, err=2000642
647, ok= 647, err= 447
64A, ok= 64A, err=200064A
64B, ok= 64B, err=200064B
64D, ok= 64D, err=200064D
64F, ok= 64F, err=200064F
651, ok= 651, err=2000651
652, ok= 652, err=2000652
653, ok= 653, err=2000653
655, ok= 655, err=2000655
659, ok= 659, err=2000659
65B, ok= 65B, err=200065B
65D, ok= 65D, err=200065D
65E, ok= 65E, err=200065E
65F, ok= 65F, err=200065F
662, ok= 662, err= 462
663, ok= 663, err=2000663
665, ok= 665, err=2000665
669, ok= 669, err=2000669
66A, ok= 66A, err=200066A
66B, ok= 66B, err=200066B
66D, ok= 66D, err=200066D
66E, ok= 66E, err=200066E
66F, ok= 66F, err=200046F
671, ok= 671, err=2000671
672, ok= 672, err=2000672
673, ok= 673, err=2000673
675, ok= 675, err=2000675
676, ok= 676, err=2000676
677, ok= 677, err=2000677
679, ok= 679, err=2000679
67A, ok= 67A, err=200067A
67B, ok= 67B, err=200067B
67C, ok= 67C, err=200067C
67D, ok= 67D, err=200067D
67E, ok= 67E, err=200067E
67F, ok= 67F, err=200067F
681, ok= 681, err=2000681
682, ok= 682, err=2000682
683, ok= 683, err=2000683
684, ok= 684, err=2000684
685, ok= 685, err=2000685
686, ok= 686, err=2000686
687, ok= 687, err=2000687
689, ok= 689, err=2000689
68A, ok= 68A, err=200068A
68B, ok= 68B, err=200068B
68C, ok= 68C, err=200068C
68D, ok= 68D, err=200068D
68E, ok= 68E, err= 48E
691, ok= 691, err=2000691
692, ok= 692, err=2000692
693, ok= 693, err= 493
694, ok= 694, err=2000694
695, ok= 695, err=2000695
696, ok= 696, err=2000696
697, ok= 697, err=2000697
699, ok= 699, err=2000699
69A, ok= 69A, err=200069A
69B, ok= 69B, err=200069B
69C, ok= 69C, err=200069C
69D, ok= 69D, err=200069D
69E, ok= 69E, err=200049E
69F, ok= 69F, err=200069F
6A0, ok= 6A0, err= 4A0
6A2, ok= 6A2, err=20006A2
6A5, ok= 6A5, err=20006A5
6A6, ok= 6A6, err=20006A6
6A7, ok= 6A7, err=20006A7
6A9, ok= 6A9, err=20006A9
6AD, ok= 6AD, err=20006AD
6AE, ok= 6AE, err=20004AE
6AF, ok= 6AF, err=20006AF
6B1, ok= 6B1, err=20006B1
6B4, ok= 6B4, err=20006B4
6B5, ok= 6B5, err=20006B5
6B6, ok= 6B6, err=20006B6
6B7, ok= 6B7, err=20006B7
6B8, ok= 6B8, err=20006B8
6B9, ok= 6B9, err=20006B9
6BA, ok= 6BA, err=20006BA
6BB, ok= 6BB, err=20006BB
6BC, ok= 6BC, err=20006BC
6BD, ok= 6BD, err=20006BD
6BE, ok= 6BE, err=20006BE
6BF, ok= 6BF, err=20006BF
6C0, ok= 6C0, err=20006C0
6C1, ok= 6C1, err=20006C1
6C2, ok= 6C2, err=20006C2
6C4, ok= 6C4, err=20006C4
6C5, ok= 6C5, err=20006C5
6C6, ok= 6C6, err=20006C6
6C9, ok= 6C9, err=20006C9
6CA, ok= 6CA, err=20006CA
6CC, ok= 6CC, err=20006CC
6CD, ok= 6CD, err=20006CD
6CE, ok= 6CE, err=20006CE
6CF, ok= 6CF, err=20006CF
6D1, ok= 6D1, err=20006D1
6D2, ok= 6D2, err=20006D2
6D3, ok= 6D3, err=20006D3
6D4, ok= 6D4, err=20006D4
6D5, ok= 6D5, err=20006D5
6D6, ok= 6D6, err=20006D6
6D7, ok= 6D7, err=20006D7
6D9, ok= 6D9, err=20006D9
6DA, ok= 6DA, err=20006DA
6DB, ok= 6DB, err=20006DB
6DD, ok= 6DD, err=20006DD
6DE, ok= 6DE, err=20006DE
6DF, ok= 6DF, err=20006DF
6E1, ok= 6E1, err=20006E1
6E3, ok= 6E3, err= 4E3
6E5, ok= 6E5, err=20006E5
6E6, ok= 6E6, err=20006E6
6E7, ok= 6E7, err=20006E7
6E9, ok= 6E9, err=20006E9
6EA, ok= 6EA, err=20006EA
6EB, ok= 6EB, err=20006EB
6ED, ok= 6ED, err=20006ED
6EE, ok= 6EE, err=20006EE
6EF, ok= 6EF, err=20006EF
6F1, ok= 6F1, err=20006F1
6F2, ok= 6F2, err=20006F2
6F3, ok= 6F3, err=20006F3
6F5, ok= 6F5, err=20006F5
6F7, ok= 6F7, err=20006F7
6F9, ok= 6F9, err=20006F9
6FA, ok= 6FA, err=20006FA
6FB, ok= 6FB, err=20006FB
6FD, ok= 6FD, err=20006FD
6FE, ok= 6FE, err=20006FE
6FF, ok= 6FF, err=20006FF
700, ok= 700, err=2000700
701, ok= 701, err=2000501
702, ok= 702, err=2000502
703, ok= 703, err=2000503
704, ok= 704, err= 504
705, ok= 705, err= 505
706, ok= 706, err=2000706
707, ok= 707, err=2000707
709, ok= 709, err=2000709
70B, ok= 70B, err=200050B
70D, ok= 70D, err=200070D
70E, ok= 70E, err=200070E
70F, ok= 70F, err=200070F
711, ok= 711, err=2000711
712, ok= 712, err= 512
713, ok= 713, err=2000713
714, ok= 714, err=2000714
715, ok= 715, err=2000715
716, ok= 716, err=2000716
717, ok= 717, err=2000717
718, ok= 718, err=2000718
719, ok= 719, err=2000719
71A, ok= 71A, err=200071A
71B, ok= 71B, err=200071B
71C, ok= 71C, err=200071C
71D, ok= 71D, err=200071D
71E, ok= 71E, err=200071E
71F, ok= 71F, err=200071F
721, ok= 721, err=2000721
722, ok= 722, err=2000722
723, ok= 723, err=2000723
725, ok= 725, err=2000725
726, ok= 726, err= 526
727, ok= 727, err=2000727
728, ok= 728, err=2000728
729, ok= 729, err=2000729
72A, ok= 72A, err=200052A
72B, ok= 72B, err=200052B
72C, ok= 72C, err=200072C
72D, ok= 72D, err=200072D
72E, ok= 72E, err=200072E
72F, ok= 72F, err=200072F
730, ok= 730, err=2000730
731, ok= 731, err=2000731
732, ok= 732, err=2000732
733, ok= 733, err=2000733
734, ok= 734, err=2000734
735, ok= 735, err=2000735
736, ok= 736, err=2000736
737, ok= 737, err=2000537
738, ok= 738, err=2000538
739, ok= 739, err=2000739
73A, ok= 73A, err=200073A
73B, ok= 73B, err=200073B
73C, ok= 73C, err=200073C
73D, ok= 73D, err=200073D
73E, ok= 73E, err=200073E
73F, ok= 73F, err=200073F
741, ok= 741, err=2000741
742, ok= 742, err=2000742
743, ok= 743, err=2000743
744, ok= 744, err=2000744
745, ok= 745, err=2000745
746, ok= 746, err= 546
747, ok= 747, err=2000547
748, ok= 748, err=2000748
749, ok= 749, err=2000749
74A, ok= 74A, err=200074A
74B, ok= 74B, err=200054B
74C, ok= 74C, err= 54C
74D, ok= 74D, err=200074D
74E, ok= 74E, err=200074E
74F, ok= 74F, err=200074F
750, ok= 750, err=2000750
751, ok= 751, err=2000751
752, ok= 752, err=2000752
753, ok= 753, err=2000753
754, ok= 754, err=2000754
755, ok= 755, err=2000755
756, ok= 756, err=2000556
757, ok= 757, err=2000757
759, ok= 759, err=2000759
75A, ok= 75A, err=200075A
75B, ok= 75B, err=200075B
75D, ok= 75D, err=200075D
75E, ok= 75E, err=200055E
75F, ok= 75F, err=200075F
761, ok= 761, err=2000761
762, ok= 762, err=2000762
763, ok= 763, err=2000763
764, ok= 764, err=2000764
765, ok= 765, err=2000765
766, ok= 766, err=2000766
767, ok= 767, err=2000767
768, ok= 768, err=2000568
769, ok= 769, err=2000769
76A, ok= 76A, err=200076A
76B, ok= 76B, err=200076B
76C, ok= 76C, err=200076C
76D, ok= 76D, err=200076D
76E, ok= 76E, err=200076E
76F, ok= 76F, err=200076F
770, ok= 770, err=2000770
771, ok= 771, err=2000771
772, ok= 772, err=2000772
773, ok= 773, err=2000773
774, ok= 774, err=2000774
775, ok= 775, err=2000775
776, ok= 776, err=2000776
777, ok= 777, err=2000777
778, ok= 778, err=2000778
779, ok= 779, err=2000779
77A, ok= 77A, err=200077A
77B, ok= 77B, err=200077B
77C, ok= 77C, err=200077C
77D, ok= 77D, err=200077D
77E, ok= 77E, err=200077E
77F, ok= 77F, err=200077F
781, ok= 781, err=2000781
782, ok= 782, err=2000582
783, ok= 783, err=2000783
784, ok= 784, err=2000584
785, ok= 785, err=2000785
786, ok= 786, err=2000586
787, ok= 787, err=2000787
788, ok= 788, err= 588
789, ok= 789, err=2000789
78A, ok= 78A, err=200058A
78B, ok= 78B, err=200078B
78C, ok= 78C, err= 58C
78D, ok= 78D, err=200078D
78E, ok= 78E, err=200078E
78F, ok= 78F, err=200078F
791, ok= 791, err=2000791
792, ok= 792, err=2000592
793, ok= 793, err=2000593
794, ok= 794, err=2000794
795, ok= 795, err=2000795
796, ok= 796, err=2000796
797, ok= 797, err=2000797
798, ok= 798, err=2000798
799, ok= 799, err=2000799
79A, ok= 79A, err=200079A
79B, ok= 79B, err=200079B
79D, ok= 79D, err=200079D
79E, ok= 79E, err=200079E
79F, ok= 79F, err=200079F
7A0, ok= 7A0, err=20007A0
7A1, ok= 7A1, err=20007A1
7A2, ok= 7A2, err=20005A2
7A3, ok= 7A3, err=20007A3
7A4, ok= 7A4, err=20005A4
7A5, ok= 7A5, err=20007A5
7A6, ok= 7A6, err=20007A6
7A7, ok= 7A7, err=20007A7
7A8, ok= 7A8, err=20007A8
7A9, ok= 7A9, err=20007A9
7AA, ok= 7AA, err=20007AA
7AB, ok= 7AB, err=20007AB
7AD, ok= 7AD, err=20007AD
7AE, ok= 7AE, err=20007AE
7AF, ok= 7AF, err=20007AF
7B0, ok= 7B0, err=20007B0
7B1, ok= 7B1, err=20007B1
7B2, ok= 7B2, err=20007B2
7B3, ok= 7B3, err=20005B3
7B4, ok= 7B4, err=20007B4
7B5, ok= 7B5, err=20007B5
7B6, ok= 7B6, err=20007B6
7B7, ok= 7B7, err=20007B7
7B8, ok= 7B8, err=20007B8
7B9, ok= 7B9, err=20007B9
7BA, ok= 7BA, err=20007BA
7BB, ok= 7BB, err=20007BB
7BC, ok= 7BC, err=20007BC
7BD, ok= 7BD, err=20007BD
7BE, ok= 7BE, err=20007BE
7BF, ok= 7BF, err=20005BF
7C0, ok= 7C0, err=20007C0
7C1, ok= 7C1, err=20007C1
7C2, ok= 7C2, err=20007C2
7C3, ok= 7C3, err=20007C3
7C4, ok= 7C4, err=20007C4
7C5, ok= 7C5, err=20007C5
7C6, ok= 7C6, err=20007C6
7C7, ok= 7C7, err=20007C7
7C8, ok= 7C8, err=20007C8
7C9, ok= 7C9, err=20007C9
7CA, ok= 7CA, err=20007CA
7CB, ok= 7CB, err=20007CB
7CC, ok= 7CC, err=20007CC
7CD, ok= 7CD, err=20007CD
7CE, ok= 7CE, err=20007CE
7CF, ok= 7CF, err=20007CF
7D0, ok= 7D0, err=20007D0
7D1, ok= 7D1, err=20007D1
7D2, ok= 7D2, err=20007D2
7D3, ok= 7D3, err=20005D3
7D4, ok= 7D4, err=20007D4
7D5, ok= 7D5, err=20007D5
7D6, ok= 7D6, err=20007D6
7D7, ok= 7D7, err=20007D7
7D9, ok= 7D9, err=20007D9
7DA, ok= 7DA, err=20007DA
7DB, ok= 7DB, err=20007DB
7DC, ok= 7DC, err=20007DC
7DD, ok= 7DD, err=20007DD
7DE, ok= 7DE, err=20007DE
7DF, ok= 7DF, err=20007DF
7E1, ok= 7E1, err=20007E1
7E2, ok= 7E2, err=20007E2
7E3, ok= 7E3, err=20007E3
7E4, ok= 7E4, err=20007E4
7E5, ok= 7E5, err=20007E5
7E6, ok= 7E6, err=20007E6
7E7, ok= 7E7, err=20007E7
7E8, ok= 7E8, err=20007E8
7E9, ok= 7E9, err=20007E9
7EA, ok= 7EA, err=20007EA
7EB, ok= 7EB, err=20007EB
7EC, ok= 7EC, err=20007EC
7ED, ok= 7ED, err=20007ED
7EE, ok= 7EE, err=20007EE
7EF, ok= 7EF, err=20007EF
7F0, ok= 7F0, err=20007F0
7F1, ok= 7F1, err=20007F1
7F2, ok= 7F2, err=20007F2
7F3, ok= 7F3, err=20007F3
7F4, ok= 7F4, err=20005F4
7F5, ok= 7F5, err=20007F5
7F6, ok= 7F6, err=20007F6
7F7, ok= 7F7, err=20007F7
7F8, ok= 7F8, err=20007F8
7F9, ok= 7F9, err=20007F9
7FA, ok= 7FA, err=20007FA
7FB, ok= 7FB, err=20007FB
7FC, ok= 7FC, err=20007FC
7FD, ok= 7FD, err=20007FD
7FE, ok= 7FE, err=20007FE
7FF, ok= 7FF, err=20007FF
A00, ok= A00, err= 800
A09, ok= A09, err=2000A09
A0D, ok= A0D, err=2000A0D
A0F, ok= A0F, err=2000A0F
A11, ok= A11, err=2000A11
A17, ok= A17, err=2000A17
A19, ok= A19, err=2000A19
A1B, ok= A1B, err= 81B
A1D, ok= A1D, err=2000A1D
A27, ok= A27, err=2000A27
A2A, ok= A2A, err=2000A2A
A2D, ok= A2D, err=2000A2D
A2F, ok= A2F, err=2000A2F
A31, ok= A31, err=2000A31
A32, ok= A32, err=2000A32
A33, ok= A33, err=2000A33
A35, ok= A35, err=2000A35
A36, ok= A36, err=2000A36
A37, ok= A37, err=2000A37
A3A, ok= A3A, err=2000A3A
A3B, ok= A3B, err=2000A3B
A3D, ok= A3D, err=2000A3D
A3E, ok= A3E, err=2000A3E
A3F, ok= A3F, err=2000A3F
A41, ok= A41, err=2000A41
A42, ok= A42, err=2000A42
A45, ok= A45, err=2000A45
A46, ok= A46, err=2000A46
A47, ok= A47, err=2000A47
A48, ok= A48, err=2000A48
A49, ok= A49, err=2000A49
A4D, ok= A4D, err=2000A4D
A4F, ok= A4F, err=2000A4F
A51, ok= A51, err=2000A51
A55, ok= A55, err=2000A55
A5D, ok= A5D, err=2000A5D
A65, ok= A65, err=2000A65
A66, ok= A66, err=2000A66
A6B, ok= A6B, err=2000A6B
A6D, ok= A6D, err=2000A6D
A71, ok= A71, err=2000A71
A73, ok= A73, err=2000A73
A75, ok= A75, err=2000A75
A77, ok= A77, err=2000A77
A79, ok= A79, err=2000A79
A7B, ok= A7B, err=2000A7B
A7D, ok= A7D, err=2000A7D
A81, ok= A81, err=2000A81
A85, ok= A85, err=2000A85
A8D, ok= A8D, err=2000A8D
A91, ok= A91, err=2000A91
A93, ok= A93, err= 893
A95, ok= A95, err=2000A95
A96, ok= A96, err=2000A96
A97, ok= A97, err=2000A97
A9A, ok= A9A, err=2000A9A
A9E, ok= A9E, err=2000A9E
A9F, ok= A9F, err=2000A9F
AA1, ok= AA1, err=2000AA1
AA3, ok= AA3, err=2000AA3
AA5, ok= AA5, err=2000AA5
AA6, ok= AA6, err=2000AA6
AA7, ok= AA7, err=2000AA7
AA9, ok= AA9, err=2000AA9
AAD, ok= AAD, err=2000AAD
AAF, ok= AAF, err=2000AAF
AB1, ok= AB1, err=2000AB1
AB5, ok= AB5, err=2000AB5
AB6, ok= AB6, err=2000AB6
AB7, ok= AB7, err=2000AB7
AB8, ok= AB8, err=2000AB8
AB9, ok= AB9, err=2000AB9
ABA, ok= ABA, err=2000ABA
ABD, ok= ABD, err=2000ABD
ABF, ok= ABF, err=2000ABF
AC1, ok= AC1, err=2000AC1
AC5, ok= AC5, err=2000AC5
AC9, ok= AC9, err=2000AC9
ACA, ok= ACA, err=2000ACA
ACB, ok= ACB, err=2000ACB
ACF, ok= ACF, err=2000ACF
AD1, ok= AD1, err=2000AD1
AD2, ok= AD2, err= 8D2
AD3, ok= AD3, err=2000AD3
AD5, ok= AD5, err=2000AD5
AD9, ok= AD9, err=2000AD9
ADA, ok= ADA, err=2000ADA
ADB, ok= ADB, err=2000ADB
ADD, ok= ADD, err=2000ADD
AE4, ok= AE4, err=2000AE4
AE5, ok= AE5, err=2000AE5
AE6, ok= AE6, err=2000AE6
AE9, ok= AE9, err=2000AE9
AEA, ok= AEA, err=2000AEA
AEB, ok= AEB, err=2000AEB
AED, ok= AED, err=2000AED
AEE, ok= AEE, err=2000AEE
AEF, ok= AEF, err=2000AEF
AF2, ok= AF2, err=2000AF2
AF3, ok= AF3, err=2000AF3
AF5, ok= AF5, err=2000AF5
AF6, ok= AF6, err=2000AF6
AF7, ok= AF7, err=2000AF7
AF9, ok= AF9, err=2000AF9
AFB, ok= AFB, err=2000AFB
AFD, ok= AFD, err=2000AFD
AFE, ok= AFE, err=2000AFE
AFF, ok= AFF, err=2000AFF
B01, ok= B01, err=2000B01
B02, ok= B02, err=2000B02
B03, ok= B03, err=2000B03
B05, ok= B05, err=2000B05
B06, ok= B06, err=2000B06
B07, ok= B07, err=2000B07
B09, ok= B09, err=2000B09
B0A, ok= B0A, err=2000B0A
B0B, ok= B0B, err=2000B0B
B0C, ok= B0C, err=2000B0C
B0D, ok= B0D, err=2000B0D
B11, ok= B11, err=2000B11
B13, ok= B13, err=2000B13
B15, ok= B15, err=2000B15
B17, ok= B17, err=2000B17
B1A, ok= B1A, err=2000B1A
B1D, ok= B1D, err=2000B1D
B1E, ok= B1E, err=2000B1E
B1F, ok= B1F, err=2000B1F
B22, ok= B22, err=2000B22
B23, ok= B23, err=2000B23
B25, ok= B25, err=2000B25
B26, ok= B26, err=2000926
B27, ok= B27, err=2000B27
B29, ok= B29, err=2000B29
B2A, ok= B2A, err=2000B2A
B2B, ok= B2B, err=2000B2B
B2D, ok= B2D, err=2000B2D
B2F, ok= B2F, err= 92F
B31, ok= B31, err=2000B31
B32, ok= B32, err=2000B32
B33, ok= B33, err=2000B33
B35, ok= B35, err=2000B35
B36, ok= B36, err=2000B36
B39, ok= B39, err=2000B39
B3A, ok= B3A, err=2000B3A
B3B, ok= B3B, err=2000B3B
B3C, ok= B3C, err=2000B3C
B3D, ok= B3D, err=2000B3D
B3F, ok= B3F, err=2000B3F
B41, ok= B41, err=2000B41
B43, ok= B43, err=2000B43
B45, ok= B45, err=2000B45
B47, ok= B47, err=2000B47
B49, ok= B49, err=2000B49
B4A, ok= B4A, err=2000B4A
B4B, ok= B4B, err=2000B4B
B4D, ok= B4D, err=2000B4D
B4E, ok= B4E, err=2000B4E
B4F, ok= B4F, err=2000B4F
B51, ok= B51, err=2000B51
B52, ok= B52, err=2000B52
B53, ok= B53, err=2000B53
B55, ok= B55, err=2000B55
B57, ok= B57, err=2000B57
B59, ok= B59, err=2000B59
B5A, ok= B5A, err=2000B5A
B5B, ok= B5B, err=2000B5B
B5C, ok= B5C, err=2000B5C
B5D, ok= B5D, err=2000B5D
B5E, ok= B5E, err=2000B5E
B5F, ok= B5F, err=2000B5F
B60, ok= B60, err=2000B60
B61, ok= B61, err=2000B61
B62, ok= B62, err=2000B62
B63, ok= B63, err=2000B63
B65, ok= B65, err=2000B65
B69, ok= B69, err=2000B69
B6A, ok= B6A, err=2000B6A
B6B, ok= B6B, err=2000B6B
B6C, ok= B6C, err= 96C
B6D, ok= B6D, err=2000B6D
B73, ok= B73, err=2000B73
B75, ok= B75, err=2000B75
B76, ok= B76, err=2000B76
B77, ok= B77, err=2000B77
B79, ok= B79, err=2000B79
B7A, ok= B7A, err=2000B7A
B7B, ok= B7B, err=2000B7B
B7C, ok= B7C, err=2000B7C
B7D, ok= B7D, err=2000B7D
B7E, ok= B7E, err=2000B7E
B80, ok= B80, err=2000B80
B81, ok= B81, err=2000B81
B82, ok= B82, err=2000B82
B85, ok= B85, err=2000B85
B86, ok= B86, err=2000B86
B89, ok= B89, err=2000B89
B8A, ok= B8A, err=2000B8A
B8B, ok= B8B, err=2000B8B
B8D, ok= B8D, err=2000B8D
B8E, ok= B8E, err=2000B8E
B8F, ok= B8F, err=2000B8F
B91, ok= B91, err=2000B91
B92, ok= B92, err=2000B92
B93, ok= B93, err=2000B93
B95, ok= B95, err=2000B95
B96, ok= B96, err=2000B96
B97, ok= B97, err=2000B97
B99, ok= B99, err=2000B99
B9A, ok= B9A, err=2000B9A
B9B, ok= B9B, err=2000B9B
B9C, ok= B9C, err=2000B9C
B9D, ok= B9D, err=2000B9D
B9F, ok= B9F, err=2000B9F
BA1, ok= BA1, err=2000BA1
BA2, ok= BA2, err=2000BA2
BA3, ok= BA3, err=2000BA3
BA5, ok= BA5, err=2000BA5
BA6, ok= BA6, err=2000BA6
BA9, ok= BA9, err=2000BA9
BAA, ok= BAA, err=2000BAA
BAB, ok= BAB, err=2000BAB
BAC, ok= BAC, err=2000BAC
BAD, ok= BAD, err=2000BAD
BAE, ok= BAE, err=2000BAE
BAF, ok= BAF, err=2000BAF
BB1, ok= BB1, err=2000BB1
BB3, ok= BB3, err=2000BB3
BB5, ok= BB5, err=2000BB5
BB7, ok= BB7, err=2000BB7
BB9, ok= BB9, err=2000BB9
BBA, ok= BBA, err=2000BBA
BBB, ok= BBB, err=2000BBB
BBD, ok= BBD, err=2000BBD
BBF, ok= BBF, err=2000BBF
BC0, ok= BC0, err=2000BC0
BC1, ok= BC1, err=2000BC1
BC2, ok= BC2, err=2000BC2
BC3, ok= BC3, err=2000BC3
BC5, ok= BC5, err=2000BC5
BC7, ok= BC7, err=2000BC7
BC8, ok= BC8, err=2000BC8
BC9, ok= BC9, err=2000BC9
BCA, ok= BCA, err=2000BCA
BCB, ok= BCB, err=2000BCB
BCD, ok= BCD, err=2000BCD
BCE, ok= BCE, err=2000BCE
BCF, ok= BCF, err=2000BCF
BD1, ok= BD1, err=2000BD1
BD2, ok= BD2, err= 9D2
BD3, ok= BD3, err=2000BD3
BD5, ok= BD5, err=2000BD5
BD6, ok= BD6, err=2000BD6
BD7, ok= BD7, err=2000BD7
BD8, ok= BD8, err=2000BD8
BD9, ok= BD9, err=2000BD9
BDA, ok= BDA, err=2000BDA
BDD, ok= BDD, err=2000BDD
BDE, ok= BDE, err=2000BDE
BDF, ok= BDF, err=2000BDF
BE1, ok= BE1, err=2000BE1
BE2, ok= BE2, err=2000BE2
BE3, ok= BE3, err=2000BE3
BE5, ok= BE5, err=2000BE5
BE6, ok= BE6, err=2000BE6
BE7, ok= BE7, err=2000BE7
BE8, ok= BE8, err=2000BE8
BE9, ok= BE9, err=2000BE9
BEA, ok= BEA, err=2000BEA
BEB, ok= BEB, err=2000BEB
BEC, ok= BEC, err=2000BEC
BED, ok= BED, err=2000BED
BEE, ok= BEE, err=2000BEE
BEF, ok= BEF, err=2000BEF
BF0, ok= BF0, err=2000BF0
BF1, ok= BF1, err=2000BF1
BF2, ok= BF2, err=2000BF2
BF3, ok= BF3, err=2000BF3
BF5, ok= BF5, err=2000BF5
BF6, ok= BF6, err=2000BF6
BF7, ok= BF7, err=2000BF7
BF8, ok= BF8, err=2000BF8
BF9, ok= BF9, err=2000BF9
BFA, ok= BFA, err=2000BFA
BFB, ok= BFB, err=2000BFB
BFC, ok= BFC, err=2000BFC
BFD, ok= BFD, err=2000BFD
BFE, ok= BFE, err=2000BFE
BFF, ok= BFF, err=2000BFF
E00, ok= E00, err= C00
E01, ok= E01, err=2000E01
E02, ok= E02, err=2000C02
E03, ok= E03, err=2000E03
E05, ok= E05, err=2000E05
E06, ok= E06, err=2000C06
E07, ok= E07, err=2000E07
E08, ok= E08, err= C08
E09, ok= E09, err=2000E09
E0A, ok= E0A, err= C0A
E0B, ok= E0B, err=2000C0B
E0D, ok= E0D, err=2000E0D
E0E, ok= E0E, err=2000E0E
E0F, ok= E0F, err=2000E0F
E11, ok= E11, err=2000E11
E12, ok= E12, err=2000C12
E13, ok= E13, err=2000E13
E15, ok= E15, err=2000E15
E16, ok= E16, err=2000C16
E17, ok= E17, err=2000E17
E18, ok= E18, err=2000E18
E19, ok= E19, err=2000E19
E1A, ok= E1A, err=2000E1A
E1B, ok= E1B, err=2000E1B
E1C, ok= E1C, err= C1C
E1D, ok= E1D, err=2000E1D
E1E, ok= E1E, err=2000E1E
E1F, ok= E1F, err=2000E1F
E20, ok= E20, err=2000E20
E21, ok= E21, err=2000E21
E22, ok= E22, err=2000E22
E23, ok= E23, err=2000E23
E25, ok= E25, err=2000E25
E26, ok= E26, err=2000E26
E27, ok= E27, err=2000E27
E28, ok= E28, err=2000C28
E29, ok= E29, err=2000E29
E2A, ok= E2A, err= C2A
E2B, ok= E2B, err= C2B
E2C, ok= E2C, err=2000E2C
E2D, ok= E2D, err=2000E2D
E2E, ok= E2E, err=2000E2E
E2F, ok= E2F, err=2000E2F
E30, ok= E30, err= C30
E31, ok= E31, err=2000C31
E32, ok= E32, err=2000C32
E33, ok= E33, err=2000E33
E34, ok= E34, err=2000E34
E35, ok= E35, err=2000E35
E36, ok= E36, err=2000E36
E37, ok= E37, err=2000E37
E39, ok= E39, err=2000E39
E3A, ok= E3A, err=2000C3A
E3B, ok= E3B, err=2000C3B
E3C, ok= E3C, err=2000E3C
E3D, ok= E3D, err=2000E3D
E3E, ok= E3E, err=2000C3E
E3F, ok= E3F, err=2000C3F
E41, ok= E41, err=2000E41
E42, ok= E42, err=2000E42
E43, ok= E43, err=2000C43
E45, ok= E45, err=2000E45
E46, ok= E46, err=2000E46
E47, ok= E47, err=2000E47
E48, ok= E48, err=2000E48
E49, ok= E49, err=2000E49
E4A, ok= E4A, err=2000E4A
E4B, ok= E4B, err=2000E4B
E4C, ok= E4C, err=2000E4C
E4D, ok= E4D, err=2000E4D
E4E, ok= E4E, err=2000E4E
E4F, ok= E4F, err=2000E4F
E50, ok= E50, err=2000E50
E51, ok= E51, err=2000E51
E52, ok= E52, err=2000E52
E53, ok= E53, err=2000C53
E54, ok= E54, err=2000E54
E55, ok= E55, err=2000E55
E56, ok= E56, err=2000E56
E57, ok= E57, err=2000E57
E58, ok= E58, err=2000E58
E59, ok= E59, err=2000E59
E5A, ok= E5A, err=2000C5A
E5B, ok= E5B, err=2000E5B
E5C, ok= E5C, err=2000E5C
E5D, ok= E5D, err=2000E5D
E5E, ok= E5E, err=2000E5E
E5F, ok= E5F, err=2000E5F
E60, ok= E60, err=2000C60
E61, ok= E61, err=2000E61
E62, ok= E62, err=2000E62
E63, ok= E63, err=2000E63
E64, ok= E64, err=2000E64
E65, ok= E65, err=2000E65
E66, ok= E66, err=2000E66
E67, ok= E67, err=2000E67
E68, ok= E68, err=2000E68
E69, ok= E69, err=2000E69
E6A, ok= E6A, err=2000C6A
E6B, ok= E6B, err= C6B
E6C, ok= E6C, err=2000E6C
E6D, ok= E6D, err=2000E6D
E6E, ok= E6E, err=2000E6E
E6F, ok= E6F, err=2000E6F
E71, ok= E71, err=2000E71
E72, ok= E72, err=2000E72
E73, ok= E73, err=2000E73
E74, ok= E74, err=2000E74
E75, ok= E75, err=2000E75
E76, ok= E76, err=2000E76
E77, ok= E77, err=2000E77
E79, ok= E79, err=2000E79
E7A, ok= E7A, err=2000E7A
E7B, ok= E7B, err=2000E7B
E7D, ok= E7D, err=2000E7D
E7E, ok= E7E, err=2000C7E
E7F, ok= E7F, err=2000E7F
E80, ok= E80, err=2000E80
E81, ok= E81, err=2000E81
E82, ok= E82, err=2000E82
E83, ok= E83, err=2000E83
E84, ok= E84, err=2000E84
E85, ok= E85, err=2000E85
E86, ok= E86, err=2000E86
E87, ok= E87, err=2000C87
E88, ok= E88, err=2000E88
E89, ok= E89, err=2000C89
E8A, ok= E8A, err=2000E8A
E8B, ok= E8B, err=2000E8B
E8C, ok= E8C, err= C8C
E8D, ok= E8D, err=2000E8D
E8E, ok= E8E, err=2000C8E
E8F, ok= E8F, err=2000E8F
E90, ok= E90, err=2000E90
E91, ok= E91, err=2000E91
E92, ok= E92, err=2000E92
E93, ok= E93, err=2000E93
E94, ok= E94, err=2000E94
E95, ok= E95, err=2000E95
E96, ok= E96, err=2000E96
E97, ok= E97, err=2000E97
E98, ok= E98, err=2000E98
E99, ok= E99, err=2000E99
E9A, ok= E9A, err=2000C9A
E9B, ok= E9B, err=2000C9B
E9C, ok= E9C, err=2000E9C
E9D, ok= E9D, err=2000E9D
E9E, ok= E9E, err=2000C9E
E9F, ok= E9F, err=2000E9F
EA0, ok= EA0, err= CA0
EA1, ok= EA1, err=2000CA1
EA2, ok= EA2, err=2000CA2
EA3, ok= EA3, err=2000EA3
EA4, ok= EA4, err=2000EA4
EA5, ok= EA5, err=2000EA5
EA6, ok= EA6, err=2000EA6
EA7, ok= EA7, err=2000EA7
EA9, ok= EA9, err=2000EA9
EAA, ok= EAA, err=2000CAA
EAB, ok= EAB, err=2000CAB
EAC, ok= EAC, err=2000EAC
EAD, ok= EAD, err=2000EAD
EAE, ok= EAE, err=2000CAE
EAF, ok= EAF, err=2000EAF
EB0, ok= EB0, err=2000EB0
EB1, ok= EB1, err=2000EB1
EB2, ok= EB2, err=2000CB2
EB3, ok= EB3, err=2000EB3
EB4, ok= EB4, err=2000EB4
EB5, ok= EB5, err=2000EB5
EB6, ok= EB6, err=2000CB6
EB7, ok= EB7, err=2000EB7
EB8, ok= EB8, err=2000EB8
EB9, ok= EB9, err=2000EB9
EBA, ok= EBA, err=2000EBA
EBB, ok= EBB, err=2000EBB
EBC, ok= EBC, err=2000EBC
EBD, ok= EBD, err=2000EBD
EBE, ok= EBE, err=2000CBE
EBF, ok= EBF, err=2000EBF
EC0, ok= EC0, err=2000EC0
EC1, ok= EC1, err=2000EC1
EC2, ok= EC2, err=2000CC2
EC3, ok= EC3, err=2000EC3
EC4, ok= EC4, err=2000EC4
EC5, ok= EC5, err=2000EC5
EC6, ok= EC6, err= CC6
EC7, ok= EC7, err=2000EC7
EC8, ok= EC8, err= CC8
EC9, ok= EC9, err=2000EC9
ECA, ok= ECA, err=2000ECA
ECB, ok= ECB, err=2000ECB
ECC, ok= ECC, err=2000ECC
ECD, ok= ECD, err=2000ECD
ECE, ok= ECE, err=2000ECE
ECF, ok= ECF, err=2000ECF
ED0, ok= ED0, err=2000ED0
ED1, ok= ED1, err=2000ED1
ED2, ok= ED2, err=2000ED2
ED3, ok= ED3, err=2000ED3
ED4, ok= ED4, err=2000ED4
ED5, ok= ED5, err=2000ED5
ED6, ok= ED6, err=2000ED6
ED7, ok= ED7, err=2000ED7
ED8, ok= ED8, err=2000ED8
ED9, ok= ED9, err=2000CD9
EDA, ok= EDA, err=2000EDA
EDB, ok= EDB, err=2000EDB
EDC, ok= EDC, err=2000EDC
EDD, ok= EDD, err=2000EDD
EDE, ok= EDE, err=2000EDE
EDF, ok= EDF, err=2000EDF
EE0, ok= EE0, err=2000EE0
EE1, ok= EE1, err=2000EE1
EE2, ok= EE2, err=2000EE2
EE3, ok= EE3, err=2000CE3
EE4, ok= EE4, err=2000EE4
EE5, ok= EE5, err=2000EE5
EE6, ok= EE6, err=2000EE6
EE7, ok= EE7, err=2000EE7
EE9, ok= EE9, err=2000EE9
EEA, ok= EEA, err=2000EEA
EEB, ok= EEB, err=2000EEB
EEC, ok= EEC, err=2000EEC
EED, ok= EED, err=2000CED
EEE, ok= EEE, err=2000EEE
EEF, ok= EEF, err=2000EEF
EF0, ok= EF0, err=2000EF0
EF1, ok= EF1, err=2000EF1
EF2, ok= EF2, err=2000EF2
EF3, ok= EF3, err=2000EF3
EF4, ok= EF4, err=2000EF4
EF5, ok= EF5, err=2000EF5
EF6, ok= EF6, err=2000EF6
EF7, ok= EF7, err=2000EF7
EF8, ok= EF8, err=2000EF8
EF9, ok= EF9, err=2000EF9
EFA, ok= EFA, err=2000EFA
EFB, ok= EFB, err=2000EFB
EFC, ok= EFC, err=2000EFC
EFD, ok= EFD, err=2000EFD
EFE, ok= EFE, err=2000EFE
EFF, ok= EFF, err=2000EFF
F00, ok= F00, err=2000D00
F01, ok= F01, err=2000F01
F02, ok= F02, err=2000D02
F03, ok= F03, err=2000D03
F04, ok= F04, err=2000D04
F05, ok= F05, err=2000D05
F06, ok= F06, err=2000D06
F07, ok= F07, err=2000D07
F08, ok= F08, err=2000D08
F09, ok= F09, err=2000F09
F0A, ok= F0A, err=2000D0A
F0B, ok= F0B, err=2000D0B
F0C, ok= F0C, err=2000D0C
F0D, ok= F0D, err=2000F0D
F0E, ok= F0E, err=2000D0E
F0F, ok= F0F, err=2000D0F
F10, ok= F10, err=2000F10
F11, ok= F11, err=2000F11
F12, ok= F12, err=2000D12
F13, ok= F13, err=2000D13
F14, ok= F14, err=2000F14
F15, ok= F15, err=2000F15
F16, ok= F16, err=2000D16
F17, ok= F17, err=2000D17
F18, ok= F18, err= D18
F19, ok= F19, err=2000F19
F1A, ok= F1A, err=2000F1A
F1B, ok= F1B, err=2000F1B
F1C, ok= F1C, err=2000F1C
F1D, ok= F1D, err=2000F1D
F1E, ok= F1E, err=2000D1E
F1F, ok= F1F, err=2000D1F
F20, ok= F20, err=2000F20
F21, ok= F21, err=2000F21
F22, ok= F22, err=2000F22
F23, ok= F23, err=2000F23
F24, ok= F24, err=2000F24
F25, ok= F25, err=2000F25
F26, ok= F26, err=2000D26
F27, ok= F27, err=2000D27
F28, ok= F28, err=2000F28
F29, ok= F29, err=2000F29
F2A, ok= F2A, err=2000F2A
F2B, ok= F2B, err=2000F2B
F2C, ok= F2C, err=2000D2C
F2D, ok= F2D, err=2000F2D
F2E, ok= F2E, err=2000F2E
F2F, ok= F2F, err=2000D2F
F30, ok= F30, err=2000F30
F31, ok= F31, err=2000F31
F32, ok= F32, err=2000F32
F33, ok= F33, err=2000F33
F34, ok= F34, err=2000F34
F35, ok= F35, err=2000F35
F36, ok= F36, err=2000F36
F37, ok= F37, err=2000F37
F38, ok= F38, err=2000F38
F39, ok= F39, err=2000F39
F3A, ok= F3A, err=2000D3A
F3B, ok= F3B, err=2000D3B
F3C, ok= F3C, err=2000F3C
F3D, ok= F3D, err=2000F3D
F3E, ok= F3E, err=2000D3E
F3F, ok= F3F, err=2000D3F
F40, ok= F40, err=2000F40
F41, ok= F41, err=2000F41
F42, ok= F42, err=2000D42
F43, ok= F43, err=2000D43
F44, ok= F44, err=2000F44
F45, ok= F45, err=2000F45
F46, ok= F46, err=2000F46
F47, ok= F47, err=2000F47
F48, ok= F48, err=2000F48
F49, ok= F49, err=2000F49
F4A, ok= F4A, err=2000F4A
F4B, ok= F4B, err=2000F4B
F4C, ok= F4C, err=2000D4C
F4D, ok= F4D, err=2000F4D
F4E, ok= F4E, err=2000F4E
F4F, ok= F4F, err=2000F4F
F50, ok= F50, err=2000D50
F51, ok= F51, err=2000F51
F52, ok= F52, err=2000D52
F53, ok= F53, err=2000F53
F54, ok= F54, err=2000F54
F55, ok= F55, err=2000F55
F56, ok= F56, err=2000F56
F57, ok= F57, err=2000F57
F58, ok= F58, err=2000F58
F59, ok= F59, err=2000F59
F5A, ok= F5A, err=2000F5A
F5B, ok= F5B, err=2000F5B
F5C, ok= F5C, err=2000F5C
F5D, ok= F5D, err=2000F5D
F5E, ok= F5E, err=2000D5E
F5F, ok= F5F, err=2000D5F
F60, ok= F60, err=2000F60
F61, ok= F61, err=2000F61
F62, ok= F62, err=2000D62
F63, ok= F63, err=2000F63
F64, ok= F64, err=2000D64
F65, ok= F65, err=2000F65
F66, ok= F66, err=2000D66
F67, ok= F67, err=2000D67
F68, ok= F68, err=2000F68
F69, ok= F69, err=2000F69
F6A, ok= F6A, err=2000F6A
F6B, ok= F6B, err=2000F6B
F6C, ok= F6C, err=2000F6C
F6D, ok= F6D, err=2000F6D
F6E, ok= F6E, err=2000D6E
F6F, ok= F6F, err=2000F6F
F70, ok= F70, err=2000D70
F71, ok= F71, err=2000F71
F72, ok= F72, err=2000F72
F73, ok= F73, err=2000F73
F74, ok= F74, err=2000F74
F75, ok= F75, err=2000F75
F76, ok= F76, err=2000D76
F77, ok= F77, err=2000D77
F78, ok= F78, err=2000F78
F79, ok= F79, err=2000F79
F7A, ok= F7A, err=2000F7A
F7B, ok= F7B, err=2000F7B
F7C, ok= F7C, err=2000F7C
F7D, ok= F7D, err=2000F7D
F7E, ok= F7E, err=2000F7E
F7F, ok= F7F, err=2000D7F
F80, ok= F80, err= D80
F81, ok= F81, err=2000F81
F82, ok= F82, err=2000F82
F83, ok= F83, err=2000F83
F84, ok= F84, err=2000D84
F85, ok= F85, err=2000D85
F86, ok= F86, err=2000F86
F87, ok= F87, err=2000D87
F88, ok= F88, err=2000F88
F89, ok= F89, err=2000D89
F8A, ok= F8A, err=2000F8A
F8B, ok= F8B, err=2000D8B
F8C, ok= F8C, err=2000F8C
F8D, ok= F8D, err=2000F8D
F8E, ok= F8E, err=2000F8E
F8F, ok= F8F, err=2000F8F
F90, ok= F90, err=2000F90
F91, ok= F91, err=2000F91
F92, ok= F92, err=2000D92
F93, ok= F93, err=2000D93
F94, ok= F94, err=2000D94
F95, ok= F95, err=2000F95
F96, ok= F96, err=2000D96
F97, ok= F97, err=2000F97
F98, ok= F98, err=2000F98
F99, ok= F99, err=2000F99
F9A, ok= F9A, err=2000F9A
F9B, ok= F9B, err=2000F9B
F9C, ok= F9C, err=2000F9C
F9D, ok= F9D, err=2000F9D
F9E, ok= F9E, err=2000F9E
F9F, ok= F9F, err=2000F9F
FA0, ok= FA0, err= DA0
FA1, ok= FA1, err=2000FA1
FA2, ok= FA2, err=2000FA2
FA3, ok= FA3, err=2000FA3
FA4, ok= FA4, err=2000FA4
FA5, ok= FA5, err=2000FA5
FA6, ok= FA6, err=2000DA6
FA7, ok= FA7, err=2000FA7
FA8, ok= FA8, err=2000FA8
FA9, ok= FA9, err=2000FA9
FAA, ok= FAA, err=2000FAA
FAB, ok= FAB, err=2000FAB
FAC, ok= FAC, err=2000FAC
FAD, ok= FAD, err=2000FAD
FAE, ok= FAE, err=2000DAE
FAF, ok= FAF, err=2000FAF
FB0, ok= FB0, err=2000FB0
FB1, ok= FB1, err=2000FB1
FB2, ok= FB2, err=2000DB2
FB3, ok= FB3, err=2000FB3
FB4, ok= FB4, err=2000FB4
FB5, ok= FB5, err=2000FB5
FB6, ok= FB6, err=2000FB6
FB7, ok= FB7, err=2000FB7
FB8, ok= FB8, err=2000DB8
FB9, ok= FB9, err=2000FB9
FBA, ok= FBA, err=2000FBA
FBB, ok= FBB, err=2000FBB
FBC, ok= FBC, err=2000FBC
FBD, ok= FBD, err=2000FBD
FBE, ok= FBE, err=2000FBE
FBF, ok= FBF, err=2000FBF
FC0, ok= FC0, err=2000FC0
FC1, ok= FC1, err=2000FC1
FC2, ok= FC2, err=2000FC2
FC3, ok= FC3, err=2000FC3
FC4, ok= FC4, err=2000FC4
FC5, ok= FC5, err=2000FC5
FC6, ok= FC6, err=2000DC6
FC7, ok= FC7, err=2000FC7
FC8, ok= FC8, err=2000FC8
FC9, ok= FC9, err=2000FC9
FCA, ok= FCA, err=2000DCA
FCB, ok= FCB, err=2000DCB
FCC, ok= FCC, err=2000FCC
FCD, ok= FCD, err=2000FCD
FCE, ok= FCE, err=2000FCE
FCF, ok= FCF, err=2000FCF
FD0, ok= FD0, err=2000FD0
FD1, ok= FD1, err=2000FD1
FD2, ok= FD2, err=2000FD2
FD3, ok= FD3, err=2000FD3
FD4, ok= FD4, err=2000FD4
FD5, ok= FD5, err=2000FD5
FD6, ok= FD6, err=2000FD6
FD7, ok= FD7, err=2000DD7
FD8, ok= FD8, err=2000DD8
FD9, ok= FD9, err=2000FD9
FDA, ok= FDA, err=2000FDA
FDB, ok= FDB, err=2000FDB
FDC, ok= FDC, err=2000FDC
FDD, ok= FDD, err=2000FDD
FDE, ok= FDE, err=2000FDE
FDF, ok= FDF, err=2000FDF
FE0, ok= FE0, err=2000DE0
FE1, ok= FE1, err=2000FE1
FE2, ok= FE2, err=2000FE2
FE3, ok= FE3, err=2000FE3
FE4, ok= FE4, err=2000FE4
FE5, ok= FE5, err=2000FE5
FE6, ok= FE6, err=2000DE6
FE7, ok= FE7, err=2000DE7
FE8, ok= FE8, err=2000FE8
FE9, ok= FE9, err=2000FE9
FEA, ok= FEA, err=2000FEA
FEB, ok= FEB, err=2000DEB
FEC, ok= FEC, err=2000DEC
FED, ok= FED, err=2000FED
FEE, ok= FEE, err=2000FEE
FEF, ok= FEF, err=2000FEF
FF0, ok= FF0, err=2000FF0
FF1, ok= FF1, err=2000FF1
FF2, ok= FF2, err=2000FF2
FF3, ok= FF3, err=2000FF3
FF4, ok= FF4, err=2000FF4
FF5, ok= FF5, err=2000FF5
FF6, ok= FF6, err=2000FF6
FF7, ok= FF7, err=2000FF7
FF8, ok= FF8, err=2000FF8
FF9, ok= FF9, err=2000FF9
FFA, ok= FFA, err=2000FFA
FFB, ok= FFB, err=2000FFB
FFC, ok= FFC, err=2000FFC
FFD, ok= FFD, err=2000FFD
FFE, ok= FFE, err=2000FFE
FFF, ok= FFF, err=2000FFF
发表于 2018-2-21 10:41:15 | 显示全部楼层
我有个测试方法,可以作为测试参考,用在RT1050上不知道是否可行。之前几个客户自己做F429板子加SDRAM验证过几次。
每次读写之间加个延迟,设置不同延迟时间试试,如果加上延迟后可以正常通信了,基本可以确定是硬件有问题。
发表于 2018-2-21 12:16:35 | 显示全部楼层
辛苦辛苦,过年还忙着调试硬件。呵呵
发表于 2018-2-24 10:10:23 | 显示全部楼层
eric2013 发表于 2018-2-21 10:41
我有个测试方法,可以作为测试参考,用在RT1050上不知道是否可行。之前几个客户自己做F429板子加SDRAM验 ...
我这也有个内存测试方法,是从一个外国DIY爱好者的网站找的,具体链接忘记了,知道的可以告诉我一下
这个测试方法比我自己写的好用,流程是
* 先测试数据总线
* 然后测试地址总线
* 然后就是常用的读写测试
我试用后效果较好,可以识别虚焊或者时序配置问题,这是我直接从工程中拷贝出来的,希望帮到楼主,也想看看楼主有没有更好的方法
bsp_sdram.h
291 Bytes, 下载次数: 91
bsp_sdram.c
18.35 KB, 下载次数: 92
发表于 2018-2-24 10:56:37 | 显示全部楼层
非常感谢
这个是官方最新的RT1052评估板,比较坑。
发表于 2018-2-24 11:13:39 | 显示全部楼层
eric2013 发表于 2018-2-24 10:56
非常感谢
楼主有结论记得说下,看看这方案表现如何
 楼主| 发表于 2018-4-13 01:48:07 | 显示全部楼层
结论: 该例程配置SDRAM主频为 166M可能是最大极限了。降低到163M就全部OK了。
就该问题发邮件咨询过NXP相关人员,按其提示操作,均无法解决问题。只有降低主频。
发表于 2018-4-13 09:00:42 | 显示全部楼层
就该问题发邮件咨询过NXP ...
把SDRAM上的VDD或VCC的去耦合电容加大,或许能解决这类问题。例如标准的用104,实际上用105或106效果可能会好得多,因为一方面电容质量不参差不齐,本身容易误差就有20%,质量差的就可能远远不止了。还有一个就是电源质量纹波质量差也会影响,这些并不是换个适配器就可以解决的事情,布线影响也很大的,这方面我之前调LPC4337的时候吃过苦头的,用104的电容调了几年都没搞定,无意中加上几个226的电容全好立杆见影啊。
以上仅仅是经验之谈。
GMT+8, 2026-11-23 05:10 , Processed in 0.362217 second(s), 27 queries .
