查看: 5477|回复: 18
[uC/Probe] uC/Probe已经升级至4.3.0.50,就是下载速度太慢,只有几KB(已经更新百度云下载)
发表于 2018-2-10 02:17:51 | 显示全部楼层 |阅读模式
百度云下载(4.3.0.50):
链接:https://pan.baidu.com/s/1bqWZdIf 密码:6ces
Micriμm μC/Probe 4.3
General Bug Fixes:
Cannot copy and paste scaling properties in the Oscilloscope Control.
When associating the Oscilloscope Control's channels to 16-bit variables, the control doesn't work.
Under certain circumstances, the Oscilloscope Control fails to update the waveform.
Missing check for zero in some of the Controls' font-size properties.
The Bit Control was not working properly under certain circumstances.
The uC/OS-II Kernel Awareness screen is crashing at run-time.
The Fonts in the uC/Probe application look blurry.
The Refresh button in the Settings dialog doesn't work properly.
The Bitmap Animation Control fails to display certain formats of PNG images.
General Improvements:
Major overhaul of our third-party framework to bring uC/Probe to their latest version. The new framework not only improves the performance and look of the application but it will also allow us to bring more sophisticated features in the future.
Increased the resolution of the Snap-to-Grid function.
Created the ability to roll back a software update.
Created the ability to rotate all the controls.
Created keyboard shortcuts for some of the most common functions.
Included the ability to remember Probe's size and position within Windows.
Included the ability to remember the size and location of the spreadsheet control.
Modified the Kernel Awareness screen to display the Event Flags' values in HEX or Binary format.
Included monitoring of the ISR Stack for uC/OS-III.
Updated the Symbol Browser's parser to support I/O files that are provided directly from the semiconductor manufacturers (.svd and .sfr)
Created a new Drawing tool that allows you to draw basic shapes and connectors between the shapes and other controls.
Included the ability to load multiple ELF files to support multi-core platforms and/or boards with multiple devices.
Updated the Chip Definition Files to support some of the latest chips.
Updated the Cypress PSOC Programmer Library.
Updated the J-Link Driver from SEGGER.
Improvements to the Infineon Edition of uC/Probe only:
Included the options for Keil and CMSIS-DAP communication interfaces.
Improvements to the Silicon Labs Edition of uC/Probe only:
Included a few J-link device options to configure generic devices that are too new.
发表于 2018-2-10 07:40:23 | 显示全部楼层
以前和谐能用吗?辛苦
 楼主| 发表于 2018-2-10 11:10:51 | 显示全部楼层
hqgboy 发表于 2018-2-10 07:40
以前和谐能用吗?辛苦
amobbs上的网友更新了:https://www.amobbs.com/thread-5687516-1-1.html
 楼主| 发表于 2018-2-10 11:11:16 | 显示全部楼层
我这里已经下载了一上午了,下载速度难以忍受
发表于 2018-2-11 11:37:38 | 显示全部楼层
还不支持断点续传,头都大了,官网自己下载完全是浪费时间,还好阿莫网友分享了。
发表于 2018-2-11 11:37:47 | 显示全部楼层
发表于 2018-2-12 20:43:32 | 显示全部楼层
0.90都出来了。。阿莫上不去。自从账号无故封了再也不申请
 楼主| 发表于 2018-2-13 00:21:16 | 显示全部楼层
这个是他们官网介绍的bug,uC/Probe点击升级,会提示4.3.0.90
而在官方下载,却是4.4.0.50
 楼主| 发表于 2018-2-13 01:23:30 | 显示全部楼层
界面字体改的有点大
发表于 2018-2-13 01:53:17 | 显示全部楼层
下载了。。。
发表于 2018-2-18 09:36:51 | 显示全部楼层
这玩意不仅实用,还能炫酷,真是难得的好东西…
发表于 2018-2-21 21:40:53 | 显示全部楼层
被和谐了啊…………楼主
 楼主| 发表于 2018-2-22 01:50:31 | 显示全部楼层
yanchao7788 发表于 2018-2-21 21:40
被和谐了啊…………楼主
没有和谐,你的网络估计有问题,刷新浏览器即可。
发表于 2018-2-27 09:24:57 | 显示全部楼层
这个是我在amobbs发的帖子,需要我把4.3.0.90,发到这边来吗? 主要是我懒得弄百度云
刚看到,4.3.0.90 已经有另外的帖子了,也有网友把破解文件转过来了。   后面出新版本需要破解可以找我要
发表于 2018-2-27 20:42:21 | 显示全部楼层
弱弱的问一句,这个软件是干什么用的 啊 ?
 楼主| 发表于 2018-2-28 02:24:43 | 显示全部楼层
发表于 2018-2-28 10:15:24 | 显示全部楼层
eric2013 发表于 2018-2-28 02:24
https://forum.anfulai.cn/forum.php?mod=viewthread&tid=50280&extra=page%3D1
你好,是不是这个软件只针对 ucos 有用 ?
对于 freeRTOS 是否适用啊 ?
发表于 2018-2-28 10:27:29 | 显示全部楼层
都可以用,其他系统只能用全局变量,RTOS的看不了。
 楼主| 发表于 2018-3-1 02:02:28 | 显示全部楼层
对于 freeRTOS 是否适用啊 ?
不适合FreeRTOS,针对uCOS的。
GMT+8, 2026-11-23 13:23 , Processed in 1.848748 second(s), 26 queries .
