查看: 4532|回复: 2
[J-Link] SEGGER官方整理的一些JLINK配合MDK的问题解决办法
发表于 2018-1-30 00:44:18 | 显示全部楼层 |阅读模式
https://www.segger.com/products/ ... eil-mdk/#tab-4285-3
MDK V5.18 or earlier
  • Problem: When using ETM trace functionality with J-Trace for Cortex-M, status bar in uVision showed "Trace: No synchronization".
  • Problem: When using ETM trace functionality with J-Trace PRO for Cortex-M, sometimes the error "Failed to read trace data" appeared.
  • Problem: When using ETM trace functionality with J-Trace PRO for Cortex-M, uVision sometimes crashed when large amounts of trace data were read.
Solution: Copy this version (V2.99.20) of the JL2CM3.dll to $MDK_INST_DIR$\ARM\Segger.
MDK V4.60 or earlier
  • Problem: Some SW-DP Ids of Cortex-M0+ devices were not recognized correctly, resulting in an error message when trying to start a debug session. For example the Freescale Kinetis L-series devices showed this problem.
Solution: Copy this version (V2.74) of the JL2CM3.dll to $MDK_INST_DIR$\ARM\Segger.
MDK V4.54 or earlier
  • Problem: For some Cortex-M devices debug register base address detection did not work properly which messed up flash download using the J-Link flashloader.
  • Problem: When selecting a device in the J-Link device selection dialog, the selection was not saved, so the dialog popped up again at the start of the next debug session.
  • Problem: When using ETM trace, under special circumstances, uVision could crash.
Solution: Copy this version (V2.71) of the JL2CM3.dll to $MDK_INST_DIR$\ARM\Segger.
MDK V4.53 or earlier
  • Problem: In case multiple J-Links are connected to the PC, uVision was not able to recognize them correctly.
Solution: Copy this version (V2.68) of the JL2CM3.dll to $MDK_INST_DIR$\ARM\Segger.
 楼主| 发表于 2018-1-30 00:45:33 | 显示全部楼层
J-Link built-in flashloader
发表于 2018-2-12 07:09:56 | 显示全部楼层
GMT+8, 2026-11-24 08:16 , Processed in 0.438709 second(s), 27 queries .
