查看: 6280|回复: 9
[emWin] RA8870 STemWin5.26 f405
发表于 2015-4-15 11:16:14 | 显示全部楼层 |阅读模式
调试ra8870一星期了,调试时一直卡在emWin_LCD_Init里LCD_FillRect里的_FillRect,在执行BTE使能命令(0x50-0x80)时进入hardfalut(此时屏幕白屏)
,用自带的驱动可显示窗口文字,fsmc配置无数次无果
http://pan.baidu.com/s/1fgh90
 楼主| 发表于 2015-4-15 11:17:41 | 显示全部楼层
用的
void LCD_X_Config(void)
    GUI_DEVICE *pDevice;
    CONFIG_FLEXCOLOR Config = {0};
    GUI_PORT_API PortAPI = {0};
    // Set display driver and color conversion
    pDevice = GUI_DEVICE_CreateAndLink(GUIDRV_FLEXCOLOR, GUICC_565, 0, 0);
    // Display driver configuration, required for Lin-driver
    LCD_SetSizeEx (0, XSIZE_PHYS , YSIZE_PHYS);
    LCD_SetVSizeEx(0, VXSIZE_PHYS, VYSIZE_PHYS);
    // Orientation
//    Config.FirstCOM = 0;//lsz
//    Config.FirstSEG = 0;  //lsz
    Config.Orientation = GUI_SWAP_XY | GUI_MIRROR_Y;
//    Config.NumDummyReads=2;
    GUIDRV_FlexColor_Config(pDevice, &Config);
    // Set controller and operation mode
        PortAPI.pfWrite16_A0  =LcdWriteReg;
        PortAPI.pfWrite16_A1  =  LcdWriteData;
    PortAPI.pfWriteM16_A1 = LcdWriteDataMultiple;
    PortAPI.pfReadM16_A1  = LcdReadDataMultiple;
    GUIDRV_FlexColor_SetFunc(pDevice, &amportAPI, GUIDRV_FLEXCOLOR_F66721, GUIDRV_FLEXCOLOR_M16C0B16);
 楼主| 发表于 2015-4-15 11:18:30 | 显示全部楼层
void LcdWriteReg(U16 Data)
    LCD_REG_ADDRESS = Data; //lsz 0325
    // ... TBD by user
*       LcdWriteData
* Function description:
*   Writes a value to a display register
void LcdWriteData(U16 Data)
    LCD_DATA_ADDRESS = Data; //lsz 0325
    // ... TBD by user
*       LcdWriteDataMultiple
*   Writes multiple values to a display register.
void LcdWriteDataMultiple(U16 *pData, int NumItems)
    while (NumItems--)
        LCD_DATA_ADDRESS = *pData++; //lsz
        // ... TBD by user
*       LcdReadDataMultiple
*   Reads multiple values from a display register.
void LcdReadDataMultiple(U16 *pData, int NumItems)
    while (NumItems--)
        *pData++ = LCD_DATA_ADDRESS; //lsz
        // ... TBD by user
u16 LcdReadData(void)
    u16 Data;
    //GPIO_ResetBits(GPIOD,GPIO_Pin_7);
    Data = LCD_DATA_ADDRESS; //lsz
    return(Data);
u16 LcdReadReg()
    u16 Data;
    // GPIO_ResetBits(GPIOD,GPIO_Pin_7);
    Data = LCD_REG_ADDRESS;
    return(Data);
 楼主| 发表于 2015-4-15 11:21:34 | 显示全部楼层
void LCD_FSMC_Init(void)
//   FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &p;
//        FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &p;
//        FSMC_NORSRAMStructInit(&FSMC_NORSRAMInitStructure);
        FSMC_NORSRAMInitTypeDef  FSMC_NORSRAMInitStructure;
    FSMC_NORSRAMTimingInitTypeDef  p;
        FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);  //
    p.FSMC_AddressSetupTime = 5;
    p.FSMC_AddressHoldTime = 0;
    p.FSMC_DataSetupTime =5;
    p.FSMC_BusTurnAroundDuration = 5;
    p.FSMC_CLKDivision = 0;
    p.FSMC_DataLatency = 0;
    p.FSMC_AccessMode = FSMC_AccessMode_A;
//    p.FSMC_AddressSetupTime = 4;
//    p.FSMC_AddressHoldTime = 0x00;
//    p.FSMC_DataSetupTime = 8;
//    p.FSMC_BusTurnAroundDuration = 1;
//    p.FSMC_CLKDivision = 0x00;
//    p.FSMC_DataLatency = 0x00;
//    p.FSMC_AccessMode = FSMC_AccessMode_A;
    FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM1;
    FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;
    FSMC_NORSRAMInitStructure.FSMC_MemoryType = FSMC_MemoryType_NOR ;
    FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;
    FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Disable;
    FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait = FSMC_AsynchronousWait_Disable;
    FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
    FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;
    FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
    FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable;
    FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
    FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable;
    FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
    FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM1, ENABLE);  //
 楼主| 发表于 2015-4-15 11:24:08 | 显示全部楼层
void RA8870_PLL_ini(void)
    LcdWriteReg(0x88); //lsz 针对不同的CPU更改
//    Delaynms(1);
    LcdWriteData(0x06);
    Delaynms(2); //After REG[88h] or REG[89h] is programmed, a lock time (< 30us) must be kept to guarantee the stability of the PLL output. After the lock time period, a software reset must be asserted and user must re-program the RA8870 to complete the procedure
    LcdWriteReg(0x89);
    LcdWriteData(0x03);
    LcdWriteReg(0x01);  //在死锁时间过后,用户必须产生一个软件Reset以完成PLL频率改变的程序
    LcdWriteData(0x01);
    LcdWriteData(0x00);
    Delaynms(2);
发表于 2015-4-15 11:57:04 | 显示全部楼层
怎么不用我们开发的在emWin下的通用驱动方案,很好用。官网的这种驱动一直没有用过。
 楼主| 发表于 2015-4-15 12:36:16 | 显示全部楼层
 楼主| 发表于 2015-4-15 12:44:38 | 显示全部楼层
他说的有些小问题,也嫌麻烦吧
 楼主| 发表于 2015-4-17 09:44:04 | 显示全部楼层
这块函数补全就好了
发表于 2015-4-17 09:51:06 | 显示全部楼层
回 sirbai008 的帖子
sirbai008:       &#160ortAPI.pfWrite16_A0  =LcdWriteReg;
       &#160ortAPI.pfWrite16_A1  =  LcdWriteData;
   &#160ortAPI.pfWriteM16_A1 = LcdWriteDat .. (2015-04-17 09:44)
[s:150][s:151]
GMT+8, 2026-11-23 07:29 , Processed in 0.477565 second(s), 24 queries .
